Results 1 to 18 of 18
    Active Member One Ring johnyeyeball's Avatar
    Feb 13 2007
    1932 ford roadster and 1933 ford 3 window coupe
    EASTVALE
    Coil overs? Which ones do you like
    I canít decide what coil overs are the best for the money. Any info on what you like?
    Active Member One Ring colorado.a4's Avatar
    Dec 04 2018
    iím curious as well... seen everything from ~$500 for solo-werks (good/bad reviews, cheap but china made?) as well as high quality $1000+ H&R or KW... interested in what people think is the best bang for buck. Also opinions of the middle man BC or D2 coilovers?
    2014 Audi a4 Quattro | APR stage 1 e85 | k&n typhoon | 034 Motorsport trans mounts | custom straight pipe | Avant Garde m621 19x9.5 in Technica Titantium | custom installed LED light bar | Carbon Imports highkick spoiler | instagram @Colorado.a4 | #quattroculture
    Senior Member Three Rings keiffr's Avatar
    Feb 19 2014
    2006 Land Rover LR3 SE
    San Francisco Bay Area
    Depends on your budget but I went with Solowerks. Iíve had them for the past 2 years and put over 50K miles on them. No complaints
    2011 A4 2.0T TFSI Quattro P+/ Phantom Black
    IE Stage 1 / A5 S-Line Y-Spoke 19x8.5 Wheels Offset: ET32 / 255/35/19 General G-Max AS-05 Tires/ Solowerks S1 Coilovers
    Established Member Three Rings choppstixxx's Avatar
    Apr 24 2017
    2003 Honda S2000
    Penfield, NY
    If you can, buy a set of lightly used H&R Streets (bought mine for like $600ish). Had them on my A4 and rode well for being as low as I was.
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1of 589
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Established Member Two Rings RLwantsS5's Avatar
    Jul 11 2014
    Bonita Springs, FL
    Vogtland.
    Established Member Two Rings a4efforts's Avatar
    May 15 2017
    '09 A4 B8, '17 PORSCHE MACAN & '08 BMW X5
    Atlanta, GA
    Have Solo Werks and regret being cheap on my coil overs. If I could go back, I would go with a set of H&R.
    Mar 26 2007
    Colorado
    I run ST coilovers (KW V1 essentially) and they ride just as smooth as the factory sport suspension, but body roll has been significantly reduced
    CURRENT:
    APR - B8 A4 Avant
    2008 - 4Runner
    Nov 11 2017
    Denver, Colorado
    +1 for Vogtland. Have a lightly used set of PSS10ís but everytime I go for a drive I wonder if the change would be worth the effort.
    I have heard good and bad about H&Rís, good when they arenít leaking.
    Jeff
    Oct 30 2012
    Arizona
    Quote Originally Posted by vdubjetta02 View Post
    I have ST XTA and they have been flawless for over 3 years now. Adjustable dampening and camber plates included. (made by KW just not as shiny)
    2015 S3 - Full OEM RS3 Front End Conversion - CTS BOV/LW Crank Pulley/Turbo Muffler Delete/Throttle Pipe/IC Pipes - AMS CF Intake - Bull X Catless DP - UM STG 2 RED FILE/STG 3 TCU - XBQ/UBQ - HG Intercooler - ST XTA Coil Overs - Black Optics Trim - PURE CF Trunk Spoiler/Mirror Caps/Rear Diffuser - 19x9 GT5 wheels - E Codes - ECS LW Rotors /BB Intake CF Eng. Cover - Full 3" Valved MF Exhaust - Blacked Out Badges - 034 R/Sway/RSFM - BFI STG 1 Engine/Torque Arm - RS3 Vents - 3M Crystalline
    Active Member Two Rings the-quattro-man's Avatar
    May 16 2018
    Sunshine State
    Lots of good reviews with Solowerks. IMO best bang for the buck!
    Feb 13 2007
    EASTVALE
    This is all good hopefully more people can post their thoughts
    Feb 02 2017
    Beaverton, OR
    I went from H&R Springs to ST coilovers. I did it based off of price as I was trying to stay around the $1,000 mark or less. So far no complaints with them
    Active Member One Ring GraemeHowat's Avatar
    Mar 20 2018
    Edmonton, AB, Canada
    Quote Originally Posted by johnyeyeball View Post
    Iím running the H&R street performance on my Ď13 Allroad. Have no complaints at all about how they feel or handle. Weíre a little on the pricey end compared to other options out there but definitely ride well.
    Only complaint I have with them is on my Allroad the backs are always tucking even at there highest setting. Would love to be able to go up 1/4Ē or so so I can push the wheels out with some spacers. IMG_3268.JPG
    G
    @lebisquit
    Edmonton, AB
    Ď13 Allroad-Ibis White
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by GraemeHowat View Post
    G
    @lebisquit
    Edmonton, AB
    Install these in the rear...they come in 15-30mm. You will have to verify fitment on H&R but they are known to work with Vogtland and Bilstein.
    https://www.ecstuning.com/b-kw-suspe...h/65030045~kw/
    Jeff
    Mar 20 2018
    Quote Originally Posted by JLAllroad View Post
    Jeff
    Hey thanks man, appreciate the suggestion. Definitely looking into these.
    G
    @lebisquit
    Edmonton, AB
    Feb 02 2017
    Beaverton, OR
    Yeah I run the 30mm spacer in the rear with my ST coils on my 2013 allroad.
    Senior Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    Baltimore MD
    There is litterally an entire forum full of this information. the fact that you are too lazy to search for it is your own thing. you could spend hours on this thing and find out exactly what you want, but if you just want somebody to tell you what to get....
    Go to the junk yard and get some springs from a 97-99 f150, then go to advanced auto and buy a set of shocks for a 2012 Honda civic. i saw a guy somewhere do this setup once and he said it was the best thing since sliced bread.
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------14' Phantom Black Pearl Stg2 A4 S-Line -- 6MT -------------- Peep the Build ---------------------
    Feb 13 2007
    EASTVALE
    Well thanks for your input also thatís all good information that forum is dated so I wanted to get a bit of current info
