Results 1 to 10 of 10
    Jan 11 2019
    Mesa Arizona
    Removed Cluster Now no Start
    2008 Convertible. 2.0T.
    I took out the cluster to get a dead bug out. Put everything together and now car starts then dies.
    Help please.
    Veteran Member Four Rings rhfosu's Avatar
    Jan 01 2015
    DC
    Immobilizer issue. I'm not an expert, but in your disassembly, you might have damaged the immo chip.
    Sent from my Moto Z (2) using Audizine mobile app
    "I don't understand Audi enthusiasts. They buy a car that looks like a bar of soap, then they spend money modifying it so it looks slightly less like a bar of soap."
    Jan 11 2019
    Mesa Arizona
    Hereís a good read about the Immobilizer faults and diagnostics.
    https://www.myturbodiesel.com/wiki/i...lacement-tips/
    Feb 15 2016
    Cambridge Ontario
    yup immobilizer active .. probably disconnecting it, it forgot what was supposed to be there.. unless you forgot to connect something back up
    2014 A4 2.0TQ Technik
    2006 A4 2.0TQ 6spd
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 11 2019
    Mesa Arizona
    The funny thing is I do not see the immo symbol when I try to start the car. No flashing keys.
    When I pull codes using VGCOM and go to the cluster module, I get a whole bunch of faults.
    Feb 15 2016
    Cambridge Ontario
    forget to plug in a connector ? or didn't get one in all the way ?
    2006 A4 2.0TQ 6spd
    1976 Yamaha XS 360
    Jun 27 2011
    make sure the Cluster plugs are fully seated and latched.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant)
    2012 Q5 2.0t - Stock Mommy Missile with new timing chains
    Former USP CLUB MEMBER #136
    Jan 11 2019
    Mesa Arizona
    Connections are good.
    I did the 10 minute trick. I hooked up a trickle charger, put the ignition to position 2 (a lights in the cluster come on) and left it there for 10 minutes.
    After that time, I disconnected the charger and starter the car up. Allís well now.
    Feb 15 2016
    Cambridge Ontario
    never herd of that "trick" but okay sounds good.
    2006 A4 2.0TQ 6spd
    1976 Yamaha XS 360
    Jan 22 2014
    Fairfield, Ca
    Very interesting
