Page 11 of 11 FirstFirst ... 91011
Results 401 to 435 of 435
  1. #401
    Nov 21 2012
    BC
    Have you dynoed your car?
    Sent from my motorola one 5G ace using Tapatalk
    2000 S4 - Daily
    1989 MR2 Supercharged (Turboed)
  2. #402
    Veteran Member Three Rings q20v's Avatar
    Nov 12 2014
    2001 Audi A4, 2001 Audi S4, 1988 BMW 530i
    Ottawa, ON
    I have not... I might try and do that before the season is over though. I'll give the shop a call soon and see what their availability is like next week since I have a few days off.
    2001 Audi S4: OE K04 / E40 / 3.65s FATS / Maxpeeding Rods / SRM Intercoolers / Catless DPs + Borla Exhaust / 83mm MAF / 630cc Injectors / Walbro 450 / 2.0T Coils / B7RS4 Clutch + TTV Flywheel / 4:1 Diff Shims / Big Brakes / H&R Coilovers / 034 Rear Sway...
  3. #403
    Nov 12 2014
    Ottawa, ON
    Went to the dyno this week with my tuner Ward Performance Tuning. Check out the video for the results and my impressions!
    Stage 3 Dyno RESULTS
  4. #404
    Apr 07 2011
    Home of the mighty beaver
    not terrible for k04s.. what FATS you running?
  5. #405
    Nov 12 2014
    Ottawa, ON
    Lowest I have recorded was about 3.75, and subsequent runs stabilized around 3.8 - 3.9. (IAT would steadily increase).
    Thanks for your log with WMI, I’ll definitely install my kit this winter!
  6. #406
    May 10 2018
    MA
    What was humidity like?
    How much boost again?
    Curious to see how you choose to do the wmi
  7. #407
    May 01 2022
    Denver
    Awesome thread. I've read through the whole thing and watched most of your YouTube videos. I'm new to this platform so it's been very helpful to get a good visual on all these things.
    Regarding your injectors - I recommend rotating them. You want the injectors to spray directly onto the intake valves, which on the 2.7t are not directly below the injectors. The factory injectors, as well as the 298s, have an angled spray - what Bosch calls the 'gamma' angle. The gamma angle of the 298s very closely match the factory injectors, but the angle is not in the same position relative to the electrical connector. Check out this video of how the spray is clocked relative to the connector: https://youtu.be/bkcmMEEL_ps?t=13
    You want to rotate your injectors 90º from how they are installed in this picture:
    This should make a good difference to throttle transients. I'm surprised your tuner didn't mention anything about it.
  8. #408
    Apr 07 2011
    the trouble is the connector does not clear the valve cover in that position.
  9. #409
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Barry's 2001 B5 S4 Build Thread
    Quote Originally Posted by S4James View Post
    I never ran stock injectors to know but my EV14/550s will. The adapters is what makes em not clear but if you were to hardware the EV14 connectors or run one of my injector harnesses they will clear that way. It’s tight and hard to see but there is clearance between connector and VC
    I did not know the spray pattern was like that so from here on out I’ll be putting them that way.
    Thanks for the tip Tightmoped!!
  10. #410
    May 10 2018
    MA
    This is the biggest issue with the generic “EV14” - you don’t really know what you’re getting. They clearly work, clearly can be tuned for, but they all run the risk of being very different to one another, whether it’s how they were “cut” or what the angle is, and potentially less than ideal which leaves who-knows on the table.
  11. #411
    Nov 12 2014
    Ottawa, ON
    Thanks for the feedback, greatly appreciated and good to know you found it helpful!
    And thanks for the tip on the injectors. I was poking around under the hood yesterday and it looks tight to rotate them. This winter I'm upgrading fuel pump / regulator / adding a flex sensor so that I can run 94 / E85 to get ~E40. My current injectors are at about 65% DC so I "should" have room... but in light of the above I may investigate injector options too.
  12. #412
    May 10 2018
    MA
    Quote Originally Posted by q20v View Post
    A sensor as in a gauge to monitor E content? A flex sensor implies running flex fuel, and switching pump to E and all blends in between with the ecu adjusting
    You’ll need considerably larger injectors, E makes for a very thirsty car.
  13. #413
    Nov 12 2014
    Ottawa, ON
    This is the sensor (or something equivalent) is what I was looking at:
    https://burgertuning.com/products/fl...41178794688686
    Plan was to figure out a mix ratio (ie 40% 94, 60% E85) to get E40 (or thereabouts) and have it tuned once for that mix. I'd have to be diligent to get the ratio correct on each subsequent fill.
  14. #414
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    FWIW-
    Check out the Injector Dynamics injectors---YES they're expensive but well worth the money
    I run the 1050X PN 1050.60.14.14.6 and needed 10mm spacers on both the fuel rail (OE) and Y-pipe.
    They make an injector that requires NO spacer but I lost that part number(found that out AFTER my build)
  15. #415
    May 10 2018
    MA
    Quote Originally Posted by LJS View Post
    FWIW-
    Second this - I got them in part because of your suggestion, and did the ones that needed no spacer (VR6). They are in my build thread I think.
  16. #416
    Nov 12 2014
    Ottawa, ON
    Awesome guys, thanks for the info!
  17. #417
    Apr 08 2013
    Connecticut
    Here's the injector PN RMode was referring to---48mm units, 1050.48.14.14B
    From-
    https://www.audizine.com/forum/showt...-Journey/page2
    entry No. 58
  18. #418
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Your tuner for sure has some room to turn it up. I was running 3.0-3.1 FATS on 93 + meth. That was 410awhp on AWE's mustang dyno.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
  19. #419
    May 10 2018
    MA
    Quote Originally Posted by CELison View Post
    Without a doubt there’s a bunch left on the table given that IDC. A good thing to have. I think I was around 2.9 FATS with just pump gas, nothing else, and 22 ish psi peak.
    I’ve still yet to find a pump source for E85 here smh. Just doesn’t seem common.
  20. #420
    May 01 2022
    Denver
    Quote Originally Posted by RMode View Post
    What are you talking about? You know exactly what you're getting because they are made by Bosch and you can find an exact specification sheet for the part number you get. I would make the exact opposite argument in that you don't know what you're getting when you get modified injectors.
    If you're only at 65% IDC now then you'll be fine running E40. E85 requires 30% more fuel, so even with E85 you'd be fine. EV14 injectors are much more robust than earlier injectors and I've found no long term issues running them up to 95% IDC. I don't remember seeing you mention upgrading your FPR, but if you bumped up the base fuel pressure to 4 bar you'd get ~724cc from your injectors and have that much more headroom.
    FWIW-
    If you want to upgrade injectors DeatschWerks makes injectors just as high of quality for less than half the price. I have a wholesale account with them, so if you do want a set DM me and I can get you a discount.
  21. #421
    May 10 2018
    MA
    Quote Originally Posted by Tightmopedman9 View Post
    Except they aren’t really “made by” Bosch at the bigger sizes. Common misconception because they often come in Bosch boxes. I forget the max size they make, but from there most firms modify the base injector to get the displacement they want. But none then have the “correct” spray pattern. This car uses a somewhat unique pattern. They all will
    work, but to varying degrees of smoothness. Especially cold start; idle. Some setups/climates/fuel (like E) this becomes more important than others. ID is the only one in the world that have Bosch make them an injector, so then you do know exactly what you’re getting. There are OEM’s now using ID’s. Their price reflects this though. This would stray way off course, but as someone who’s tuned many, many standalones of my own, from cheap to super expensive, for nearly 30 years, DW and ID aren’t in the same ballpark. Ive actually never tuned an ME7, but I’m sure those that do would have their favorites and least favorites. The concepts remain the same. It’s a matter of manipulating the software to run the hardware. I’ve used DW stuff plenty of times of course. For a time, it was almost the only quickly accessible thing. But it’s not the same level of product. Which is why they aren’t sold at the same price point. Tons of documentation out there for anyone ever curious. Some of it gets into minutia though. There was actually a good (but LONG) podcast episode on HP Academy on injectors. They’ve generally got lots of good content that goes superficial for a quick overview and then very detailed, depending on the topic. Good for the nerd stuff.
  22. #422
    Nov 13 2018
    Ocean city NJ
    +2 on IDs>DeatschWerks. You definitely get what you pay for and money well spent.
  23. #423
    Jan 25 2011
    Finland
    Read the whole thread. Very inspirational and like the attention to detail. Just a question when you powder coated the oil pan, it seemed the inside of the oil pan was also powder coated. Arent you afraid the powder coating coming off and blocking the oil pick up for instance?
  24. #424
    Jan 11 2008
    Estonia
    This is not possible.
    It was 3.97 according to this post.
  25. #425
    May 10 2018
    MA
    Quote Originally Posted by s4rmm View Post
    Typo :) the graph is correct
  26. #426
    Nov 12 2014
    Ottawa, ON
    Hey Krister, thanks for the kind words! Glad you enjoyed the read. Just to confirm, the inside was not powder coated, just the outside. You have no idea how much multi-purpose cleaner I went through for this build!
  27. #427
    Veteran Member Four Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    Long Island NY & Kent OH
    Hey Barry, I was browsing some videos on PB garage and I don't think I saw the Cactus b5 A4 in any of the videos. Do you guys have any clips or videos of it? I been curious about it.
    Garage: b5 s4 silver stg3 f21s
    RIP Daz 4/14/16. Legend.
  28. #428
    Nov 12 2014
    Ottawa, ON
    Hey everyone,
    Time for a bit of an update. I'll try to capture some of the changes since last year.
    Around June 2023 I made changes to the car to support E40 (I mix about 20-25L of 94 octane and ~15L of E85 or E99, depending on where I get the Ethanol)
    - Walbro 450 fuel pump and relay kit
    - 722017500 PIERBURG fuel pressure regulator (larger orifice)
    - Innovate ECF-1 - Ethanol / Fuel Pressure and Temperature / Lambda Sensor and Gauge
    - Updated 3D printed gauge pod for the new gauge
    My tuner street tuned the car and I've been driving it without any issues. Definitely feels faster, I think he said he added about 7 degrees of timing, mostly at the higher RPM range.
    I returned to the dyno late April this year and unfortunately all the runs had timing pulled by the ECU, intake temps were higher than usual. Best numbers were 397hp / 417 lbft. On the street we don't get the timing pull, so likely an airflow issue with the dyno fans? I'm happy with the cars performance but do still have the AEM WMI kit sitting here, so I may eventually get around to installing that if I decide to return to the dyno, but no rush. Street FATS are mid 3.5s.
    I'm at about 10k KM on the rebuild and just enjoy driving the car, usually to work once a week and on weekends. My A/C stopped working so that's the only thing on my plate this year for the car.
    Here are some of the components I installed:
    IMG_7821
    Sensor installed:
    IMG_7847
    FPR:
    IMG_7830
    Pump gas 94 octane only:
    IMG_8001
    E40 (just over):
    IMG_8119
    Dyno:
    IMG_0746
    My dyno compared to a 2.7t Stage 2 (upgraded injectors and DVs) same day back to back:
    IMG_0741
    IMG_0725
    The Stage 2 (Braydon from a local shop, Rodgers Performance)
    IMG_0737
    Couple other little things in the past year...
    Badge before:
    IMG_0463
    After:
    IMG_0464
    This fitting broke, and I needed to use the car so I quickly fab'ed up a repair:
    IMG_7825
    IMG_7849
    Got some new exhaust mounts that I have yet to install:
    IMG_6685
    Dyno video:
    Diff mount mod:
  29. #429
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    Such a great build, and attention to detail. Along with great info, so glad to see there are other people that are still crazy enough to bring these cars back to glory. Awesome job!!!
  30. #430
    Nov 21 2012
    BC
    Hey everyone,
    IMG_7821
    Sensor installed:
    IMG_7847
    FPR:
    IMG_7830
    IMG_8001
    E40 (just over):
    IMG_8119
    Dyno:
    IMG_0746
    IMG_0741
    IMG_0725
    IMG_0737
    Badge before:
    IMG_0463
    After:
    IMG_0464
    IMG_7825
    IMG_7849
    IMG_6685
    Dyno video:
    Diff mount mod:
    Any feedback on the fuel pressure regulator?
    2000 S4 - Daily
  31. #431
    Nov 12 2014
    Ottawa, ON
    Quote Originally Posted by Tec_Nine View Post
    Thanks! With everything I've done and invested into this car, it drives like new and performs great. Still fairly unassuming out on the street, doesn't attract much attention. If I ever came across some serious money, the 1 thing I'd do is convert the body work to RS4. That's only recently motivated by my brother recently procuring a B7 RS4 Avant. It would be nice to have something truly unique.
  32. #432
    Nov 12 2014
    Ottawa, ON
    Seems to work well, at least my tuner hasn't complained about anything related to fuel supply. Installation was the same as stock, simply remove and replace.
  33. #433
    Nov 21 2012
    BC
    Were you worried about a restriction causing an overly rich condition with the larger pump?
    2000 S4 - Daily
  34. #434
    Nov 12 2014
    Ottawa, ON
    Quote Originally Posted by oasis View Post
    Yes, correct, in my research online I found anecdotal reports of odd issues using the Walbro 450 and stock FPR, but also some with no issues at all. I didn't want to go down the route of an adjustable FPR (GFB is a popular one), thinking it might be overkill (especially $$), so I thought this would be a good compromise.
  35. #435
    Veteran Member Three Rings mjmatos's Avatar
    Apr 29 2014
    Long Island, NY
    Interesting discovery, I opted to upgrade my N75 to the pierburg unit, I’ll have to do some research on the new FPR as well as I’ve been wanting to replace for peace of mind
    Current
    2001 B5 S4 Sil | ASP Stg 3 | RS6 K04 | Rosten Rods | AWE SMIC| RS4 Engine and Trans Mounts | AMD Stg 3+ | CM SMFW | StopTECH BBK | ASP DP + Exhaust | Tein SS Coilovers
    2001 B5 S4 BB | Blake tuned | E85 | SRM K24 Hybrid | SRM v3 IC | Full SSAC DP + Exhaust | 034 Motor Mounts | CM FX400 | 17z BBK | BC Coils | Wallbro 450
    R.I.P
    2005 B6 A4 1.8TQM | REVO Stg 2| RNS-E | B7 S4 Brakes | ST Coilovers
    2001.5 B5 A4 1.8TQM | Stg 3 | GTRS Elim | Meth
