I understand there are different components built into the system. My question is really how the car behaves once you turn ESC to sport or turn it off completely.
There's Electronic Stability Control (ESC) to prevent skidding helps keep the car straight under heavy braking. I'm also aware that it can pull power as well as apply brakes.
Then there is Electronic Differential Lock (EDL) that simulates an LSD and finally XDS which can react to the unloading of the front wheel on the inside corner or some say both inside wheels to help produce a slingshot exiting effect.
What happens to those features as we goto sport and off modes. Does it simply disable the throttle intervention or if it also reduces the torque vectoring of the car.
