Results 1 to 6 of 6
    Established Member Two Rings royrogers's Avatar
    Feb 18 2019
    canada
    CV Boot, received a different axle bolt do I torque it differently?
    Hope someone is here to see these questions, wanted to do this today. Called audi dealership but they are closed so guess I sit on my hands till someone replies.
    Replacing CV boots 2000 Audi S6, just got the front CV boots from rock auto
    https://www.rockauto.com/en/moreinfo...2MdpTtCA%3D%3D
    the axle bolts have a different head than whats on the car, the car has the allen type head and the ones on this kit are a hex 1 1/16. I assume they are the same thing only with a different head???? Also do I torque them the same???? and finally I saw a video stating that when working on an older car you should not do the full 180 degrees cause of the bearings, he said he does 90 degrees.???
    thanks
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    Same torque but have a helper when doing the final 180 so your socket doesn't slip and you break your wrist. I prefer the Allan type to be honest.
    I have done this several times on older bearings and I don't think it will wreck em. I try to get as close to 180 as possible.
    Feb 18 2019
    canada
    Steely, should I just wait? I can go to the dealer on monday and do this next weekend. I've only got a deep socket 1 1/16. If I have to put so much torque on it maybe it can slip - is it really that tight?
    Dec 10 2013
    Borden, Ontario, Canada
    I usually torque 135-180° for final.
    You could always do less and let us know how it goes for you lol
    Sent from my SM-G935W8 using Tapatalk
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jun 07 2005
    Shepherdstown, WV
    I've never used the random Chinese large hex bolt that comes with CV kits and axles. I'll reuse the stock one before I use them, I don't trust them. Just replace with an oe one next chance I get.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Feb 18 2019
    canada
    ok got one side done, made quite a few mistakes so am gonna post those on the what I would call "official" cv boot/axle removal thread. Thanks for the help
    https://www.audizine.com/forum/showt...ighlight=boots
