Results 1 to 4 of 4
    Established Member Two Rings jeffreyk's Avatar
    May 26 2011
    British Columbia Canada
    Up sizing throttle body - Re tune?
    Hi,
    I hope the more technical people in the forum can help me out... I think I know the answer but I need to confirm...
    So I have an APR Ultracharger and dual pulleys installed on my car with the appropriate APR II+ tune.
    The throttle body is giving me grief and I need to replace it. See my other thread. https://www.audizine.com/forum/showt...-Throttle-Body
    If I swap my 80mm APR throttle body for a 'ported' or 'bored' 85mm throttled body, which flows more air per same amount of throttle position, would it required a re-tune?
    I think the answer is yes.
    My thinking is: The ECU should base the fuelling and timing and based on the throttle position right, manifold air pressure and temp? We don't have a MAF to tell the ECU air going in right?
    OR..... can the computer sort this out based on the O2 sensors? or other sensors?
    Who does custom tunes for things like this?
    Jeff
    2010 B8 S4 6 speed / ADS / APR Stage 2+ / Mercracing Cooler / Ported Charger / Stasis-Ohlins / Eurocode Sway Bars
    SOLD - 2000 B5 S4 6 speed / Black on Black & Grey Alacantra / K04 / VND Tune / ER SMIC / Stasis Tracksport / VMR 701 18x9.5 / Michelin PSS
    Established Member Two Rings BlueSteW8's Avatar
    Apr 24 2011
    Supercharger Heaven USA
    If I were in your position, I would try to get the car running right before trying a larger TB.
    That being said, I believe you shouldn't need a retune on the APR UC file.
    Is there an APR dealer close by?
    Maybe start there.
    May 26 2011
    Quote Originally Posted by BlueSteW8 View Post
    Maybe start there.
    Yes... probably wise words. I will make it run first.
    It’s always so tempting to ‘upgrade’ if at all possible. Lol.
    I contact APR and they asked me to double check the wiring harness. I will do that tonight.
    Jeff
    Veteran Member Three Rings englishbay's Avatar
    Sep 30 2009
    Vancouver, Canada
    Does anyone know what's expected if you do swap the APR Ultracharger throttle body to a larger one? There are lots of threads on doing this but little on what the impact is with just this change alone will do.
    B8.5 S4 DSG | APR UC/TCU | APR Intercooler System | APR Intake | Bilstein PSS10s | Ethanol Sensor
