Results 1 to 20 of 20
    Veteran Member Three Rings 03redgti's Avatar
    Dec 20 2010
    lancaster, pa
    Clicking noise while turning left at slow speed.
    So my car has been making a clicking noise from the driver side front wheel for a long time now. Only when turning left at slow speeds..Pretty sure it started after installing my coilovers so maybe its possible something isn't tight? Both CV boots are in great shape.. Anyone else ever had this issue?
    2013 S4 | Glacier White | Chestnut Brown Interior 1/13 | Sport Diff | IE Stage 2 | IE Intake | JHM V2 Test Pipes | PLM V2 HE | Custom Magnaflow Exhaust | Solo-Werks S1 | Rohana RF-2 20x10 square | Continental DWS |
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Quote Originally Posted by 03redgti View Post
    Did you replace the bump stops when you put on the coils ? Most setups come with them but some don’t. Mine are crumbling and I have the same sound. Replacing them next week when I put my coilovers on.
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
    Dec 20 2010
    lancaster, pa
    Quote Originally Posted by DC Dawg View Post
    Yes the coils came with new bump stops all around..
    Dec 31 2018
    Chevy Chase MD
    As usual, my diagnosis of weird car noises is wrong.
    Dec 20 2010
    lancaster, pa
    hahaa yea they can be a pain to figure out..the car drives absolutely fine..its just annoying and I'd like to figure it out.
    Jun 05 2015
    a few interesting items
    Sounds like maybe an upper ball joint
    Sent from my LYA-L0C using Tapatalk
    Active Member Two Rings Rappydog's Avatar
    Jan 29 2014
    N.E. Florida
    Please update this thread when you get an idea of what is causing this. I have the same issue that started recently. The sound is coming from the left, front of the car. It sounds like a metal on metal "click" when you turn the wheel.
    Active Member Two Rings JBalls's Avatar
    Aug 26 2017
    Hong Kong/Vancouver
    Check tie rods, I had clicking sound from low speed turns from front right wheel area, my shop replaced them, took care of the noise.
    Audi S4 B8 | Ibis White | Magma | Carbon Atlas | B&O | Michelin Pilot Sport 4S | AG M590 | Bilstein | H&R
    Apr 02 2018
    I have a similar noise, only when cold. No suspension mods, under 30k miles.
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Is it this noise? If so it was my front axles, I replaced both with product from Raxles and it has been perfect since.
    https://youtu.be/Gx5oUJUP8Ks
    Sent from my SM-G975U1 using Tapatalk
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Apr 02 2018
    Mine isn't that.
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    My issue was wheel bearings when this happened with my car. A replacement fixed the issue and it hasn't returned in 5 years.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Junior Member Two Rings
    Jun 14 2018
    Conshohocken, PA
    Check lower control arm bushings.
    Sent from my Pixel 3 using Audizine mobile app
    2014 B8.5 s4 6MT Monsoon Gray Metallic/Black Optics/RS Grille/GIAC Stage 1/AWE Touring Exhaust & S-Flo Intake/H&R Sway Bars/Bilstein B16 PSS10
    Mar 09 2015
    Harrisonburg, Va
    Does it only click once? and when you straighten it up it doesn't seem to happen at the same place? but then when you turn the wheel back it happens again?
    Had this issue with lower front control arms being worn, replaced them and still had the issue.... turns out I didn't torque down the bolts to spec, tightening to "grunt noise level" isn't sufficient. ...and replace the bolts also.
    I've also heard of Alu Kruezs causing a similar issue from them being installed while the suspension was compressed.
    Mar 09 2015
    Harrisonburg, Va
    ANOTHER THOUGHT: How to rule out your control arms...
    Loosen the bolts for all the lowers, and see if you still have the noise.
    Veteran Member Three Rings mecheng's Avatar
    May 29 2013
    2017 Q7
    Toronto, Canada
    So I have a similar noise, it's a softened clunking at low speeds over certain bumps but not all. It used to be quite bad until I replaced my shot dampers with Bilstein B8's this past weekend (I'm lowered on H&R sports). I thought for sure that would resolve it - and it had for a bit - but after a few days of driving I can hear and feel it's still there, just not as pronounced.
    All my bushings are in good shape, the half-shaft boots are intact (didn't pull them back to take a look at the joint)...
    It's independent of steering angle, and it's driving me nuts.
    2013 S4 | Brilliant Black | Premium | Magma/Black | Carbon Atlas | 19" Rotors | 6 Speed | ADS | Sport Diff | Side Assist
    Previous:
    1. '82 911SC [sold]
    2. '11 WRX [murdered]
    3. '11 S4 [sold]
    4. '14 Fiat 500c Abarth [sold]
    5. '17 Q7 [Family Hauler]
    Established Member Two Rings bbrown14's Avatar
    Jan 19 2018
    Livermore, California
    I had a similar problem after some suspension work where I got my upper control arm bushings replaced. Check the subframe bolts, as if they arent torqued under full load they can loosen over time and cause that sound. This is just speculation however, and an unidentified "clicking" could really be alot of things within your suspension.
    2013 Glacier White S5 | 6MT | 034 Stage 1 | EuroCode SS |
    [SOLD] 2011 Phantom Black S4
    Dec 20 2010
    lancaster, pa
    Quote Originally Posted by Jroyalty7 View Post
    It actually does sound like that.. ugh i'm hoping something is just lose though or bad control arms/tie rods.
    Jan 10 2016
    Porsche Macan Turbo
    FL
    I think Raxles is a little more expensive but well worth it!!! And like I said no problems since.
    Check out this thread for more info
    https://r.tapatalk.com/shareLink?url...9&share_type=t
    Sep 28 2013
    B8S4, C300 4matic, Honda CR-V
    I had clicking noise in low speed near full turn to full turn either direction at 50k ish miles - I normally heard it when I was parking in an indoor garage. It ended up being failing upper control arm bushings due to lowered suspension.
    Noise went away as soon as upper control arms were replaced with SPC's.
    interior and license plate LED lights, E-code headlights with 6000k bulbs, AWE catback, H&R OE springs, APR Stage 2, 19" BBS RGR (summer), stock 18" with 15mm and 20mm spacers (winter), carbonio intake, lots of VAG mods, 35% tints all around, lots of road rash, 034 transmission mount insert, SPC ACS, Spulen rear diff mount, Bilstein sport shocks, CR-15 strut brace bar
