Results 1 to 7 of 7
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    Heater core hoses feed and return pipe o-ring part numbers?
    Iím looking for the part number or size of the o-rings for the heater core feed and return hoses that connect to the back of the engine at the coolant cross pipe? Does anyone have or know the size? Thanks.
    Veteran Member Three Rings RocksForsSale's Avatar
    Oct 11 2014
    Allentown, Pa
    They are pretty well built into the plastic couplers you can get separately from VW or from a supplier with the part number. Mind as well replace them if you havenít pulled the stock ones off ever, good luck if theyíre old a big pain.
    Sep 24 2010
    Costa Mesa, SoCal
    I've installed # 212 silicone O-rings for the heater core hose connectors (instead of replacing the connectors).
    McMaster-Carr P/N 1283N84
    Can't speak to the longevity of using them yet, but the sizing seemed close.
    I have lots extra (25-pack) and can send a few via US mail (in an envelope) for only a couple dollars.
    Also more info:
    https://www.audizine.com/forum/showt...ng-part-number
    https://www.audizine.com/forum/showt...ficulty-Rating
    2001.5 S4 Avant: JHM shifter, 3" exhaust, Stage 1, APR bipipe, lowered, receiving lots of love ($$$)
    2001.5 A4 1.8TQM: so many upgrades. Parting out.
    2001 Corvette (C5) Z06: just getting started
    Nov 23 2004
    NH
    I have the motor out so it should be easy. Metalman you have PM.
    Jul 04 2012
    Woodbridge, VA
    Advance auto and rock auto sell a dorman part you can use. Canít remember the part # though. Check 627-002 through 627-007 those are all Vw Audi connectors.
    Aug 03 2018
    05 CRF250R
    Philadelphia Subs
    https://www.partsgeek.com/gbproducts...ad=47433971532
    Think this is what you want. The connection is actually below the crossover pipe right into the back of the block.
    Put some Vaseline on the lip of the oring when you go to install, makes it easier to seat.
    Mar 06 2011
    Wilmington, MA
    I used a #212. I don't recall the material, probably buna-n or viton. I have 2 yrs and 11k miles on them.
