Results 1 to 12 of 12
    Oct 28 2017
    Atlanta, GA
    2016 sq5 question
    Looking at a 2016 sq5 with 30,000 miles. Anything to look out for in particular? Anything I would want to keep an eye on? From what I have gathered the 2016 is a very reliable car but just want to know what the general consensus is here.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    No issues or complaints with mine. Worth closely inspecting the brakes - if the front rotors and pads haven't been replaced, they're likely due. Good luck.
    --Jerry || 2016 SQ5 P+, Glacier White; Tech, Nappa, Black Optics, 21's.
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: 13' Q5 3.0T '12 Q5 3.2, '08 A4 Avant 3.2, '06 A4 Avant 3.2.
    Nov 27 2017
    Los Angeles, CA
    Quote Originally Posted by Weberr89 View Post
    Both industry data and peoples stories indicate that the 2016-2017 Q/SQ5 are one of the most reliable vehicles ever made.
    The only real areas to watch out for that I've seen are:
    - water pump or crossover pipe coolant leak
    - catalytic converters
    - tires quality (make/model) and remaining tread
    - maintenance that has been completed (e.g. prefer one that has had the 35k service)
    - extended warranty or prepaid maintenance
    - options on the vehicle
    Also the SQ5 and Q5 3.0T are almost identical in manufacture except for minor items, and the Q5 3.0T can be made faster via a simple tune without losing reliability, for a significantly lower cost.
    Veteran Member Three Rings elijahallen's Avatar
    Nov 12 2006
    (sold)2011 B8 S4, (sold)2014 Audi Q5 TDI
    Michigan
    I bought mine around that mileage and then waited for 35k service before modding, at that service I noticed the water pump was leaking ever so slightly so I had that done under warranty. Itís been reliable so far and Iím throwing a lot of power at it with no issues. The brakes were just done on mine when I got it so really thatís the main thing to look at.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Check the rear brakes, too. They are known to wear as fast as the fronts, if not faster. Oil-level sensor (get a dipstick), water pump leaks. . .nothing major. I'm just about to turn 62k on mine and that's all I've had done.
    Oh! The tune. Don't forget the tune. You're going to want to bump that 354 up to 454 soon.
    Jan 11 2018
    2018 VW Atlas
    Florida
    2016 sq5 question
    Quote Originally Posted by SQive View Post
    454hp...thatís it?
    I second the idea of having a dipstick.
    Check the water pump for sure. Iím at 53k miles and mine is leaking, having it replaced this week.
    Senior Member Three Rings MSq5's Avatar
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by bajan01 View Post
    454hp...thatís it?
    Bajan01, I tried to PM you in response to one you sent me. Your box was full. It pertains to your coolant reservoir question.
    2017 Q5 3.0T S-Line | Brilliant Black | EPL Stage 2 93 octane tune | JHM 179mm crank pulley | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8
    Jan 11 2018
    2018 VW Atlas
    Florida
    Quote Originally Posted by MSq5 View Post
    Cleared inbox out...try again.
    Apr 26 2014
    DFW
    454hp...thatís it?
    That was my official dyno when going stage 2. I've since gone dual-pulley, CPS, APR v.4 tune, and TCU mods. Based on that first tune, my butt-dyno reads about 465/440, with a very broad power band. Not bad for pump gas.
    Jan 11 2018
    2018 VW Atlas
    Florida
    Word...just kidding around. What gear did you run in?...4th?
    Registered Member Two Rings
    Jan 28 2019
    CT, USA
    It's amazing what power you guys can pull out of these 3.0 engines. 454HP in a 4door crossover.
    Dec 22 2009
    2008 A4 Avant
    San Francisco, CA
    2016 should be good. Has updated cam chain tensioner which was a TSB/warranty fix for 14/15. Also has updated steering components - some earlier 14/15 are more prone to electronic steering failure at near-zero temps.
    Hers: 2014 SQ5 Premium Plus
    Mine: 2008 Ibis White Ti S-line A4 Avant 2.0T 6MT
    Black Alcantara S4 Recaros | RS4 Grill | S4 Mirrors | JHM Short Shifter | RNS-e + OEM BT | BBS CH reps | KW V2 | F+R S4 Brakes | RS4 Sway Bar + 034 End Links | APR Stage 1 Tune | JHM Downpipe | B7 S4 Exhaust | Apikol Snub + Differential Mount | 034 Street Density Motor + Trans Mounts
    Past: 2004 Arctic White S4 Avant
