Results 1 to 11 of 11
Thread: 02 Allroad Help
    Feb 11 2019
    Mt. Sterling Kentucky
    02 Allroad Help
    Long story but I just purchased an 2002 Audi Allroad 2.7T automatic. Bought the car it wouldn't come out of park when you turned the ignition switch on. It would start with a jump. If key wasn't on you could move shifter freely. As soon as you turned the key on the shifter would lock. Temporarily solved that problem by unhooking the safety switch. Not sure what its called but at the front of the shifter that moves when you hit the brake. Installed new battery. Started car and drove it home. Seemed a little sluggish like something was holding it back. Once it got moving it was fine. Drove about 40 miles. Realized half way through the trip that it wasn't shifting. Trans was stuck in one gear. Figured trans was in limp mode. The PRND indicator does not show up on the dash. Check engine light, abs light, and the light with a circle and triangle in the middle was on. I also noticed the heat was not working. It was blowing out cool air. Got it home and decided to hook my laptop up to it. I have vcds on my laptop. Hooked it up and the alarm horn started going off. It wont quit, its a constant sound. Only way to get it to quit is unhook the battery. Car starts and runs fine. Door locks aren't working. On my drive home I tested the windows and the sunroof and they where working then. Haven't tested them since the alarm horn started going off. I was unable to read the codes for the tcm. It said no communication when I tried to read it. I'm leaning toward a bad ccm and possibly a bad tcm. I'm looking for any and all help. Thanks
    Feb 11 2019
    Also every time you shut the car off and turn it back on it switches all the readings to metric.
    Feb 11 2019
    Also I keep remembering things. Lol. The Suspension system buttons do not light up or does anything happen when I use the buttons.
    Jun 07 2005
    Shepherdstown, WV
    Between the alarm and trans issues I would check for flooding under the carpet, TCM is on passenger side and body/alarm module is on the driver side.
    The alarm going off can just be related to a low battery and forgetting state of alarm when power was lost, putting key in door lock and cycling lock/unlock should solve that.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Feb 11 2019
    I tried the key in the driver door and also in the hatch and nothing changes. The battery is brand new and the car when its running shows it to be charging fine.
    Nov 30 2016
    northfield, ma usa
    Your TCM and Body module sound water damaged
    Feb 11 2019
    If I order those off line do I have to get them programmed or match up numbers on the modules and they work? Thanks for the help
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by fireman346 View Post
    yes, there will be a letter suffix at the end of the p/n, example 4Z7959655'C'
    best to match the letter if at all possible
    and some programming might have to be done as well
    also, if you can, get a vagcom scan done; that will eliminate a lot of guesswork with this diagnosis
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Nov 30 2016
    northfield, ma usa
    They will need to be coded to the car using Vag-Com
    Feb 11 2019
    Finally got a chance to pull the tcu and ccm out of the car today. Both cases where full of water. Ordered both off of eBay. Hopefully this will straiten it out. Now to unclog some drains. Lol
    Nov 30 2016
    northfield, ma usa
    Make sure to check the connectors for crap and corrosion.
