I can't answer your direct question but I can tell you what I did to my 07 BMW 530i a few years ago when I had it. I had the steering angle sensor warning go off indicating the sensor was bad.
I found someone online who had done their own fix and posted a DIY. I disconnected the battery to disable the airbag from going off. Then I removed the airbag and then the box behind the wheel that had the steering angle sensor in it. Then I disassembled the box and removed the goo that had built up on the sensor. I think I used a toothpick, swap and rubbing alcohol.
I then put it all back together and my problem was solved. I owned the car about 3 additional years and never had another problem.
The dealer wanted $500 for the part and about that same amount for labor. I'm glad I tried to fix it myself.
