Results 1 to 5 of 5
    Dec 31 2018
    Iowa
    Oil Level Sensor System Fault P0197
    Hi everyone, I have a 2015 Audi A3 TDI and the Oil Level Sensor System Fault light keeps appearing on my dashboard. I used OBDElven to get the code and it shows code P0197.
    Does anyone know if the oil level sensor on the bottom of the oil pan is also the engine oil temperature sensor too? Or are they separate.
    Could it just be faulty sensor?
    Thanks,
    Veteran Member Four Rings MikTip's Avatar
    Dec 25 2004
    Earth
    Quote Originally Posted by aik1ng View Post
    Thanks,
    Correction!
    The G266, item on bottom of oil pan is also the temp sender.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 31 2018
    Iowa
    I searched for the part # on ECStuning.com and it told me it does not fit my car model.
    Is there anywhere else you would recommend looking?
    Dec 25 2004
    Earth
    i searched for the part # on ecstuning.com and it told me it does not fit my car model.
    tdi
    04l-907-660-c
    take a look at the one on your A3.
    Verify same part number.
    Or use the part number on yours
    Dec 31 2018
    Iowa
    Okay thanks, should I assume the EOT sensor is bad and that is why that fault is coming back as P0197?
