Page 1 of 12 12311 ... LastLast
Results 1 to 40 of 476
    Jul 21 2004
    South Florida
    The CWA100 upgraded supercharge coolant pump thread...everything CWA100...
    editing now to add pictures and formatting changes:
    I have finally gotten around to writing on this topic after people have shown interest. I want to thank Tecomotive.com for making the specs of these pumps so readily available to us all. The data they provide is available from Pierburg but tecomotive graciously makes this information easy to find and decipher on their site. They also make wiring harnesses available. Also please see this thread for a ton of info about these pumps:
    https://mbworld.org/forums/w211-amg/...now-about.html
    What is the CWA100?
    The stock supercharger coolant recirculation pump in our car is an extremely robust and powerful flowing pump, particularly at flowing against head pressure. The stock pump is a Pierburg CW50.
    That said as people add additional heat exchangers, killer chillers, or additional boost tgey may want increased circulation.
    Here are the specs of the stock Pierburg CWA50 and CWA100:
    As you can see the CWA100 almost doubles the flow of the CWA50. Looking at the technical documents, it also massively outflows the hobby style pumps such as the Varimax and Meziere style pumps when any head pressure is seen.
    CWA100-2 versus CWA100-3
    There are three different versions of the CWA100 pump but we will focus on the currently available versions, the CWA100-2 and the CWA100-3.
    First it should be known that as far as the specifications suggests, there are no flow differences at all between these pumps. They should both work identically. The only difference appears to be in the following:
    CWA 100-3 has slightly shorter water inlets and outlets.
    The connectors on the CWA100-2 and CWA100-3 are different.
    I have had both of these pumps.
    Here is the connector/socket for the CWA100-2:
    Here is the connector/socket of the CWA100-3:
    Availability of the CWA100 variants:
    -The CWA100-2 is an old AMG pump that was used in a ton of Mercedes Benz supercharged applications. The Mercedes Benz part number is: A0005000486
    You can source this part from a multitude of MB dealerships as a remanufactured item in the $300 to $350 range. FCP Euro has it currently for $342 and of course that is with a lifetime warranty. Tecomotive also has this available for 249Euro and you can buy the plug and play connector from them. They are a great site to support as well as they have been kind enough to publish most of the research you see here.
    -The CWA100-3 is a new VAG pump that is used overseas in the Audi Q7 4M hybrid. The VAG part number is: 4N0965567
    Interestingly you can find this pump from salvage cars on ebay for around $75. HOP ON THIS WHILE YOU CAN!
    Harnesses for each of these pumps?
    You can easily make a harness for each of these pumps.
    Here are the part numbers needed for the CWA100-2
    Connector to the CWA10-2 Pump: BMW part number: 12527549033 (available at ecstuning or fcp for under $5)
    Connector to the stock harness: TE Connectivity p/n 1-1703494-1 (available on arrow.com for $1.69)
    Here are the part numbers needed for the CWA100-3
    Connector to the CWA100-3 Pump: VAG part number: 4D0971993 (ebay for around $8)
    You should be able to make either of these harness for around $10-$15 or less.
    PIN Diagrams:
    CWA50
    CWA100-2
    CWA100-3
    2018 Audi S5
    Gone-
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    I have a CWA300 pump and harness from Tecomotive. If time allows, I’ll try to install this weekend on the SQ.
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Id seen this and thought it was a good deal with the used units out there, but I don't fully understand from looking at the numbers how it doubles the flow rate? Seems like a mild increase.
    Jul 21 2004
    South Florida
    Quote Originally Posted by theweebabyseamus View Post
    The ratings are at different pressure. If you equalize it, the difference is much greater
    Quote Originally Posted by bajan01 View Post
    That would be awesome to see your before and after temps too!
    2018 Audi S5
    Gone-
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    Mike you should do before and after iat numbers like you’re doing for the TBs... if you can get it same day and same starting iat would be a good comparison. I’ll probably do this now that it looks easy :) great work!
    Jan 11 2018
    Florida
    Quote Originally Posted by bhvrdr View Post
    Working on it. I took some data last weekend so if the temp/DA is similar this weekend I should have some good data to compare. Go big or go home and I’m hoping that this will help with what I have coming next.
    Jul 21 2004
    South Florida
    I'll update this with "after" performance numbers. I collected controlled condition baseline data but i've been waiting for mirror ambient conditions to collect the Post data
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Nice! Just ordered all I need for $139. You do this with bumper off or through wheelwell?
    Jul 21 2004
    South Florida
    wheel well. You can even do it with the wheel on but taking it off gives you some elbow room
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Perfect thanks man! If I can keep my iat below 60 that would be dope! On a 1/4 run now after sitting in the lanes I’m hitting 65-70 so 5C less and it’ll be money! Thanks again! If I knew it was that easy would of done it a long tome ago
    Jul 21 2004
    South Florida
    keep in mind we are still air to water heat exhangers. If you have no air flowing over the front hx then no matter how fast you pump water through it all you have is a metal heat sink sitting in front of your car. This will help reduce the rise in temps a tiny bit but its not a miracle :(
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Right agreed, but climb will be reduced as well overall 5C delta would make me happy. For instance now I have 20 delta at the track in the lanes etc 25. If I can change that at all I’d be happy. The meth helps to sa point but once too of third or in 4th that’s where most of the climb happens so a little help and I’ll be happy. Wish there was a way to keep or turn the fans on whenever I wanted...
    Jul 21 2004
    South Florida
    Quote Originally Posted by evil35r View Post
    Aeroforce technology guage controls fans
    https://www.audizine.com/forum/showt...auge-with-Podi
    2018 Audi S5
    Gone-
    Apr 16 2017
    Illinois
    Is there a "napkin math" way to know that the faster rate of flow will not be counterproductive?
    I'd imagine that shifting at peak power naturally has you shifting at like high 6k, so that should help offset temps. Temp increases seem exponential after high 5k RPMs, which is likely why Audi bled boost there.
    No point in going to higher RPMs unless you end up avoiding 1 shift or more during a timed event.
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
    Jul 21 2004
    South Florida
    Quote Originally Posted by Bartlett View Post
    These cars make power to redline.
    Plus you have gear torque. The lower gear puts down more power so staying in gear is beneficial. That said logging differences between shifting at 6300rpm vs a 7400rpm file showed maybe a tenth difference.
    2018 Audi S5
    Gone-
    Apr 16 2017
    Illinois
    I see. So then it's a matter of whether one persons's setup will benefit from the lower IATs @6300 vs @7400.
    Any thoughts on my flow rate question? I know that for folks with a Merc kit, especially with an added reservoir, this pump should do great. But, for a dual-pass kit with a reservoir?
    Mar 22 2016
    73 Jimmy 496 BBC
    I agree triple pass + this should help. Dual pass probably not as much. Can’t wsit to try it with the merc
    Jul 21 2004
    South Florida
    Ill let you do the math but it seems to suggest that higher flow is a good thing as long as you dont cavitate...
    http://www.gnttype.org/techarea/turbo/intercooler.html
    Mike
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Mike could you maybe take pics of or explain which wires to put in which pins or is it pretty straight forward?
    Jul 21 2004
    South Florida
    done
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Perfect! Ty
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Anyone have a link where I can find a used pump for under 200 bucks? Can't seem find one . PM me if you want.
    Jan 11 2018
    Florida
    Not quite, it’s more of a matter of how high you can go in rpm and not have timing pulled/boost bled because your IATs are too high. I took a log the other day starting around 2000rpm in 3rd and ran it through to the change to 5th (this is in my SQ, ZF8 trans). My IATs started at 33C and max was 57C. This was about 2 minutes after a 3rd gear run that started at 30C and maxed out at 53C. Ambient was 20C, redline is 7200rpm. I have seen logs that show much higher IATs than this and they are most certainly losing power. A good cooling system should keep your max IATs decent and also help in a quick recovery. After running out 3rd, my starting IATs were only a few degrees higher for my next run shortly after and this helps in such instances as back to back 1/4 mile runs. I will add that water/methanol injection helps quite a bit in reducing IATs. Having said that, cruising around on the highway my IATs are about 7-10C above ambient and at such times I’m not spraying water/methanol.
    Jan 11 2018
    Florida
    Mar 22 2016
    73 Jimmy 496 BBC
    Agreed with the above and a lot of tuners you really don’t start to see timing pull till 60-65C ish. So if I can keep mine below 65C on a staged strip run I’ll be happy. On the street I rarely see above 55-60
    Mar 22 2016
    73 Jimmy 496 BBC
    Some interesting charts I found
    [IMG] [/IMG]
    Senior Member Three Rings TristanT14's Avatar
    Sep 24 2017
    Totaled B8.5 Moonlight Blue S4
    Long Island
    So this helps with IATs and its cheap/easy to do?
    2014 Moonlight Blue Audi S4 Totaled
    Integrated Engineering DP Crackle
    2011 E93 Snapper Rock Blue Metallic BMW M3
    Instagram @DREAM3Y.M3
    Jul 21 2004
    South Florida
    Quote Originally Posted by TristanT14 View Post
    Preliminary data says maybe a few degrees c in improvement in a 0-120mph sprint. For some every degree counts
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Mike can you also add what pins etc are needed. I got one of the connectors todays and they don’t come with pins. Would 1.5MM male and female pins work or do they need to be 1.2MM?
    Jul 21 2004
    South Florida
    Here ya go..
    Cwa100-2 plug
    Stock female plug
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Stock harness plug
    967067-2 Wire seals (Newark.com)
    1718762-3 Pins (only ones I could find in stock) (Newark.com)
    Cwa100-3 plug
    000979141E Female pins and seals (amazon)
    18-20 gauge wire estimate 8-10” harness length with 3 different wires of different colors
    Not buying a crimp tool I’ll borrow one from work
    Mar 09 2018
    Pittsburgh
    Anyone else have luck finding these for not a ridiculous price? I'm looking all over with no luck.
    23 Q8
    21 Tesla Model 3 Performance
    Mar 22 2016
    73 Jimmy 496 BBC
    Just got a barley used one off eBay for $120
    Jan 11 2018
    Florida
    Fun times...going for a test run later tonight.
    https://www.tecomotive.com/en/index.html
    Mar 22 2016
    73 Jimmy 496 BBC
    Heck yea! Let us know!
    Mar 13 2013
    Chicago Western burbs, Il
    In for updates; also, tecomotive told me that they have not yet confirmed that PWM is working in the Audi B8.x 3.0 and the pump may just run at 100%. They believe it should be controlled by PWM but don't have evidence one way or the other, When you're testing can you see if logs indicate PWM? Thanks
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Jan 11 2018
    Florida
    Quote Originally Posted by tmoe View Post
    Yeah I need to test and post here and get back with Tecomotive. I will say that so far it seems to be cooling equally well compared to my 194/57 setup. I am now running a 203/57 setup. I really wanted to install the CWA100 pump first and test to compare to the CWA50 pump. In the end I didn’t want to put the car to service mode twice so I did the pump and 203mm crank ring together. Since I am seeing similar IATs at cruising as well as on 3rd or 4th gear pulls I can conclude that the CWA100 pump is flowing and therefore cooling better than he CWA50. More to come...tomorrow.
    Mar 27 2019
    Will this work on all 3.0T’s?
    Mar 20 2018
    Hanover, Maryland
    I wouldn't conclude better until you do WOT and watch recovery
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    I need a CWA100-3 Cable anyone can ship today?
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
