Results 1 to 15 of 15
    Feb 27 2019
    Los Angeles, CA
    Question Foam Cannon Recommendations
    I've never had one and wanted to try it out.
    TIA.
    Apr 11 2012
    This MTM one has been the best one Iíve used, but there are cheap ones on Amazon that work okay too. Depends on what you are looking for.
    Mar 26 2014
    Quote Originally Posted by will13k7 View Post
    So what makes a foam cannon like this one create more foam than an Amazon one?
    I currently have an amazon one and I am not too happy with it. I dont know if its the device, my pressure washer or if im not using enough soap.
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    I use the adams foam cannon it's good but i'm gonna upgrade to the MTM. the MTM is the one to have.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|
    |AWE Touring Exhaust|RS7 Airbox|FlatBottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|
    |S6 Oem Trunk Spoiler|RS Pedals|S6 Diffuser|RS6 CT3 Carbon Fiber|
    Apr 11 2012
    Quote Originally Posted by JVince View Post
    I currently have an amazon one and I am not too happy with it. I don't know if its the device, my pressure washer or if im not using enough soap.
    there's some matching of orifice size and the pressure of your pressure washer. some say that a higher gallons-per-minute makes the most difference. Matt from Obsessed Garage on YouTube has some videos where he's testing out a huge variety of pressure washers to find the right combinations, he might even have a found a good combination for your model already and is selling it on his site.
    I get shaving cream foam with almost anything I throw in. Just 1400 PSI, but with 2.1 GPM for my PW.
    May 08 2018
    Colorado
    FWIW, I wanted to buy the highly regarded MTM PF22 but, at the time in 2018, there was a 1.8 gpm requirement from the power washer. My Karcher K5 is a 2000psi / 1.4 gpm unit so I went for the Torq EQP322 Big Mouth instead. Very disappointing with almost no foam (at least with Gyeon Foam). Now the MTM is sold with different size orfices so low volume applications work. Bottom line, get the MTM as others have indicated.
    2018 RS5 - Nardo Gray
    Mar 26 2014
    Wow that's amazing foam!
    Thanks I'll have to check that out. I currently have the Karcher K5, I believe it has 2000 PSI. Hopefully it can produce that much foam as well.
    Senior Member Three Rings mikedizzzo's Avatar
    Nov 03 2016
    So Cal
    Are you using a electric pressure washer? If so, try replacing the orifice on the foam cannon to a 1.1 MM.
    -MikeDizzzo
    2016 S5 Premium Plus | Florett Silver | Black Optic Plus Package | DSG | ADS | Carbon Atlas | B&O
    Mods: GIAC Stage 2 | TCU | SC Pulley | Bilstein B16 Ride Control Coilovers | AWE Touring Exhaust 90mm | Maxton V1 Front Lip | 034 Transmission Insert | Brakes - Hawks Pro with slotted/dimpled rotors | Relak Paddle Shifters | Ceramic Pro 9H | LED interior | 2 x Audizine 5' stickers | Audi All Weather Mats
    Mar 26 2014
    Quote Originally Posted by mikedizzzo View Post
    Yes its electric. I'm using the Karcher k5 https://www.kaercher.com/ca/home-gar...-16033610.html
    Nov 03 2016
    So Cal
    I switched out orifice and man so much foam with my electric pressure washers. My pressure is 2030 psi too
    -MikeDizzzo
    Mar 26 2014
    Thanks, I'm going to try and find a 1.1 mm.
    Nov 03 2016
    So Cal
    If you picking up the MTM foam gun, the newer ones should come with the 1.1 mm oriface
    -MikeDizzzo
    Mar 26 2014
    Oh I just have a cheap one from Amazon that I want to make better.
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    The 1.1 orifice is on Amazon. <10 bucks I think.
    Nov 03 2016
    So Cal
    Then just buy the 1.1 oriface on amazon. You should be good then
    -MikeDizzzo
