    Feb 19 2007
    Dealership only source?
    I need second Key Fob so is dealer only place to get one with programming??
    Senior Member Three Rings j23a45m's Avatar
    Feb 07 2018
    19’ Qx60, 16' s1000rr, 15’ S4, 12' X5, 10' A3
    Lacaster, Pa
    Some locksmiths have the programming tool. Call around your area and check pricing!
    [B]'15 S4 - Sepang Blue|DSG|Sport Differential|MMI|B&O Side Assist|ECS Trans Mount|ECS F/R Diff Mount|MercRacing Hx/ Divorce kit|AWE Touring Exhaust 102mm|Apr Open Carbon Fiber Intake|Iabed 82mm throttle body |35% Tint|3000k Fog LED's|OBD Eleven Mods|Macan 4-piston brembo calipers|Unitronic Stage3 Ecu/ stage 2 Tcu|Custom clear lense and painted Headlights|Ecs carbon lip and rear diffuser|Airlift 3P/H| 10.25 Rsnav|034 Track/Street density/ Sway bar| [/CB]
    Feb 19 2007
    Ok thanks but how about the fob/key itself? Any good aftermarket key fobs to be found?
    Feb 07 2018
    Lacaster, Pa
    Quote Originally Posted by jdevoid View Post
    Again call and ask pricing for a total solution, usually they won’t reprogram a used key! If I’m not mistaken a few models you can’t even do so!
    Veteran Member Three Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    Find a company like this one - ekeys4cars.com
