Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 141
  1. #81
    Feb 07 2018
    PDX ish
    Mine are not that concave so I'd guess face two honestly don't know.
    1010tires wheel fitment puts you at -1 mm clearance (8.5et 43 vs. 10et 25). Maybe the concavity makes a big difference. Just throwing some info out there for you. If I waited 6 months I would want them on asap but if its not a daily I get that too. GL.
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
  2. #82
    Senior Member Three Rings Circuit's Avatar
    Aug 02 2015
    Las Vegas, NV
    Quote Originally Posted by hardfive View Post
    Yeah that -1mm is only to the suspension, not to the calipers. Face design makes a much bigger difference than offset. Appreciate it!
    Between tires, ceramic coating, another alignment, etc. I won't be throwing them on for a week or two after they arrive. Plenty of time to order spacers! Thanks for the heads up though!
  3. #83
    Aug 02 2015
    Las Vegas, NV
    Had a 2-stage correction and ceramic coating done for the Wekfest SJ car show this past weekend. Also borrowed my friends OEM 300L roof box for the show.
  4. #84
    Veteran Member Three Rings Dusty Mauve's Avatar
    Feb 04 2011
    Norway
    Looks awesome with the box, Chris.
    Get yourself one and paintmatch it!
    13 A6 C7 Allroad - 3.0 biTDI - Havana Black
    09 A4 B8 Allroad - 2.0 TDI - Condor Grey
    05 Caddy 2K - 1.9 TDI - Light Silver
    00 A4 B5 Avant - 1.8 TQ - Light Silver
    Instagram
  5. #85
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    That looks fantastic!!
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
  6. #86
    Aug 02 2015
    Las Vegas, NV
    Quote Originally Posted by Dusty Mauve View Post
    Yeah paint match is a must! After the correction the difference between the Phantom Black on the car and gloss black box is insane!
    Quote Originally Posted by eljay View Post
    Thank you!
  7. #87
    Aug 02 2015
    Las Vegas, NV
    Last set of shots before returning the box.
  8. #88
    Aug 02 2015
    Las Vegas, NV
    Prepping to finally install my OEM+ BBK this weekend
    S6 400mm 6-piston fronts
    Q7 356mm 4-piston rears
    Tesla Model S e-brake
    Voshmods brackets for the rear
    Blank zimmermann rotors
    Porsche Macan dust shields and air deflectors
    Calipers are all powder coated as close to the OEM Ceramic finish as possible. Dust shields done in Satin Black
    Also picked up a beat S4 Vorsteiner lip that will get refinished/cut to fit my front bumper.
  9. #89
    Feb 04 2011
    Norway
    Excited to see those S6 calips on the car!
    Instagram
  10. #90
    Aug 02 2015
    Las Vegas, NV
    Got everything installed this weekend. Now just need to bleed, bleed, and bleed!
  11. #91
    Feb 04 2011
    Norway
    That looks so good!
    Love that you did them in a silver/grey color.
    Instagram
  12. #92
    Aug 02 2015
    Las Vegas, NV
    Came across 2 separate pairs of Gram Lights on Facebook marketplace and decided I needed Japanese wheels on the car. Both pairs were 20x10, but one pair is +20 and the other +30. My fronts have always been more sunk than the rears, so I thought putting the +20 in the front would work out well.
    I had the wheels redrilled from 5x114.3 (I think they were originally an R35 GTR front spec) to 5x112 and powder coated Volk Bronze. Center caps were refinished with bronze cerakote since they are plastic.
    Went for some meaty fitment with 285/30/20 Firestone Indy 500s. Needed some fender shaving and a little more camber, but they tuck nicely!
  13. #93
    Feb 07 2018
    PDX ish
    Fantastic. Obviously a ton of thought and care here.
    Not to infer these are anything but great, but what happened to the te37's?
  14. #94
    Aug 02 2015
    Las Vegas, NV
    They're still on order. The update I got in March was Nov-Dec (ugh), but more recently I was told they're coming in the next month LOL. I wouldn't have bought these Gram Lights if they were coming so soon, but oh well haha.
  15. #95
    Aug 02 2015
    Las Vegas, NV
    Its been a very eventful couple months. Just moved from the SF Bay Area to Las Vegas, got covid, got well, then wife got covid. So car stuff has been moving really slow.
    And just last week, these beauties arrived. Hello gorgeous!
    Going to be converting to studs so I can run Project Kics lug nuts. Need to test fit to confirm brake clearance some time this week (its going to cool down to 100), and then decide on tires.
  16. #96
    Aug 02 2015
    Las Vegas, NV
    Went out to Gears and Grinds out here in Vegas and met up with a couple other Avant owners
    Did a test fit with the TEs. Need to order tires.
  17. #97
    May 09 2012
    Virginia
    TE’s look great! Did you get them off the forum?
  18. #98
    Aug 02 2015
    Las Vegas, NV
    Quote Originally Posted by jbain2 View Post
    Thanks! I did not, bought them brand new and waited about 14 months.
  19. #99
    Aug 02 2015
    Las Vegas, NV
    Ordered a new set of 275/30/20 Michelin Pilot Sport 4S! got them mounted and everything ceramic coated. Just waiting on a stud conversion to get the wheels on!
    64mm Motorsport hardware studs - too long to for Project Kics lug nuts
    44mm Motorsport hardware studs - too short for my liking and can't run a 3-5mm spacer in front. Can only get 7 turns when torquing down the lug nuts. Need 9 turns to get to 14mm of thread engagement
    55mm 034Motorsport studs - bullet nose too long for Project Kics lug nuts
    50mm H&R studs - on the way and should be just perfect!
    Also picked up an OEM 300L roof box from Facebook marketplace. Its a little scuffed up, so I might either get it repainted, or wrap it something fun.
  20. #100
    May 09 2012
    Virginia
    Quote Originally Posted by Circuit View Post
    Damn. Glad you didn’t get them off here. I was eyeing a set on here but ended up second in line. Would have had to send you hate mail had you been the swiper.
    Anyway, everything you have done is on point! Keep up the good work!
  21. #101
    Aug 02 2015
    Las Vegas, NV
    Haha! Good luck and thank you!
  22. #102
    Aug 02 2015
    Las Vegas, NV
    TEs are on!
    - H&R Quicksafe stud conversion (40mm length)
    - Project Kics M14 lug nuts
    - H&R 5mm front spacer
  23. #103
    May 09 2012
    Virginia
    Question for you on the suspension. How did you decide on the dual compressor setup versus a single compressor? What size tank are you running? Getting ready to do this on my Q7.
  24. #104
    Aug 02 2015
    Las Vegas, NV
    Dual compressor for redundancy and speed of refill, and also that's what fits on the BecauseBags bracket. Tank is 5L IIRC, same reason -- its what fits on the bracket.
  25. #105
    Aug 02 2015
    Las Vegas, NV
    Went to Big SoCal Euro this past weekend. Some shots from my buddy Ray.
  26. #106
    Aug 02 2015
    Las Vegas, NV
    Met up with a local photographer to get some shots.
  27. #107
    Aug 13 2015
    NS
    Looks amazing and great shots!!
    How about we just swap our Allroads, so you can save me a whole bunch of work?! :)
  28. #108
    Aug 02 2015
    Las Vegas, NV
    Everything is for sale, for the right price ;)
  29. #109
    Aug 13 2015
    NS
    OK, you stop it now at once! I don't need more temptations! ;)
  30. #110
    Aug 02 2015
    Las Vegas, NV
    Finally completed my OEM carbon atlas interior with the center console trim.
    S4-style carbon steering wheel with Urus-style paddles and TobyCook Allroad badge. Only interior piece I am waiting for now is a carbon skinned MMI surround.
    Switching rear brakes to Macan Turbo to simplify. Same size rotor/carrier as S6 rears (356mm), but the calipers have a cool cover plate. Powder coated S6 dust shields as well. Voshmods rear setup will be for sale once everything is swapped. Leaving red for now, but will do a full Acid Green caliper refresh front and rear, with 034's newly released 2-piece rotors.
  31. #111
    Aug 02 2015
    Las Vegas, NV
  32. #112
    Aug 02 2015
    Las Vegas, NV
    My Gram Lights are for sale!
    https://www.audizine.com/forum/showt...4#post14943534
    Had my MMI surround done in matching carbon atlas by a local carbon fiber guy. Interior is mostly done, for now.
    Quick snap while getting some tea. Not much done lately as I have been working on moving into our new home. Full brake overhaul ordered to knock out now that we're settled.
  33. #113
    Aug 02 2015
    Las Vegas, NV
    Refinished the brakes over the last couple weeks.
    Porsche Acid Green G2 paint
    034 2-piece rotors
    Macan Turbo front brake ducts (some trimming required to clear body at full lock)
  34. #114
    Account Terminated One Ring
    Jun 27 2023
    United States
  35. #115
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    034 2-piece rotors
    Assuming the labeling is vinyl stickers? Did you clear coat over the stickers?
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
  36. #116
    Aug 02 2015
    Las Vegas, NV
    Quote Originally Posted by Older_not_Wiser View Post
    Yeap just vinyl. No clear over it.
  37. #117
    Aug 02 2015
    Las Vegas, NV
  38. #118
    Aug 02 2015
    Las Vegas, NV
    Photos by Randy from SoCal Quattro at the SLO drive
  39. #119
    Aug 02 2015
    Las Vegas, NV
    Met up with James @food4audis for some shots at/near the Sphere
  40. #120
    Aug 02 2015
    Las Vegas, NV
    Tons of photos from Big Socal Euro coming in! Took home a Top 3 award for the Wagon category!
