Results 1 to 9 of 9
    May 19 2015
    winnipeg
    Rack and pinion. Need control module (j500)
    Any one know where I can get just the control module? I don't need the entire rack. Rack works fine. Control module doesn't.
    2013 S5 W/O DYNAMIC
    The tag on the rack/control module
    VWAG
    HU TT1
    120613 H36
    8KO.909.144B
    RCEPS-B-21S-1365014B
    8KO.909.144D
    A2C3094190300
    2 SW:505 F
    If anyone could help so I don't have to buy an entire rack and waste 1500$.
    Much appreciated.
    Sep 10 2012
    London
    Are you talking about the module thatís integral with the rack, if so, donít think you can get it separately.
    I retrofitted dynamic steering and had to swap the racks. I can look to see if it can be removed.
    May 19 2015
    winnipeg
    It can be separated, it's held in by 6 or 8 bolts and disconnects. If you have the old rack laying around... You know.... Hint hint lol
    Oct 30 2018
    toronto
    You should check to see if theres a part number on the module and just type the part number into ebay and see if anything pops up
    Sep 10 2012
    London
    Mine is a rhd rack from the uk.
    Post a pic.
    If itís the same Iíll see if I can help.
    May 19 2015
    winnipeg
    Quote Originally Posted by Adamantium View Post
    Post a pic.
    This is what it looks like out. If the numbers match from RHD it should work the number your looking for is 8k0.909.144
    Dec 19 2017
    philly
    i just change my rack, bought from junk yard, they are going for around 300$.
    May 19 2015
    winnipeg
    Quote Originally Posted by orson888 View Post
    I can't find any near me. Like zero. It sucks so bad. 😔
    May 19 2015
    winnipeg
    When you changed yours out did you have to do any coding for the new *used* one or was it just drop in worked set ur wheel angle and done?
