Results 1 to 12 of 12
    Jun 04 2017
    2010 A6 Door Locking and Window not closing all the way up problem
    Hi guys,
    Used to be random working not working, mostly now not working anymore. It`s the front passenger door that doesn't lock, all others doors lock. Now I noticed on that door also the window goes up all the way and then comes back to 75% open and the only way to close it all the way is to hold the button and it closes 100% the window.
    I used to think it`s the locking module but now with the window issue on the same door kinda leads me think it's the computer module.
    https://www.ebay.com/itm/05-08-AUDI-...IAAOSwm-Ncq76Y
    What do you think ? anyone had the same issue with their front doors ?
    Thank you
    Jun 04 2017
    is there a way to check the module with VCDS ?
    Oct 31 2013
    Land Rover LR3, Harley Dyna Fat Bob, Triumph Speed Triple
    Washington DC / NoVa
    I have a similar issue. Passenger door doesn’t lock. I’m thinking you have two separate issues. The door is the actuator. I have been too lazy to tear apart the door and repair. I just lock it by using the key on the inside of the door jam.
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Mine locks but doesn’t unlock. I too have been to lazy to replace the actuator
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Jun 04 2017
    been lazy as well but I kinda wanna fix it now...I was thinking the actuator but now with the window acting funny kinda takes me to that module more and more, or I might have 2 issues in fact
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    From what I understand, the actuator is a complete PITA to change. My drivers door doesn't lock without inserting the key and its been a year or so and I haven't tried because I heard it was so hard.
    If you have any luck i'd be interested.
    Just not something I ever tried to tackle.
    My pass window doesn't always wanna roll back up from the driver switch but does with passenger so thats just a bad switch.
    2006 A6 3.2L Quattro S-Line (got my baby back)
    Oct 31 2013
    Quote Originally Posted by JPJ2007 View Post
    I have the exact same situation with my passenger window. Doesn’t roll up from the driver switch so I have to reach across to the passenger door....problem solved :)
    Apr 15 2009
    Middle TN
    Yeah ive made a few offers on ebay for a good switch but i cant bring myself to pay 40ish for it.
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    These actuators have been prone to failure since its original iteration in the C5 generation. Even door lock sensors have been known not to communicate well with the comfort module. Part is cheap, but the process of replacing is rather tedious, lol
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Jan 10 2019
    Pittsburgh
    In winter my drivers door does not unlock with the fob but will lock just fine. I just use the key to unlock the door the old fashioned way. When weather warms up everything is AOK.
    I also have the sporadic issue with the passenger window auto close opening. This is a safety function that occasionally malfunctions. The way to get it to close is to open the window all the way and then close it while continuously holding the close button. It will disengage the auto close.
    These are minor annoyances that I have absolutely no plan on fixing!
    2009 A6 Avant Phantom Black Pearl / Amaretto Black Interior BONE STOCK / 149,000 miles and counting
    2006 BMW E46 M3 Convertible / Jet Black / SMG (and proud of it) / 54,000 miles
    Aug 24 2014
    Newport Beach, CA
    I had issues with the driver's door lock this winter (albeit California winter), except it would be intermittent whether it locks/unlocks with the key fob. Sometime in January it magically fixed itself and has not had issues since... go figure.
    Knock on wood, but unfortunately with cars things rarely just 'fix' themselves.
    2024 M3 Comp xDrive
    Jun 04 2017
    thanks guys, well I have the exact issue for the past year or more sometimes it locks, sometimes it doesn't and now it just doesn't anymore. For the Window like someone else mentioned I only tested from the driver switch and noticed that, and if you hold the button after you open it all the way it works... small things but very annoying.
