Results 1 to 13 of 13
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    ZF 6HP19 - ATF - Valvoline Maxlife Multivehicle
    Is the 6HP any different regarding ATF than the 5HP?
    I (and a lot of others, including big tranny shops in our area) have been using the Valvoline MaxLife Multivehicle ATF for the 5HP car (Audi, BMW, etc) for decades.
    I am changing fluid on my B7 tranny tomorrow, and plan to use again the Valvoline based on the success with the 5HP trannies (5HP19, 5HP24).
    What is the word out there (aside from the "only use Audi labeled fluid (made by someone else and same stuff just for 3x the price)" regarding alternative fluids for the 6HP?
    Haven't checked bimmer forum et al. And now the 6HP is maybe used in domestic cars (pretty sure the indy trans shops don't put Audi fluid into those)?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    May 20 2010
    I changed my B7's transmission fluid the first time with OE Audi fluid (ZF's Lifeguard 6 at the time). 2nd time, I had Lifeguard 8 (which is supposed to be compatible) and had a shop do it; it was terrible. Shifts were jerky; I could feel it slipping, etc. Brought it back and they did a complete drain and fill (3x IIRC) with Redline D4 and it was great.
    TL;DR: Haven't used the Valvoline, but have used Redline D4 to great success. Be sure to do several drain and fills to completely remove the original fluid.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Feb 20 2010
    Brighton, MI
    Officially, ZF specifies their Lifeguard 8 for the 6HP "A) (quattro I pressume) in Audi, but Lifeguard 6 in BMW (RWD).
    Valvoline rates their MaxLife as a suitable replacement/mix for Lifeguard 8 (and various BMW, Mercedes and Volkswagen specs).
    For the 5HP trannies, they specify Lifeguard 5.
    So I guess it is a good fit for the 6HP.
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Hmh. Strange since they specify Lifeguard 8 now for the Audi (but still 6 for the bimmer; same tranny; assume 8 because of quattro?).
    I will drop pan and change gasket, filter and fill with the Maxlife (mix with the fluid that is in the car; assume original). See how it goes.
    05 Golf TDI
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by vtraudt View Post
    They split it during the B7 years, you need a TCM update to run the ZF8 fluid properly.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by Jay-Bee View Post
    Wow! Wonder how the "ZF8 compatible" Valvoline will work. I assume Audi wants a pretty penny for the TCM update?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Has Audi changed THEIR (who knows what they are using) their fluid specification also to accomodate the "Split"? If so, from what spec to what spec?
    Or are they just ignoring the ZF and use the same spec/fluid for both versions without bothering?
    05 Golf TDI
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    It should be covered under a TSB if you ever had it in for service, I asked them to check when i did my airbag recall and they said it was up to date. I then realized you can easily tell your TCM software rev from VCDS as well.
    Feb 20 2010
    Brighton, MI
    Scan of tranny module:
    Tuesday,12,March,2019,20:02:13:03761
    VCDS Version: Release 18.9.1 (x64) Running on Windows 7 x64
    www.Ross-Tech.com
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Control Module Part Number: 8E1 910 156 K HW: 09L 927 156 B
    Component and/or Version: AG6 09L 2,0TFSI USA 0080
    Software Coding: 0000002
    Work Shop Code: WSC 00000 000 00000
    VCID: 2F6C9E5BBE13FD3274-807A
    05 Golf TDI
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Check Phil's ATF DIY, i'm pretty sure he covered this.
    I work in parts sales, honestly some of this stuff is overly complicated for no reason. I'll be running Liquimoly 1800 Toptec ATF, it is a multi spec fluid as well that covers ZF6&8
    Jun 27 2011
    ZF Lifeguard 8 is good stuff. I used it recently in my wife's ZF 8HP powered Q5 with solid results. That being said, I believe Redline D6 fluid will work for a 6HP and its way cheaper than ZF.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    May 20 2010
    Oh they have D6 now? Was D4 back in 2014 or 2015 when mine was done.
    Mar 24 2013
    Oakdale, CT
    I used Vaico ATF 8HP in the 05.5 tip B7 I used to have and it worked great. The trans went from not shifting out of third to working perfectly. This was at about 172k miles.
    -Adam
