Page 12 of 12 FirstFirst ... 2101112
Results 441 to 476 of 476
  1. #441
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    The CWA100 upgraded supercharge coolant pump thread...everything CWA100...
    i bought this and it was shipped super fast, quality is factory or better. worked for my CWA100-3 swap.
    https://www.bmotorsports.com/shop/pr...oducts_id/4658
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
  2. #442
    Feb 16 2019
    miami, fl
    Quote Originally Posted by IHave2Turbos View Post
    ballenger is the go to for just about any car connector you need or pigtail or anything. they're legit.
  3. #443
    May 05 2018
    South Florida
    I just picked up a cwa100-3 off eBay and even though it looks like the ones I’ve seen on this thread/online I can’t cross reference any info to confirm it’s a cwa100-3.
    This is the info on mine
    Made in Germany
    7.09042.01.0
    24 T 037 01486
    4М0. 965.567
    VW AG
    PTG
  4. #444
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    It looks the part with that connector, etc, but the part number doesn’t line up. Thing is, I know of no other pump made by them that looks like that which aren’t CWA100-3. Maybe it’s a new part number for Audi. I doubt they’d make a CWA50 (flow wise) with the new connectors… makes no sense, unless they wanted to keep connections the same but flow less. The years and engine designations match up with what the other parts numbers would have worked with from Audi though.
  5. #445
    May 05 2018
    South Florida
    Yeah it’s physically identical to what I’ve been seeing online. Waiting for the pigtail and going to throw it in. I’m going to get some data before the swap to see if it made a difference.
  6. #446
    Aug 05 2013
    N/A
    Let me put it this way. If you can hear it and if you can feel a higher vibration on the hoses above the pump right behind the left headlight, then it’s a 100. Feel them with your original 50 so you can see what I’m taking about.
  7. #447
    Junior Member One Ring
    Jan 28 2022
    España
    Hola buenas tardes mi bomba cwa50 falló y quería comprar la bomba cwa100-3. Si quiero que funcione en modo normal sin cortar ningún cable tengo que cortar y cambiar la posición del cableado del arnés Audi para que funcione correctamente? Es para un s4 b8.5 año 2013.
  8. #448
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    Quote Originally Posted by Truper78 View Post
    Para no realizar cambios, necesita el arnés adaptador para convertir el enchufe cwa50 en cwa 100. Consulte publicaciones anteriores con esa información.
    Thank god for google translate lol
  9. #449
    Jan 28 2022
    España
    Yo tb Dios bendiga América que en España aprendemos mucho de vosotros x esta plataforma. Compraré el kit de tecomotive que ya viene con el arnés. Hoy hablé con Tobías y depende del modelo a veces el cableado del arnés es diferente posición al conector de la bomba cwa50. No quiero estar cortando y soldando cables tan solo llegar y conectar plug&play como decís vosotros. Nosotros decimos cosido y cantar jejeje
  10. #450
    Jan 04 2021
    CALI
    Con el kit tobias deberías tener una instalación fácil. buena suerte
  11. #451
    Aug 05 2013
    N/A
    DO NOT BUY from that ripoff artist shithead Tobias at Tecomotive!!!!! He will not stand behind the product and will flat out ghost you.
  12. #452
    Mar 18 2024
    Leeds
    hello i’m sure this might have been mentioned before, just fit a cwa100 with harness from merc racing.
    vcds scan
    P023B - Short to ground
    is this normal, i’m getting around 70 IAT when idle/low speeds going up to 90 at open throttle + the new hx is freezing cold
  13. #453
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Your IAT’s at idle are irrelevant. They’re going to rise no matter what. What are they when you’re cruising at highway speed?
    They should be at 20 above ambient at highway speed and about 30 above ambient at 30-40 MPH.
    Your heat exchanger and coolant pump is literally useless without airflow
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
  14. #454
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Quote Originally Posted by DustardCog View Post
    vcds scan
    If those #s are Celsius your that is not normal, and your pump is not working. I would double-check the wiring in the harness that came with the pump. Did you de-Pin the signal wire ?
    Sent from my SM-S928U1 using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
  15. #455
    Junior Member One Ring BRadMobile007's Avatar
    Feb 13 2022
    2024 Q5 Hybrid, 2009 Toyota 4Runner
    Quote Originally Posted by killer_s4 View Post
    Made in Germany
    7.09042.01.0
    24 T 037 01486
    4М0. 965.567
    VW AG
    PTG
    There are some images and specs at the beginning of this thread that might help you.
    2011 B8 S4 6MT, Lava Grey, 034 Stage 2 SP Tune, APR SC pulley/belt, P3 gauge, 034 Trans/Diff mounts, AWE Non-res DP + Touring Exhst, JXB Driveshaft Carrier, ECS Intake/Strut Tower/Chassis Brace/Billet X-Brace, EBC Slotted Rotors w/Red Stuff Pads, Rieger Bumper, Hartmann HLP-410-GS:M Wheels, H&R OE Sport Springs, gloss black RS style grill, rings and emblems, RSNAV 8.8" S4 touchscreen...more.
  16. #456
    Mar 31 2008
    eS-4
    CAL*SO
    Don't cwa100 or 150 come oem on some audis?
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
  17. #457
    May 20 2017
    New Hampshire
    It has 3 wires. Power, ground and PWM. Disconnect the PWM wire and it runs 100% all the time.
  18. #458
    Senior Member Four Rings
    Jun 08 2021
    PA
    It’s best to run the wire through an accessible switch. Winter time you want your pump to slow down. Running 100 percent in 10 degree weather on the highway especially if you have a heat exchanger will kill your fuel mileage. At least it did for me.
  19. #459
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by Fresh.S4 View Post
    8K0965567B
  20. #460
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    Quote Originally Posted by EvolutionArmory View Post
    Does this cause any codes?
    IE Stage 2 Dual Pulley, APR HX, APR 187 and 57mm pulleys, Milltek Resonated Exhaust, Deval CF Diffuser, 034 Lowering Springs, 034 Rear Sway Bar, Eurocode AK.
  21. #461
    Jun 08 2021
    PA
    8K0965567B
    This pump at fcp is significantly less than the cwa100 merc or others sell. Is there any reason to not just buy this pump instead? Any actual difference?
  22. #462
    Jun 09 2021
    WI
  23. #463
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by DrGrapeApe View Post
    interesting.. because the pump comes only on 4L v8's (audi and porsche).
    the other code i see coming up with the same 8k0965567 is 4n0965567
  24. #464
    Apr 14 2021
    Roanoke, Va
    Quote Originally Posted by STXA7 View Post
    from what i read you get a 'soft code' on list if u scan with vagcom , but it is not the type of code to trigger check engine light or alter engine behavior
    Thank you.
  25. #465
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    So i recently had a code pop up and saw this thread. Is this a sure sign the pump is done? I have not had any noticeable issues other than the code when i routinely checked.
    If so, where's best place to purchase the CWA-100 now?
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
  26. #466
    Mar 19 2004
    Vegas
    vcds scan
    Did you ever get this sorted and what was the issue if so?
    - - - Updated - - -
    Quote Originally Posted by RoofRails View Post
    Why would it need a de-pin with the harness?
    Cheers! David
  27. #467
    Mar 19 2004
    Vegas
    Just checking back on best place to order the cwa-100 from. Please advise for anyone that has purchased recently.
    Cheers! David
  28. #468
    Established Member Two Rings Ibuckfitches's Avatar
    Aug 20 2023
    Alberta
    Quote Originally Posted by Silence View Post
    Mercracing and Gas sells them I’m pretty sure. Also with the harness.
  29. #469
    Mar 19 2004
    Vegas
    got it. thank you
    Cheers! David
  30. #470
    Mar 19 2004
    Vegas
    Quick update - just installed pump and harness from Merc Racing and the previous P190D code went away, but i have a p190C code now for no signal, even though pump appears to be working fine.
    Is this normal and if so, any work around to have it go away?
    Cheers! David
  31. #471
    Mar 19 2004
    Vegas
    Anyone have this same code with the cwa-100 pump and harness?
    Cheers! David
  32. #472
    Apr 29 2018
    Fred
  33. #473
    Jan 04 2024
    Toronto, ON
    Hello,
    I ended up ordering the 4NO.965.567 directly from the dealer, as it is much easier (and cheaper) to get in Canada than a non-VAG CWA-100. This is what I received:
    It looks almost identical to what I saw at the start of the thread, but the part number on mine is 7.04934.14.0 vs 7.04934.54.0. I'd like to think that this is just because it's made for VAG vs generic but wanted to see if anyone else's looked like this.
  34. #474
    Jan 04 2024
    Toronto, ON
    Looking through the internet more, I found a reference to a 7.04934.04.0 being interchangeable with the 7.04934.54.0, so it is likely that the 14 is an updated or regionally different version of the 04.
    I'll install it and hope for the best, but wanted to share here in case more people end up with this pump.
  35. #475
    Established Member Two Rings bguild's Avatar
    Apr 30 2014
    Massachusetts
    Crew: can anyone here help me? I thought I had a dead CWA100, so I swapped back to a CWA50, yet the pump isn't working at all. Now I'm beginning to think it's wiring or a fuse or relay. Anyone know what fuse and relay wiring I need to be looking at? Is there any way to use ODIS to run a proper test cycle on this Auxiliary Coolant pump?
  36. #476
    Junior Member Two Rings STICK5's Avatar
    Mar 31 2022
    Quote Originally Posted by bguild View Post
    If you have VCDS you can do an output test for the aux water pump. It’ll ramp up 10%, 30%, 60% and so on. My first CWA-100 from Merc Racing died within a few months. I used a multimeter and ran the VCDS test while tapped onto the connector leads on the car side to verify it was the pump and not connection/fuse. With no warranty I wasn’t paying $500 twice so picked up a used CWA-100 from a Cayenne Turbo S that works fine (it doesn’t even inverse the signal like some people have had happen, but does throw soft code for communication). As far as fuses some people have had to upgrade to a higher fuse once they get to the CWA-150 which I believe is in the fuse box between the wipers and ECU.
