just ordered this $9 eBay Chinese tool to try on terminal pins
I still need to figure out how to measure wire gauge, and a good source on it.
Same goes for terminal pin ends.
If I can start from scratch making my own wires, it could allow better installation of heat shield tubing, for a tighter neater look.
Because modifying an existing harness that already has terminals crimped onto the wire ends might make that harder. They take up more space and it'd he harder to slide over the right size tubing.
I hope it can apply to fuel injector wiring.
It appears Motoza offers many different parts for EV14's, such as plastic adapters, wire harness versions, and the connector itself.
I'm not sure how tight-fitting or heat resistant the tubing is on the harness ones.
This is not the cheapest or highest quantity ad I've seen for terminals.
https://www.ebay.com/itm/Female-Wire...-/232985917444
They may be more different ads, and I think I've even seen some listed here or on VWvortex. Maybe the person bought a bulk amount for himself and was getting rid of any extra that came with it that he didn't need, IDK.
When searching eBay for RayChem DR-25 and ordering results starting with Lowest Price, it appears there's some as cheap as $2 for 1 foot of tubing. So I might gather an assortment.
I hear it's a good heat-resistant shrink tube; otherwise I've only found regular 3M so far locally.
Another reason to be concerned about re-working a pinned harness, or starting with fresh wire. Hopefully shrink tubing can slide over a pinned harness and not be loose, because it still only probably has a 2:1 shrink ratio.
