Results 1 to 15 of 15
    Senior Member Two Rings AFAndrew's Avatar
    Nov 15 2015
    Salt Lake City Utah
    Corner Door panel Rattle
    Alright so i have a weird rattling coming from this part of my door panel. It when Iím on uneven roads and itís like something is loose. If i push it in a little it stops and Iíve checked and there is nothing thatís rattling and if i have the panel off itís gone. Thoughts?
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    So you've removed the door panel card entirely and proven that the rattle is not there with the door card removed? If so, I'd check all the clips that hold the card in place, also wrap any wiring harnesses or connectors that might flop around while driving. And check that any screws holding things in place like arm rests, door handles, window switches, etc are fully secure.
    Do let us know what you ultimately determine the cause to be and how you corrected it.
    2011 S4 | Prestige | Jet Blue | Black/Silver Silk Nappa | S-Tronic | Sport Diff | Drive Select | Side Assist | Titanium | Carbon Fiber Inlays | HRE R40s (summer) BBS RGRs (winter)
    Nov 15 2015
    Salt Lake City Utah
    Will do. Itís super annoying
    Mar 05 2016
    Montreal
    I know exactly how you feel. I had the same problem, last night I decided to pull out the panel, and had secured all loose parts. Ha...*♂️ feels good not hearing the annoying rattle anymore.
    Audi 2013 S-Tronic | REVO Stage 1+ | REVO Pulley | REVO TCU tune | EurocodeAFE intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe| RCP headlights & dual color fog lights.
    Nov 15 2015
    Salt Lake City Utah
    What parts did you tighten up?
    Mar 05 2016
    Montreal
    Quote Originally Posted by AFAndrew View Post
    Silicone, double side tape, and WB Weld to fix some clip holder that was broken.
    Nov 15 2015
    Salt Lake City Utah
    Do you have a picture?
    Mar 05 2016
    Montreal
    post #4
    Nov 15 2015
    Salt Lake City Utah
    I canít really tell in the pic. Lol
    Mar 05 2016
    Montreal
    That's the only pic I took before installing back the panel. The trick is, check all the clips, pod lights, speaker/twitters, make sure they're not moving freely. Use silicone or 3M double side tape to secure them.
    Nov 15 2015
    Salt Lake City Utah
    Thanks man. Iíve used so much sound deadening lol still the noise Iíll recheck everything tomorrow
    Mar 05 2016
    Montreal
    Sometime, you just need to use what ever laying around and it does just fine. No need fancy pant material😜
    Nov 15 2015
    Salt Lake City Utah
    haha it was laying around from when i did aftermarket front speakers
    Nov 15 2015
    Salt Lake City Utah
    I found the cause to the majority of the rattle. It was my Door regulator. I took it off and put some sound deadening and i think its gone. ill find out more tomorrow.
    Active Member One Ring darwandoo's Avatar
    Nov 17 2009
    2004 s4 b6
    Toronto, Ontario
    I'm
    Sent from my Pixel 2 XL using Audizine mobile app
