Today was an eventful day! This morning I finished up torquing the suspension and a couple other little odds and ends, then Tyler from Ward Performance Tuning came by and loaded a base map and we fired it up. It started on the first try and idled well. It was making a bit of lifter tick and the power steering pump was complaining. We let it idle for a few minutes, shut it down, and started it back up and the lifter tick was gone but the power steering pump is still making noise. We took it for a short drive and aside from having no power steering, the alignment being way off, and the suspension being a lot stiffer than I was expecting, it drove well.
I drove it about 20 km later this afternoon close to the house, varying the RPM and working the brakes / engine a bunch.
Initial thoughts:
- Brakes work well although I haven't stomped on them yet, but right out of the garage they had good pressure and feel confident. I don't even think I need to re-bleed them. Parking brake works perfectly too. Super happy with this aspect of the build.
- Suspension is stiff, and there was the odd clunk or two at the start as maybe the springs were settling on their perches. I may raise the car a bit, we'll see.
- I put the car back in the air and went lock-to-lock with the engine off, engine on, engine upside down and everything in between, and can't get what I'm assuming is a big air bubble out of the system. The pump is noisy and there's no power steering assist. I'll try again this week with more lock-to-lock in the air.
- Borla Exhaust sounds very nice. Although the low rpm fart the downpipes used to make with the stock exhaust is still there but not as bad.
- Engine hits about 6-7 psi nice and easy, pulls well under load and doesn't hesitate / hiccup at all. It feels like it wants to go.
- I feel a vibration in the driveline, probably the driveshaft since I fought that (driveshaft vibration) a while back. I might have to re-shim the centre bearing.
- I tried to switch from the AWE Poly DTS to the Rubber one, but the hole spacing on the rubber one doesn't align with the AWE aluminum bar holes. It's close, but the only way to make it work is to hog out the aluminum bar holes so I just deleted the mount for now. Drove it after and it was a bit smoother. More testing required, stay tuned.
- OIL LEAK! Everything was bone dry during the initial run, but after Tyler left and I did the longer drive, a drop of oil was sitting on the bell housing / engine interface, just under the RMS. I was just crushed, but I looked closer and it ran up the side of the engine to the top. It's actually coming from the turbo oil distribution tee-piece, one of the banjos. I was able to get a wrench on it and give it another 1/16th-ish of a turn, but it's tight back there. I'll keep an eye on it and hopefully that's that.
Next steps:
- Sort out the power steering
- Alignment
- At 50-75km I'll change the oil with new break in oil and filter. At about 300km I'll change it again with synthetic. At around 6-700km I'll get Tyler over for a re-tune to squeeze some power out of it.
I'm normally trigger happy with the camera but I only took this one! Obviously I'll photobomb the thread over the next few weeks
IMG_0626 by
barry.goss, on Flickr
And the oil leak:
IMG_0632 by
IMG_0636 by
