Results 1 to 24 of 24
    Aug 24 2012
    83 quattro, 99 A4 Avant LY1T, 99.5 Avant LY1B, 74 Norton Commando, 81 Kawa GPz 550 (two of them)
    Portland, OR
    Driggs' BRILLIANT Yellow 1999.5 Avant
    Hey everyone.
    Picked up a gorgeous brilliant yellow avant yesterday.
    Very stoked.
    More pics and info to come!
    8D5 515 Type
    AEB Engine
    DAJ Transmission
    DWR Transmission
    LY1B Brilliant Yellow
    N5F Seat trim covers in fabric
    BR Onyx seats with Satin Black dash/steering wheel
    E0A No special edition
    1KD Disk brakes in rear
    3FE Electric tilting and sliding glass sunroof with sun screen/sunblind
    F0A No special purpose vehicle, standard equipment
    T8B 4-cylinder SI engine 1.8 l unit 058.D
    2PV Leather-wrapped sports steering wheel
    7Q0 Without navigation device
    3L3 Manual height adjustment for front seats
    1SA Without additional front underbody guard
    J0L Battery 340 A (70 Ah)
    0L0 Mechanical throttle control
    3NZ Unsplit rear seat bench unsplit, split folding backrest
    C4X Alloy wheels 7J x 16
    4UB Airbag for NAR
    1LB Disk brakes in front
    8GB Alternator 55 A
    8BH Ellipsoidal headlamps for driving on the right, US design
    8Q0 Without headlight range adjustment
    7K0 Without direct tire pressure monitoring system
    6XD Exterior mirrors, power-adjustable/ heated
    4LA Without controls (RADIO)
    5MY Decorative inserts
    0G1 Gearshift lever
    U1D Instrument cluster w/ mph speedometer, clock, tachometer, trip odometer, add. instruments (voltage, oil temperature)
    9Q2 Multi-function display/on-board computerwith check control
    4X1 Side airbag in front
    3Y0 Without roll-up sunshade
    Q1D Sports seats in front
    5SG Left exterior mirror: flat
    1AH Electronic differential lock (EDL)
    7X0 Without park distance control
    0YS Weight range 17 installation control only, no requirement forecast
    X9A Equipment options subset for USA
    8Z6 Hot country
    2K2 Reinforced bumpers
    4K2 Radio remote controlled central locking "SZV"
    5RW Right exterior mirror: convex (US) large viewing field
    1BE Sports suspension/shock absorption
    4R3 Power windows with comfort operation
    0JF Weight category front axle weight range 6
    M98 4-cylinder SI engine 1.8 l/110 kW (20V) turbo base engine is T8B/T8C
    6R2 Leather gearshift boot
    5D2 Carrier frequency 315 MHz
    4GP Windshield in heat-insulating glass withsunshield and viewing window for vehicle identification number
    83 urq, 84 4kq, 99 a4q avant, 99.5 a4q avant
    b2 Resource page! Links, Registry, more!
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    Nice option list! Good luck.
    Veteran Member Four Rings Joe Jr.'s Avatar
    Mar 09 2017
    Longmont, CO
    very clean! Getting harder to find in that condition.
    Need another!
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    WOW! Love it! Sport cloths too
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Jun 30 2008
    Erie, Pennsylvania
    Sweet Wagon. So clean for a 99.5.
    Jun 10 2010
    Wow, looks like it has a RS4(?) spoiler too.
    Someone drive a similar Avant (but 2.8) to work. But his is nowhere near as nice as yours.
    Aug 24 2012
    Portland, OR
    The spoiler was made by MS Design in Austria
    I have to repaint it and the front bumper. But I’m so exited it has this little spoiler!
    Aug 24 2012
    Portland, OR
    The felt inserts in my new brilliant yellow avant were disgusting from the years of use, so off the scrapyard, and I picked up some of the preferred rubber inserts. I grabbed the cup holder insert out of a b6 and trimmed it to fit behind the cigarette lighter (until i find another b5 larger piece to cut to size), and I am going to cut the cupholder insert later tonight. Its the little things that make me happy.
    Aug 24 2012
    Portland, OR
    Did a little cleaning after I arrived home from my 10 hour drive when purchasing the car
    Winter mats due to arrive tomorrow. Once the weather gets back to spring, the seats will come out it this, and the gold avant so the carpets can get steam cleaned.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    nice find, a little dirty, but nice find none the less!
    please remove the 1980s pin striping, its the only thing i see when i look at the car lol
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Aug 24 2012
    Portland, OR
    A little dirty?
    Pin striping will come off when the car gets detailed after winter.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    I wish my Brilliant Yellow still looked that good. Will look better when that pinstripe is gone.
    1998.5 A4 1.8TQM My Build
    Dec 13 2010
    FL
    Quote Originally Posted by Driggs View Post
    A little dirty?
    Well I was trying to be easy, but since you asked, the interior is really dirty, look at it! Your door jambs are disgusting too, and this is after a "wash" lol
    Mar 15 2018
    Europe
    If that is dirty I dont know what mine is :)
    Aug 24 2012
    Portland, OR
    Quote Originally Posted by GrapeBandit View Post
    Hmm not sure I said I washed it. Pretty sure I said a little cleaning.
    I drove 10 hours thru a snowstorm before I got home and snapped pics.
    Sorry it does not meet your standard. Please feel free to ignore me and my posts as I am sure they won’t meet your standards going forward.
    Dec 13 2010
    FL
    My misunderstanding, usually a cleaning is a wash, my bad, I thought the words were interchangeable. I tried to give you a compliment on the find, and you get upset because I called it a "little dirty".
    This has nothing to do with "my standard", if the interior is dirty, the interior is dirty! Do you think the inside of your car is clean?
    Veteran Member Three Rings Cactus Avant's Avatar
    Dec 15 2012
    This thing is awesome. Sweet pick up. Gotta love a rare spec avant. Excited to see what you have planned.
    Aug 24 2012
    Portland, OR
    Grabbed a few sets of rubber from the scrapyard. I always hated the felt liners for the cupholders/storage in these cars so I was lucky to find a b5 that had the long rubber insert, along with the empty storage rubber. I like having the cupholders so I cut it to fit the cupholder tray, and grabbed a similar enough rubber liner from a b6, and cut that to fit behind the cigarette lighter
    Changed out the disgusting cabin air filter, and steam cleaned my vent system. Hopefully this gets
    Picked up a set of b6 passat wiper arms as the arms that came on this car stuck up way too high. theyre different than my early 99 a4 arms, so I imagine they were replaced at some point in time. We have a snowstorm coming in today so I had to get this done.
    Veteran Member Four Rings reece_2212's Avatar
    Apr 22 2016
    Alberta, Canada
    Nice ride! Always cool seeing the more rare colours in great shape
    '96 A4 2.8QM - (RIP Avocado) <3
    '01 A4 1.8tQM - GT2860RS Elim, 550cc, APR Carbonio, Clutchmax Stage 2 w/ SMFW, APR FMIC, IE Rods - Bilstein B8, Tein S Tech, 034 Trans Mounts, ECS Poly Snub, Stern Engine Mounts - B7 A4 Front Brakes, C5 S6 Rear Brakes, Stoptech Stainless Lines - eBay SS, 3D Printed Shifter Cage, JHM Linkage Bushings -
    Active Member Two Rings dewaynesparks90's Avatar
    Jul 10 2018
    Colorado Springs/Colorado/Moun
    Man nothing in this world like a B5 Avant
    Established Member Two Rings RastAudiA4's Avatar
    Aug 26 2014
    United States
    Nice, welcome to the brilliant family, im jealous, never seen a brilliant wagon ever
    Aug 24 2012
    Portland, OR
    Quote Originally Posted by RastAudiA4 View Post
    Thanks! Been doing lots lately but haven’t had the time to put it all together and post on here. Will do soon.
    Aug 24 2012
    Portland, OR
    Well its been an interesting month of ownership. Idaho uses salt, and or de-icing material from what I can tell, and man the underside of the car has that layer of rust and corrosion that makes bolts break and things a pain in the ass
    Things I have noted need fixing:
    Downpipe flex line leaking (new downpipe is in my garage)
    Rear humming above 50mph (replaced both rear wheel bearings, problem fixed! Although more problems added)
    Rear calipers are sticky, and need to be replaced
    Hazard/Switch/Cupholder trim piece is all banged up (replaced with a used unit)
    Front rotors were not vented anymore as the vents were full of dirt. I replaced them with some Brembo rotors and EBC Red Pads I had kicking around
    Front speakers are shot
    Rear tie rods need to be replaced
    Rear sway bar links need to be replaced
    Weird low RPM rattle in the front end. Sounds like a heat shield of sorts.
    Needs a new cargo cover eventually
    Both front and rear glass have scratches in them from the wipers and what I assume was dirt on the window. Sigh. Couldnt polish them out. I will have a glass company come to fix this. Very noticeable.
    Multi Function Display will have to be replaced
    I grabbed two rear spindles from a parts car at the yard. Pressed in new bearings, and cleaned those up. The ones on the car had completely seized eccentric bolts and ABS sensors. Also noticed the rear calipers were sticky and inconsistent, so I will be swapping them out for some rebuilt ones, along with new hangers and hardware. When doing all this, both sway bar links were really sloppy and both tie rod ends had way too much play in them, so theyll be replaced next week and the car dropped off for an alignment.
    Things I have done
    Later passat wiper arms installed
    Neused rear spindles with new bearings installed
    Hazard trim piece replaced
    Front rotors and pads replaced
    Oil changed
    Mar 09 2017
    Longmont, CO
    amazing how a car can hide things from you until you start getting underneath and looking closely. I look at lots of used cars and i've come to the conclusion that if it has between 150k and 200+ there's just a lot of things that need to be addressed, unless of course someone just went through it all.
    how many miles were on it when you picked it up? Just curious.
    Need another!
