Results 1 to 11 of 11
    Mar 05 2016
    Rear door cable broke, need help
    My rear door cable broke, now I can’t open the from outside, I can only open from inside. Not to sure if it’s part number 8 or 12 on the picture that’s broke. It this cable easy to change or I have to remove the lock actuator in order the remove this cable?Attachment 104335Attachment 104336
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    Rest assured, man. I live in the same country. Sometimes, you can't use brute strength to solve your problems if things aren't going your way.
    These German cars are like delicate flowers, so be sure to take heed next time!
    In all seriousness, I wish you luck with this - from a fellow Canuck to another.
    Mar 05 2016
    It’s freezing cold in Canada, like -30•c. Maybe pull to hard on the handle🙄
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    As you mentioned, there are two cables inside the rear door. One is connected to the inside handle, and is part number 8K0 839 085 A. The ECS website carries this one (ECS part number ES#451466 for $32.22). The description is Rear Door Latch Release Cable - Bowden cable from inside door handle to latch - Fits left or right side ... Inside door release not working? A common problem is the Bowden cable stretching or breaking. It looks like this:
    However, you said that you cannot open the door from the outside, only the inside. Therefore the other cable, part number 4H0 837 099 B is the one you'd need. The ECS website shows this one (ECS part number ES#2595542 for $38.33). The description is Door Bowden Cable - Fits the left and right side. Fits the front and rear doors from the 2013 model year (but the chart shows it fits the B8 S4 -- you didn't mention your car's year so check to verify the part number). ... The bowden cable attaches the exterior door release to the door latch assembly, allowing you to release the latch from the outside of the vehicle cabin. If this cable fails, the outer door handle will no longer open the door. It looks like this:
    I assume you need to remove the inner door card to have access to replace this bowden cable. Might be a DIY video to illustrate the process you'll need to follow for this repair. Alternatively, someone here on AZ can offer advice as to what needs to be done to replace the cable. Also, the part may be available for less at other on-line parts websites. ECS is a reputable vendor though that I've used in the past, and trust.
    Just noticed that if that picture of the cables you included is from your car, than apparently you got the door card off. The cable with the yellow plastic piece at one end has a white plastic piece at the other end. In your pic it looks like the white plastic piece could be broken, so that could be your problem. Here's what a new one looks like:
    It would be part number 10 in this diagram:
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Mar 05 2016
    Quote Originally Posted by LYKUNO View Post
    Yes, door Bowden Cable Part #4H0837099B, that's exactly what I need. The interior panel is already removed, the edge of the Bowden cable link to exterior handle is removed. However, I don't know how the remove the link of the other end (the yellow side). I can't access the other end, do I have remove the lock actuator? Not to sure how to proceed.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Mar 05 2016
    Attachment 104342
    Don’t know how to remove that end of the link. No room, how to access??
    Attachment 104349
    If I unscrew these two triple square bolts, will I be able the free my lock actuator and have access to the Bowden cable?
    Senior Member Three Rings Akvdubn's Avatar
    Jun 28 2013
    2001 Imola B5 S4, 2005 Subaru STI, 1997 VW Jetta GLX, 2016 Triumph Daytona 675R
    Anchorage, AK
    Quote Originally Posted by TC_S4 View Post
    Attachment 104342
    Attachment 104349
    Yup!
    Sent from my SM-G965U1 using Audizine mobile app
    Established Member Two Rings btb.tyler09's Avatar
    Apr 04 2018
    Michigan
    Yeah here's a picture of my old lock actuator. I replaced it with a used one that came with a new cable. The cable is easy to remove once the actuator is out of the door.20190131_061421.jpeg20190131_061424(1).jpeg
    Sent from my LM-G710 using Audizine mobile app
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Yeah, undo those bolts
    This is the DIY video that I used when I replaced my accuator. I was thinking of keeping it for parts, but I do that too often and tossed it. There's someone parting out a car in the classifieds.
    https://youtu.be/fCwqOAHgcCg
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Mar 05 2016
    It was fairly easy to remove the cable once the actuator out of the door. I ordered the cable, should get tomorrow to finalize to job.
    Thanks everyone for the help🤗
    Feb 13 2018
    Dude, that's awesome! I'm glad the overall repair was painless, and am happy you're approaching the finish line soon.
