Page 4 of 4 FirstFirst ... 234
Results 121 to 142 of 142
  1. #121
    Sep 28 2019
    Ohio
    ^ Good to know, by chance do you have a part number for the "shorter" Bilstein B8's?
  2. #122
    Nov 11 2013
    2014 Nissan 370z , 2010 APR K04 GTI (SOLD!)
    OC/CA
    Quote Originally Posted by MK_TT View Post
    https://www.shockwarehouse.com/site/...Rear-24-145992
    they should be 24-145992 rears
  3. #123
    Established Member Two Rings Digitaldub's Avatar
    Apr 29 2010
    Toronto, Ontario, Canada
    Quote Originally Posted by Das Ponto View Post
    H&R sport springs with oem shocks.
    It's been great.
    A lot of the issues people had previously were in correct springs from H&R when they were first released.
    No reverse rake, actually wish the rears were a hair lower. This was right afyering switching to summer rubber.
    And winter mode
    Great looking AR Das Ponto! Running the H&R's with OEM shocks, were you able to do a correct alignment? Or are you cambered, and if so what has your experience been with uneven tire wear? Thanks
  4. #124
    Nov 11 2013
    OC/CA
    BILSTEING B8 SPORT INSTALL..........FAIL.
    no effect.
    finally grabbed a set of rear bilstein B8 sprots dampers #24-145992, a good 3/4 inch shorter dimensionally than the KONI yellows I had on ..... installed, dropped and ..... NO CHANGE REAR RAKE
    these H&R sport springs, MADE FOR THE F*CKING ALLROAD supposedly ...... DO NOT FIT/WORK aesthetically, PERIOD. I cant put in to words how pissed off this has me, after weeks and weeks of research and "troubleshooting" their sh*t calculations, which were clearly WRONG for the allroads.
    with the new H&R sports and KONI yellows - one week after install ..... HIDEOUS RAKE.
    finally got the B8 Sports on , and ...... NO CHANGE ...in fact, it might actually be WORSE by like 1/8 inch \
    im pretty much lost at this point .... the H&R' sports supposedly made for the allroad simply DO NOT FIT CORRECTLY , period. Going to try one last thing -- finding a set of SEDAN/S4 H&R sports .... if that ends up just being more f*cking me over, just start saving for proper coilovers.... i cant even orate how much I hate this look right now.
  5. #125
    Sep 28 2019
    Ohio
    Following.
  6. #126
    Nov 11 2013
    OC/CA
    so no surprise, H&R was of ZERO help or assistance at all .... only offered to test my springs up against their stock test springs in their lab , on MY dime (removing springs, shipping them to H&R in Washington ) ...
    so I'm just going to save for a proper set of coil-overs or a true H.A.S. kit in the spring (tax time!) .... in the interim, I simply can not stand to even LOOK at my cars hideous stance now -- so I'm putting the Stassis springs back on out back , even though they sank soooo low - Ill mate them with with the Audi ADS spring pad/spacer (13mm) .... hopefully this will keep it "Even keeled" until I can slap a real system in it ....
  7. #127
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by ROOSTER1050 View Post
    What are your front/rear FTG measurements?
  8. #128
    Nov 11 2013
    OC/CA
    Quote Originally Posted by JLAllroad View Post
    **when I was on the Stassis springs (ans KONI yellows - 4 corners)
    -driver front - 26 1/4
    -driver rear - 26 1/4
    -pssngr front - 26 1/8
    -pssngr rear - 26 --
    **when I put on the H&R sports (still koni yellows 4 corners)
    -driver front - 26 2/5
    -driver rear - 27 1/2
    -pssngr rear - 27 1/8
    **when I swapped Bilstein B8 sport dampers in rear for the koni yellows
    - driver front - 26 1/4
    - driver rear - 27 3/4
    - pssngr frnt - 26 1/4
    - pssngr rear - 27 5/8
    I seriously want to puke everytime I walk up to my car .....cant stand looking at it RN
  9. #129
    Nov 11 2013
    OC/CA
    FIXED!!!!! more or less ....
    FIXED the H&R hideous rear-rake and gap , FINALLY ...... complete "franken-suspension" now, LOL ...going to settle on this until I buy coil-overs in the spring....
    removed the H&R sports in the REAR - swapped the old STASSIS Engineering springs back in .... left the gas-charged Bilstein B8 performance plus dampers in (they tend to "push up" a bit more, even through they're shorter dimensionally) .... used the Audi extended spring-PAD , 13mm buffer ....
    pre swap -- still with the riduculous gap and height in the rear
    swapped in the old Stassis springs (REAR only) , left the bilstein B8's in , and with the 13mm extended spring pad --- it fell back into the "proper" height and gap
    end result -- MUCH, MUCH more in-line with the overall ride height and look .... should settle down another 1/8 inch or so as those pads dig in ...
    [IMG]The H&R fix by RS T, on Flickr[/IMG]
    quick surf at lunch - drove around a bit on the way home, couple RR x-ings, a bump or two and a couple loaded right turns at speed -- and it's settled back down to near perfect now --- all hail the "FRANKEN-SUSPENSION"
  10. #130
    Veteran Member Three Rings skifreak85353's Avatar
    Sep 23 2015
    Arlington, VA
    I think I have the opposite issue as most.
    I want to lift my rear to match my front. Have avant s line springs in place right now and have had them for some time, just now getting around to this. Thinking the spring plate may be my best option?
    Front FTG
    Rear FTG
    ____________________
    2014 Audi Allroad Prem+ Moonlight Blue | Neuspeed Power Module | 19" S5 Rotors + 10mm H+R spacers + PS2's | 19" S4 Peelers anthracite + 25mm/30mm H+R spacers + Blizzaks | Stasis RSB | Alu Kreuz | Avant S-Line springs | 20% tint | Vag Com mods | RSNav CarPlay
    2009 Volvo XC90 V8 R-Design
    2013 Subaru WRX Limited (Satin White Pearl) - Gone but not forgotten
    The Instagram the_radifier
  11. #131
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by skifreak85353 View Post
    Front FTG
    Rear FTG
    My understanding is the Allroad front shock bodies are about an inch longer than that of an A/S 4/5, this changes the spring perch height and hence the front ride height.
    I know it’s subjective, but 26.5”-27” is a great no compromise height, this give very similar ground clearance as a stock A4 Sline.
  12. #132
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Quote Originally Posted by Digitaldub View Post
    Wowo I definitely missed this haha... Alignment was done post lowering (as it should always be done). No additional camber required at that height and thus tire wear was great. I've moved on to a B9.5 allroad now, but love how detailed this thread has gotten - such a good resource!
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
  13. #133
    Established Member Two Rings 2002allroad's Avatar
    Dec 30 2007
    Chicago area
    So I looked through this post and I'm still confused. I'm looking to replace my solowerks coilovers on my 2013 allroad this summer with just shocks and lower springs. Looking at H&R springs with stock bilstein replacement shocks. Is this the way to go? Not looking for slammed look but about 27" FTG.
    2013 AR premium plus sports package, silver with matching fenders, 20% tint, Carbon vinyl wrapped interior trim, Dynamic side turn signals
    solowerks coilovers w/KW 30mm spacers rear, Niche M179 Verona 20x9 et25, 255/35/20, (winter) stock 18's with Blizzak w/15mm spacers, 10.25 Android (non Rsnav), wireless CarPlay
  14. #134
    Senior Member Two Rings Lizard 1's Avatar
    Jan 26 2016
    Lots of fun stuff
    Gahanna, OH
    Great thread and sorry a lot of you had to deal with issues... I am using Koni yellows with H&R springs. The previous owner had them installed and trying to get the formula as to what he used exactly and will post details. But, I am VERY happy with the stance and with the 20" wheels, makes me giddy... Rides amazingly well also.
  15. #135
    Junior Member Two Rings
    Dec 01 2021
    BROOKLYN
    Quote Originally Posted by Lizard 1 View Post
    Nice drop!any part number for sharing.
  16. #136
    Sep 23 2015
    Arlington, VA
    Quote Originally Posted by MacRoadie View Post
    Original:
    With Bilstein dampers and H&R springs:
    With Eibachs swapped in for H&R's:
    Mac - what size tires in these photos?
  17. #137
    Sep 23 2015
    Arlington, VA
    Or for anyone listening who may have the right guidance - I’m trying to land at 28” FTG or right around the and am running 255/40 19 tires. I’d even be ok with the rear a little higher in the front for the same reasons Mac originally mentioned.
    Wondering if his set up is the move, or if I should just go coilovers.
  18. #138
    Sep 23 2015
    Arlington, VA
    Closing the loop on the setup I went with.
    Bilstein B4’s up front (19-226859)
    Bilstein B6’s out back (24-145978)
    H&R Sport Springs (28969-1)
    In the five miles back from the shop I am wonderfully pleased.
    FTG:
    Front - 27.5”
    Rear - 27.75”
    Note I am on 255/40 19 tires.
    We’ll see if the springs settle in any more.
    Ever so slight rake (rear higher than front) but I’m cool with that. After all, I’m just a guy with a wife, two kids, a dog, and lots of bikes and skis to bring the back down level.
  19. #139
    Established Member Three Rings adm750's Avatar
    Aug 16 2023
    2016 A4 Allroad, 08 BMW X5 3.0, 06 Grand Marquis
    Fekkin all over !
    holy cow...sub'd..!
    I recently acquired a 2016 Allroad and definitely would like to lower it at some point. Update the wheels too....
  20. #140
    Junior Member One Ring
    Oct 03 2022
    Arizona
    Bumping this old thread just got an allroad
  21. #141
    Oct 03 2022
    Arizona
    Original:
    Macroadie if you’re still around do you remember what the part number was for the eibachs springs ? Were the same that come with the b12 kit ? If so are the sedan or avant- specs springs ?
  22. #142
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2013 B8.5 allroad (current) 2007 b7 a4 (previous) 2006 vw touareg (previous) 2003 b6 a4 (previous)
    Ummm the Jersey Shore
    Quote Originally Posted by Stormgray0131 View Post
    I also want this ride height and would like to confirm part numbers.
    Miss my B6
