Results 1 to 12 of 12
Thread: No crank 1.8T
    Jan 21 2018
    Montreal, QC
    No crank 1.8T
    Hi guys,
    My 2003 A4 1.8T was parked outside in winter time for about 5 weeks during my holiday abroad. Upon my return, I put the battery (fully charged) in the car and it started right up, drove the car for a full day with multiple startups, behaved normally.
    Now a day later, out of the blue, in rather cold weather, the dash lights up with ignition, but no crank. I tried many times, no luck.
    I pulled only code 18010, Power Supply Terminal 30: Voltage too Low (P1602 - 002 - Lower Limit Exceeded - Intermittent), which is probably due to the battery having been unplugged during my absence.
    Searching online returns somewhat similar problems, but most happen intermitently before failing completely. Mine failed at once.
    If one of the relays (ignition, starter) or sensors (crank position, clutch pedal) failed, would Vagcom tell me? Like I said, only error code I'm getting is 18010.
    I can use some help! Thanks!
    Feb 08 2006
    Columbia, Md; WPB, Fl
    You said you put a fully charged battery in. So, not brand new. Did you try to jump the car? Perhaps your charged battery has a bad cell and didn't hold the charge.
    Jan 21 2018
    Montreal, QC
    Quote Originally Posted by icutrauma1 View Post
    Yes that's one of the first things I tried, with my neighbor's old Civic, no luck. I'm not getting a "tic" or anything. As if I was turning the key without pressing the clutch pedal (surely that sensor could be a possibility, but wouldn't I get some sort of code?).
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I'm going to say if the battery is good and connections are solid, and it is a random no crank, it is the starter. Get a flashlight and a flat head screw driver, look under the car at the starter from the front and see if the braided copper wire running between the starter and solenoid is continuous or if you can push the screw driver right through. I've seen quite a few threads with car running fine one day, the next random no crank, always was the starter (including myself).
    Note, if you're like myself you more than likely wont hear the fuel pump prime or have fuel pressure at the rail either so don't get sidetracked, it cost me a lot of time, remember it's a no crank not a no start. If you have a manual just try jump starting it and see how it runs once it's going. You can also using a wire to jump the park neutral safety relay I'm pretty sure if that is something you want to rule out but I still say starter. If you have a voltmeter and/or test light there are good tutorials out there on how to test the connections at the start/battery if that's also something you want to try.
    I'll stick these here, you might not have all relays shown in the ECU box FYI.
    Wiring
    Fuse/relays
    Apr 07 2011
    My guess is wiring between positive battery post and starter, probably a bad connection. Maybe try and re-seat the positive battery connection and try again.
    Jan 21 2018
    Montreal, QC
    Interesting. Will do right now, I did so but only on negative post.
    Just did re-seat both connectors and tightened, no luck... search continues.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by B6fan View Post
    No. The clutch safety start switch does not connect to any computers - ECU or otherwise. So it cannot set any codes. It is simply an electrical part of the starter circuit.
    Luckily for you, the starter circuit is basically the simplest circuit in the entire car. Even simpler than the horn circuit. Zero fuses, zero computers. Compared to newer cars with push-button start nonsense, that's a really, *really* great thing.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    My thread a few threads up should have all the info you need:
    https://www.audizine.com/forum/showt...-walky_talky20!
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
    Jan 21 2018
    Montreal, QC
    After much investigation, pretty much the last option... it was a relay under the ECU, I think it is activated by the clutch pedal sensor? Anyway, lower part was rusted out, though we didn't find any water in there and other relays were fine. Replaced the bad one and now happily back on the road! Thanks to all for input!
    Mar 31 2009
    NC
    Good to hear. That relay is your "starter" relay, so that would explain your ordeal precisely. Glad you're back on the road.
    -Brandon
    12.9@104mph
    Apr 07 2011
    How does one test this relay? Oddly enough, I got my car back from the shop yesterday after doing a motor swap for me and now the starter doesn't engage... I don't think I'm hearing the click from the relay when I go to start it so I'm hoping it's just the relay.
    Feb 15 2019
    Florida
    Uhh, that happened to me, the connections on the battery positive we’re messed up. I checked the connections, they seemed good, so I changed the starter. That wasn’t the problem. Really check your connections to make sure they are good. That, or try hitting the starter with a metal object while someone tries starting it. Just be careful that you don’t get hurt while doing this.
