Results 1 to 21 of 21
    Veteran Member Four Rings RocksForsSale's Avatar
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Airbag module 65535 from struggling cold start
    65535.V48023 Internal Control Module Memory: Checksum Error
    Did a lot of reading. What cars come with the K air bag module? B5 A4, passat?
    Most similar issues popped up from very cold temps low voltage starts resulting in this. Most said 65535 “intermittent” mines “checksum error” same code. A few threads mentioned it going away once warmer out.
    Rosstech mentions it’s not bad but from voltage issues:
    Anyone ever use this?
    Similar search found another thing called a zombie box or something working but needing to be used 6-10 times a year after a few years of it working.
    Ultimate fix I guess is to RR
    If I can just grab one from a passat or a4 and soft recode if that’s the “k” module. I’ll just do that, but 20 some bucks to reset the hard fault is better digging to get the module from 2 cars to make a fix.
    I assume the above thing is more than what the vagcom would do to the fault code.
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Quote Originally Posted by LJS View Post
    Yep read this already, just didn’t say what car was the K was from. Pretty sure it’s older b5 a4. I read about an hour of googling the topic here, Audiforums and audiworld.
    Established Member Two Rings hikaru's Avatar
    Apr 29 2014
    United States
    Quote Originally Posted by RocksForsSale View Post
    I have this. I use it every time sub zero temps trip the srs light. Works every time.
    2001 S4
    2004 S4
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Quote Originally Posted by hikaru View Post
    Yes, the answer I was hoping to see! Thanks. And I see that the “k” box perhaps doesn’t do the seat airbags...
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    The checksum error or Intermittent? I’m not sure if there is a difference since it’s the same code number.
    Veteran Member Three Rings rkern's Avatar
    Jul 26 2012
    93 Corrado VR6
    SoMD
    Does that scanner work to clear the light even with no code? I have the airbag light, I'm guessing due to the cold here. I have scanned it and it comes up clear. Just annoying and not sure that if the light is on, will the bags still work?
    01.5 S4 Avant Imola Yellow Stg 3
    93 Corrado VR6 3.0L
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Quote Originally Posted by rkern View Post
    You have to go into the “airbag” section of the scanner. Don’t think the bags will work when the lights on like they’re supposed to.
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Looks like they are out of stock? Do you have this exact one?
    Jul 26 2012
    93 Corrado VR6
    SoMD
    I do go to the Airbag tab on the VCDS to scan it, still no codes.
    93 Corrado VR6 3.0L
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Weird but the lights on?
    Apr 29 2014
    United States
    Light on=bags disabled
    Same exact one
    2001 S4
    2004 S4
    Jul 26 2012
    93 Corrado VR6
    SoMD
    I know. I kept hearing people say, if it's below a certain temp the light will come on. I would assume that a connectivity fault would pop up but it's blank.
    93 Corrado VR6 3.0L
    Jul 26 2012
    93 Corrado VR6
    SoMD
    I have also heard that if no fault codes that the brain box might be bad and that is what I thought that this was covering, the replacement or another suitable part.
    93 Corrado VR6 3.0L
    Apr 29 2014
    United States
    Its a hard code. Vcds won't erase the code. My understanding is the reseter recodes the module.
    2001 S4
    2004 S4
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    I just ordered it from eBay. Searching eBay it didn’t come up right away. I paid it hopefully coming from NJ, but paypal threw Chinese letters at me as the seller when it went through. Probably should just order it cheaper directly from China save 5 bucks if it’s coming from there anyway.
    Nov 19 2014
    Portugal
    I had this on mine and the only way to solve that was buy a new control module.
    I bought one of those erasers but no luck.
    I also have a good file for it but didn't found way to flash the control module
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Quote Originally Posted by armageddon- View Post
    Same one the black box with the two buttons? Do you know which code you had “intermittent” or “checksum”. Oh well for 25 bucks it’s worth a shot then I’ll get to digging the module out. Def died because the cold, voltage drop cranking.
    Apr 29 2014
    United States
    2001 S4
    2004 S4
    Nov 19 2014
    Portugal
    intermittent
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Hey good news that eBay airbag handheld device did the trick. Cost me 25 but just get the one that comes from China as it’s gonna come from there anyway cheaper. Saved me from digging into my dash.
