Results 1 to 13 of 13
    Established Member Two Rings cshocker's Avatar
    Apr 18 2018
    Anoka, MN
    How long would you wait to install APR TCU tune after mechatronic replacement
    Had my mechatronic replaced last week. Now need to put my APR stage one ECU and TCU tunes back in. How many miles would you put on the new Mechatronic before programming? APR thought, but didn’t know for sure 500-1000 miles.
    Jul 14 2017
    Maine
    Quote Originally Posted by cshocker View Post
    Did the new unit fix your issues? What were your issues?
    2015 Audi S4 APR Ultra charger with Dual Pulley 3.18 ratio, APR DSG tune, AWE touring exhaust with resonated down pipes, Red Star Test Pipes, ECS intake, AWE Coldfront (all), H&R sway bars, ECS rear diff mounts, ECS Control Arm Brace, CR-15 Front Brace
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I think 500 would be a good break-in period. Did the new mech come with any kind of warranty?
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Apr 18 2018
    Anoka, MN
    Quote Originally Posted by scls4 View Post
    Kinda fixed issues. Lag when rolling stop is better. Lag between park and drive is shorter. It did have a hiccup when shifting under heavier acceleration, which hasn't happened again, but it seems like it might. And it was a lot worse with TCU tune, so when I get the tune put in, then I can really tell. Never had a code thrown.
    - - - Updated - - -
    Quote Originally Posted by Joker S4 View Post
    I had a indy transmission shop do the install in which they got mech and fluid and filters right from Audi dealer. So probably 12 month warranty
    2016 S3 stock-ish
    2017 Q7
    Mar 27 2019
    As soon as you tune it again, you’re probably gonna void that new warranty lol.
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Never heard of a transmission break in period. Mine would have already been tuned.
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Veteran Member Three Rings Corradobrit's Avatar
    Oct 27 2007
    TX
    Didn't notice much a difference with TCU tune on Stage 1. Returned it and went back to stock TCU file
    2014 S4 Premium Plus, Glacier White Metallic, Black Optics, DSG, sport diff, Nappa, B&O, AWE Touring/Res DP, GIAC ECU Stage 1, ECS CF rear diffuser, CR15
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Quote Originally Posted by Corradobrit View Post
    Thanks for your input?
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    Quote Originally Posted by Whitee View Post
    I stand corrected. Well played. However, OP might want to wait a little bit due to the warranty aspect. Or, just throw your tune back on there and enjoy the ride.
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    If the warranty is through an indy shop and not Audi I agree. I would have tuned it the moment I had time. If issues arise the shop probably can't see the flash counter.
    Apr 18 2018
    Anoka, MN
    Yeah I don't like waiting around and miss my tune. And I don't see a tune causing any damage to the mechatronic. Only "break-in" thing I'm wondering is the computer learning in the mech.
    2016 S3 stock-ish
    2017 Q7
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    I think it can learn the mech regardless, I would put back the tune asap
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Apr 18 2018
    Anoka, MN
    So I put my APR ECU tune back in. They were unable to put TCU in because of the new software in the new mech (APR will release an update eventually).
    Issue I'm having now is big clunk from 4-3 and when going from 2-1, slight delay and then it is fully engaged. Have to keep brake on hard or car will start moving. You can fell the car bog down when it gets into 1st. Wasn't doing that before the tune.
    2016 S3 stock-ish
    2017 Q7
