Results 1 to 7 of 7
    Senior Member Two Rings FourRingThing's Avatar
    Jun 17 2011
    Charleston, SC
    Need help with issue
    I have been chasing a problem for a few years know where when it gets hot like August if I get stuck in traffic or something like that I get a misfire code and "Coil" primary/secondary fault and go into EPC. It is always cylinder 3 only on a 3.0T, I can then typically reset and everything is fine as long as I can get moving to cool things down. I have done the obvious and changed the coil pack but that was not it, I have had this issue for a few years and only when it is really hot. However this year it has already happened granted it was the hottest day of the year so far but not hot for around here so it appears to be getting worse. Is there an electric fan maybe that should be running when stuck in traffic? Any help would be appreciated.
    2021 B9 S5, Black optics, Sorts Package, Black door handles, spoiler wrapped black, IE intake and inlet pipe, ECS Tuning strut tower support.
    (sold) 2012 C7 A6 3.0T Prestige, Innovation Package, 20" Sport Package.
    Jun 08 2014
    C7 A7 4.0T
    Illinois
    Quote Originally Posted by FourRingThing View Post
    Did you change your plugs or at least inspect them?
    Sent from my BBB100-1 using Audizine mobile app
    Jun 17 2011
    Charleston, SC
    Yes, when I changed the coil pack, when it goes bad it reports coil primary/seccondary open
    Jun 08 2014
    C7 A7 4.0T
    Illinois
    Ok, any possibility that it's the harness? Just trying to cover all bases.
    Deactivated Four Rings
    Jun 23 2011
    What is the exact code or what does the VCDS say?
    Jun 17 2011
    Charleston, SC
    It comes up 0303 and 1361, always clears and will be fine unless I continue to be stuck in traffic then it will come back until I can cool it down some. Hell many times I can just shut it off and restart and it will be fine. Thanks for the help I am thinking connector but where?
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Try moving the number 3 coil pack to another location and see if the misfire follows it to the new location. If it does then you probably have a bad coil pack despite it being new. Check all the boots to make sure there are no holes/gaps allowing the spark to jump.
