Hi,
I hope the more technical people in the forum can help me out... I think I know the answer but I need to confirm...
So I have an APR Ultracharger and dual pulleys installed on my car with the appropriate APR II+ tune.
The throttle body is giving me grief and I need to replace it. See my other thread. https://www.audizine.com/forum/showt...-Throttle-Body
If I swap my 80mm APR throttle body for a 'ported' or 'bored' 85mm throttled body, which flows more air per same amount of throttle position, would it required a re-tune?
I think the answer is yes.
My thinking is: The ECU should base the fuelling and timing and based on the throttle position right, manifold air pressure and temp? We don't have a MAF to tell the ECU air going in right?
OR..... can the computer sort this out based on the O2 sensors? or other sensors?
Who does custom tunes for things like this?
Thanks
Jeff
