Results 1 to 15 of 15
    Senior Member Three Rings fallingreason's Avatar
    Jul 07 2011
    Bicycles
    SF Bay Area
    2007 B7 A4 Avant - DTM - K04 - OEM+
    Putting out a feeler for my B7. Have had 2 B6's this is my second B7. Finally looking to move on to another platform. There is a lot invested in this car, she has all the right parts and runs like a top. Post is a feeler as I'm not in a rush to get into a new vehicle, but will likely happen in the next year or so. Will sell to the right buyer, as I bike to work except in winter (hence low miles).
    Details:
    -2007 B7 Avant, Tiptronic with 71xxx miles 3rd owner, CA car. Asking $16,000
    Modifications:
    Suspension/Wheels
    -Bilstein PSS9 Coilovers
    -034 Strut Mounts
    -034 Adjustable Upper Control arms
    -034 Density Lower Control Arms and Front end links
    -034 Rear Sway bar and adjustable end links
    -Meyle HD solid Tie Rod Ends
    -Refreshed OEM Front Sway Bar Bushings
    -OEM B8 S4 Peelers 19x8.5 et43, new Continental Extreme Contact Sport 245/35/19
    Brakes
    -OEM Q5 3.0T Brembo Stage 3 BBK, OEM pads, ECS coated Rotors, Stainless lines for front calipers
    Driveline
    -034 Street Density Engine mounts
    -034 Street Density Transmission Mounts
    -034 Rear Differential Carrier Bushing Inserts
    -ECS Tuning Poly Rear Differential Mount
    -ECS Poly Snub Mount
    Engine
    -JHM K04-R Turbo
    -HPFP Upgrade (new unit bench tested from HPFPupgrade.com)
    -OEM S3 Injectors
    -034 HFC
    -JHM Y-Pipe Downpipe
    -OEM B7 S4 Exhaust, with OEM S4 rear diffuser for quad-tip
    -Evolution Racewerks Side Mount Intercoolers
    -ECS Silicone Turbo inlet and throttle body hoses
    -GFP DV+ Diverter Valve
    -034 Catch Can
    -Motoza 91 Oct ECU tune with cable (the tune I run)
    -Unitronic KO4 w/ HPFP tune (with uniconnect cable), 93oct
    -JHM TCU Tune
    Interior
    -OEM B7 Avant Recaro Seats, Black Leather, great shape
    -OEM RNSE
    -Dension Gateway Bluetooth streaming/hands free
    -Upgraded front door speakers (unsure of make, prior owner had this done)
    -ECS Tuning Billet Hood Latch release
    -P3 Cars VIDI interface multi-function gauge
    -S-Line Steering Wheel
    -RS4 aluminum sport Pedals
    -OEM All weather Mats
    -OEM rubber trunk liner
    -OEM carpet mats with silver piping (new 2 years ago)
    -DeAutoLED interior lighting kit + license plate lights
    Exterior
    -OEM DTM front Bumper
    -OEM DTM Side Skirts
    -OEM S4 Mirror caps
    -Rear Parking sensors
    -Osram Xenarc LEDriving Headlights with clear LaminX
    -Evolution Import Thor Skid Plate
    -50% Tint all around
    -Yakima Whispbars
    Maintenance
    -Timing belt done a few years ago by previous owner
    -Both Front window regulators by previous owner
    Since 63k the car has had:
    -Spark Plugs - NGK BKR8EIX iridium
    -New OEM R8 Coilpacks
    -New MAF
    -New Front O2 Sensor
    -New Fuel Filter
    -New Cam follower
    -New N75
    -New Breather from block to valve cover
    -New Thermostat and temp sensor
    -New Oil filter Housing assembly and gaskets to block/oil cooler
    -New Coolant Reservoir
    -New front and Rear wiper blades
    -New Valve cover assembly + Gasket
    -New Throttle Body
    -New Rear Seat Latches
    -New engine and cabin air filters
    -New Hood and Hatch struts
    -Transmission Fluid service @ 63k
    -Brake Fluid Flush @ 70k
    -Have new OEM parts for PCV system if you do not wish to run a catch can
    -Have new rebuild kit for 034 Adjustable arms (bushings, helms, dust boots)
    -Have new wiper stalk to swap for DIS trip computer, never had time to install
    -Tires are brand new last month, brake pads are 7.0mm front and back.
    -Alignment was done 6mo ago and rechecked at same shop where tires were purchased/installed
    Bads:
    -Rear bumper was repainted at some point, and is not the greatest work. Has a fairly large blemish on rear bumper, driver side.
    -Front bumper has started to get some rock chips, but looks great for a DD
    -Scratch on rear hatch from opening in a garage area that was not tall enough, touch up paint applied.
    -Some marks on headliner in rear of car due to wheel transportation
    I think that's everything. Looking for $16,000. Hoping to get feedback on pricing and desirability of the car. Not sure how many nicely cared for B7's are out there with this low of mileage. Tune was done carefully with Dave at Motoza. With the intercoolers the ECU pulls only -1.75 degrees of timing up top.
    I have a spreadsheet with all maintenance documents, as well as hard copies of all work not done by me. Most recent work (preventative) done at JHM with a clean bill of health.
    Any questions just shoot me a PM
    2007 B7 Avant - JHM K04 - Motoza - JHM TCU Tune - PSS9 - 034 Arms, Sway, Links - Brembo Q5 BBK - Recaro - DTM - Osram Xenarc - S4 Peelers - Evolution Racewerks
    // A C B A
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    Price?
    Sent from a misfiring cylinder
    2014 RS5 Sepang/White - Akrapovic/Eventuri/034/Eurocode/Bilstein/Euro headlights and tails/Euro mirrors/BLK Wheels/Escort/Blackvue
    2018 Audi S4 (wifemobile) -Navarra Blue/Black Optics/Virtual Cockpit/Carbon inlays -Mods coming soon..
    @Driven_Not_Hidden
    Jul 07 2011
    Bicycles
    SF Bay Area
    Quote Originally Posted by ENVē View Post
    Price?
    $16k. Added to beginning of post
    // A C B A
    Established Member Two Rings griga's Avatar
    Jun 30 2017
    New Jersey
    Beautiful. GLWS.
    Silver 2008 A4 2.0T Cupra R Lip | 034 Mounts | Peelers |
    IG: https://www.instagram.com/rigadesigns/
    Nov 07 2012
    new bern, nc
    Just a suggestion. Your advertisement is extensive. Your price is a footnote at the bottom. The reason the guy asked about the price was because he didn't see it in the post. Putting the price at the beginning along mileage and basic condition before all the details is helpful. 2nd. If you do want to sell the car, when someone takes the time to ask a question about a detail in the post that they missed why not just give them the answer they want rather than tell them to read the ad again?
    Established Member Two Rings Kylet21's Avatar
    Dec 19 2016
    2012 TT RS
    Milwaukee, WI
    Assuming this is an automatic since a clutch isn’t mentioned anywhere
    Senior Member Three Rings eurojunkjon's Avatar
    Mar 12 2017
    2016 A3
    Burlington, wi
    I noticed it does mention jhm tcu tune in his sig
    Nov 04 2010
    Quote Originally Posted by txpd View Post
    This. I finally found it but it needs better placement. Good luck selling. Price might be high.
    @Driven_Not_Hidden
    Jan 06 2012
    Riverside
    Price you are looking for will seem high to most folks but it is a very low mileage example that has lived in the right part of the country with what appears to be great care. I built my 2008 GTI (which is same engine and suspension) to a similar level with similar parts and the cost of parts and labor is significant well over 10K. A well tuned K04 2.0t is a quick car and when you combine it with the suspension mods and brake mods it is a beast. So at 16K I suspect it is not a KBB bargain but for someone who wants all of these mods in a finished sorted out car, this really is a bargain, assuming it all checks out and the body and interior are also in great shape as they should be at only 71,000 miles.
    Jul 07 2011
    Bicycles
    SF Bay Area
    Agreed, will try not to reply from my phone from now on :)
    Reply and post edited.
    // A C B A
    Dec 19 2016
    2012 TT RS
    Milwaukee, WI
    Quote Originally Posted by eurojunkjon View Post
    I missed that.
    Active Member Two Rings Joshua516's Avatar
    Aug 17 2018
    East Bay, NorCal
    GLWS! I've always had a thing for the B7 S4 avants with DTM kits! Where could I possibly find those headlights? I've never seen those before.
    Jul 07 2011
    Bicycles
    SF Bay Area
    Thanks! The headlights I had to source form an Osram dealer in Germany. At the time plenty of GTI MK7 kits were in the US but none for the B7.
    // A C B A
    Established Member Two Rings willroc7's Avatar
    Sep 04 2014
    Very impressive car. GLWS!
    Established Member Two Rings Jargon's Avatar
    Dec 01 2017
    Oregon
    Very nice car. More pictures anywhere?
    The price seems good, despite it being automatic (although in SF I bet you wouldn't even want a manual).
    2006 A4 Avant 2.0T Quattro 6MT
    2005 BMW 325xi Touring 5MT
