Originally Posted by
Wkraus
You need to go between comfort and dynamic and it changes. I hate it does it too. Did it on my 18 rs3 and does it on my rs7. Unless you switch between comfort and dynamic or yes probably auto and then dynamic it won’t change. If you go to individual and have the engine sound service to dynamic they wont close and you won’t hear the change. If you start the car right after the initial rev up they close as it isles down. If you go to comfort and then back to dynamic or individual if that’s how you have it set I know it will change and you will be like what the F?! Or if you start the car and it was last in dynamic you’ll notice when you pull it into drive it’s just on D not S. If you bump it back to S you’ll hear the louder deeper sound. I too hate it about these cars. The only solution was custom code. They made the valves always closed in comfort and always open in dynamic BUt even they couldn’t get it to default that way at startup. Still had to cycle but was much louder with both always open. Unfortunately Audi thinks they still need to have one always moving depending on rpm to help with drone and sound so it did sound way different when they were coded always both open. Again that was on my rs3, I’m doing unitronic on my rs7 once the Russian downpipes arrive. I’ve asked john at uni if he can code the valves the same as custom code
MadAboutCars
Yes, definitely an issue in my 2018 RS6, as well. If you start the car in dynamic and then switch to individual (with dynamic exhaust set) it still doesn't open the valves. You have to go to comfort or auto and then back to dynamic or individual to open the valves. The other option is to go into sports mode on the trans. I wish this car had a button for the exhaust, like the R8 plus.
Thank you. you both confirm that this is not a problem, but just the design of the programming. Sucks. but ill take your recommendation to select comfort or auto drive select, then go back to individual. ill report back if it works and is the easier work around.
Valpo A7
There are a lot of parameters that get programmed into memory with the driver position. Have you tried setting everything where you want and then re-setting your driver position?
I have not. I didn't think anything of the drive select options are smart key coordinated. Thought it was only mirrors, seat, and steering wheel position
