Results 1 to 35 of 35
    Dec 31 2018
    New York, NY
    Exclamation Mechanic said internals pierced oil pan?!?!?!?!?!?!?
    So I have a 2003 a4 1.8t 5spd Lowered
    To me it appeared that my oil pan cracked found the exact spot and etc mainly because when I put oil in it comes right out. The mechanic called me today and said from what he saw it looks like the oil pan was pierced from the inside out. He told me I'm going to have to get a new engine. I've never heard of this before. I still have yet to see for myself but I'm going to see as soon as they open in the morning. Any input. I dont want to sell the car
    Dec 28 2006
    '03 A4, '13 A5, '18 MB-GLA
    Western Maryland
    What happened prior to the oil leak? Was the engine running OK? Any funny noises or misfires?
    Since you are lowered it's possible that you hit something in the road and cracked the pan.
    A4 Motoza tuned Frankenturbo F21L / Bosch 550's / 3" MAF / TyrolSport SMIC / 034 HFC / TT 2.5" DP / Borla / Eibach ProKit / Koni Yellows / H-Sport F&R Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi
    Dec 31 2018
    New York, NY
    The engine was running fine held 20lbs of boost fine, I had an oil leak coming from the tensioner gasket (half moon seal) that is it. Same thing I figured, I hit a bad bump because this isn't the first time I cracked the oil pan. My internals are forged so I don't think that's a possibility. From the engine diagram I'm not seeing how something can pierce my oil pan from the inside out. The mechanic said my engine is no good
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    For the pan to have been pierced from the inside, something catastrophic would have needed to happen. Does the engine run now? Even for a second before quickly shutting it off? If so, I'd be looking for a new (actual) mechanic.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Jul 03 2010
    New York
    I don't see anything there which indicates an internal failure.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by DPDISXR4Ti View Post
    Agreed. That is a crack from bottoming out. The next big question will be did it get damaged from being run with no oil, that's a pretty big leak.
    Senior Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    2016 White A3 Teknic S-Line with 19's
    Richmond Hill, Ontario
    I agree pic number 4 proves an external impact played a huge role here, Iíd like to know the mechanics logic
    His - 2015 Audi S3 Technik Florett Silver Metallic on 19's
    Hers - 2016 Audi A3 Technik S-Line Glacier White Metallic on 19's
    "I have nightmares that I'm going to wake up, and everyone's driving a Prius and living in a condo, and we're all getting health insurance".
    - Kid Rock
    Dec 31 2018
    New York, NY
    So he didnít take off the oil pan. He said when he put it in the lift from the way it looks it seems as if the connecting rod disconnected from the crankshaft and dented the oil pan. Is this plausible?
    Mar 28 2015
    Quote Originally Posted by Sire Preacha View Post
    No. You have three posts saying it was an eternal hit and your still asking?
    How did it get on the lift , was it driven?
    Who was driving when it happened and how long was it driven after the oil light came on? Also, that a pretty good hit how did the person driving not notice? If they didn't notice the pan hitting i'm not hopeful they noticed the oil light coming on and shut the motor down.
    To me the only question is did it get damaged from being driven / run with no oil. The motor may have thrown a rod, but that would be from being run dry. Also, most time you lose a rod it goes out the side of the block. Typically, the bottom of the pan is way too far away to poke a rod through.
    https://www.audizine.com/forum/showt...1-8t-rod-knock
    Dec 28 2006
    Western Maryland
    Definitely plausible. Although I think it is apparent that isn't what happened to your engine.
    I once knocked a fist sized hole in the side of an engine block of a TR2 when a rod bolt broke off of one of the connecting rods. Believe it or not all I had to do was replace the rod bolt/nut and patch the hole in the block.
    Dec 31 2018
    New York, NY
    Who was driving when it happened and how long was it driven after the oil light came on. Also, that a pretty good hit how did the person driving not notice? If they didn't notice the pan hitting i'm not hopeful they noticed the oil light coming on and shut the motor down. Something seems odd. Was the car loaned out, stolen or was this a DUI thing? My gut feel is there is more to the story.
    To me the only question is did it get damaged from being driven / run with no oil. The motor may have thrown a rod, but that would be from being run dry. Also, most time you lose a rod it goes out the side of the block. The bottom of the pan is way too far away to poke a rod through.
    No, it was pushed. I havenít turned it on or driven it since the pan cracked. Iíve always towed it and pushed it for when it needs to be moved.
    Dec 31 2018
    New York, NY
    He basically gave me the Iíve seen it a thousand times story and to prevent me from doing a rebuilt. Iím still running a K03 turbo though so I doubt thereís enough power to cause internal damage as he described with my forged internals, but Iím not a formally trained mechanic
    Dec 05 2007
    Get the pan replaced.
    When the pan is dropped, things can be inspected pretty clearly once the windage tray is moved to the side. In my opinion from the looks of that deep gash section by the oil return drain, you simply bottomed out and cracked the oil pan. Most likely a simple oil pan replacement fix, then invest in a metal belly pan.
    Registered Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    Looks like external impact damage to me!!
    Apr 03 2016
    Up North
    I'll add my voice to the choir, totally looks like external damage to me as well. Get yourself a new pan and to prevent re-occurrence possibly a skid plate. I've got an Evolution Thor which has saved my oil pan many times over...
    Active Member Two Rings Mokacrow's Avatar
    Nov 18 2012
    2002 Audi A4 1.8T Quattro Auto, 2003 Audi A4 3.0 Quattro
    Toronto, Ontario
    Pics # 2, 3 & 4 all show signs of road rash. I've seen some winter rims in better condition! lol
    If you take into consideration the damage location from Pic #2, it would be very plausible that the crack was created by the upward pressure in the middle of the pan. Taking it off will help with assessing the damage.
    If you're unable to do the work yourself, talk with your mechanic. If they seem like they could accept making a wrong diagnosis and still fix the actual problem, carry on. If you think they're going to stick to their guns about it being INTERNAL and not budge, find a new mechanic for this job.
    Mar 28 2015
    Agreed, I have seen them out the pan, it's just more of a 1 in a 100 kind of thing..... I included a photo so the OP know what to expect.
    https://forum.miata.net/vb/showthread.php?t=524439
    Also, if you ever throw a block, this is what it looks like.
    Fun search!
    Good luck with your engine, with any luck its in better shape than the ones I linked to.
    Mar 05 2013
    CA
    why didn't the mechanic quickly drop the oil pan to visually confirm, and text you a picture
    Jan 04 2017
    I've got a 1.8T from a 2001 Audi TT, with a wiring harness, ECU, and a K04 turbo. It's all together. It is an AMU engine from a 225hp TT. The ECU is chipped from GIAC and the wiring harness is almost new. It has about 10kmi on it. Sell it all for $1k plus shipping if you get to go that route. Heck, the hardness alone cost me $1k when I bought it new.
    You could build it up with new internals and have it literally dropped in.
    Engine ran fine when taken out of the car. It has been stored inside.
    I hope you don't need to go that route, but if you d ando, let me know. The only thing I can think of off the top of my head is you would probably need to change your MAF sensor.
    Sent from my SM-G950U1 using Audizine mobile app
    Mar 05 2013
    CA
    Quote Originally Posted by tropheusman View Post
    I heard TT engines don't fit the B6
    Feb 09 2013
    CNY
    Add me to the external impact crowd. As mentioned earlier, pic #4 shows where the drain plug area was hit and that's what likely caused the large crack.
    Quote Originally Posted by Spike00513 View Post
    The oil pan isn't exactly "quick" to just drop... mechanic would be better off using a boroscope to look inside for a thrown rod if he has access to one.
    The K04 would be no good to him as well... mk1 TT/Mk4 Golf turbos are different (transverse vs. longitudinal applications), not to mention other things that would need to be changed.
    Jan 04 2017
    Yes, that may be the case. I was just thinking that. The TT engine is transverse and the a4 is longitudinal. At least in the way they are mounted. I cannot be sure if you can direct fit them.
    Jan 04 2017
    Yup, you'd need to deal with the turbo inlet and exhaust as well as the TT uses a halted system for Quattro.
    Sorry man, it wasn't thought through...more coffee before early morning posts.
    Jan 04 2018
    GJ,CO
    I will join too. Definitely an external impact from the look of the crack. I wouldn't trust the mechanic that thinks he knows everything just by externally analyze something. fr3zno is right he needs to use a boroscope or if it was me I would just spend some time and remove the oil cooler and the whole adapter to look at the crank and the rods.
    May 13 2008
    NoCal - EBay
    Either way that pan is coming off. Regrardless of what caused it.
    So dropping the pan and confirming whats broken is the next step.
    I would NOT trust that shop's forensic ability after:
    1) Seeing an oil pain with a HUGE smashed flat road-rash portion and a damaged oil drain bolt
    2) Claiming the damage came from the engine internally.
    'SOFTWALKER MODS
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30 LS2, 2002 A4 B6 1.8t, E63 AMG
    San Diego, Ca
    is your car really low or did you just scrape a huge speed bump? that scrape is soooo fresh and on point i agree with every one else's assessment.
    2007 Mercedes E63 AMG - Nardo Grey, Pano, LTH X-Pipe, Res Del, ROW Box Mod, Programa ELM, UPD Arms
    2003 Audi A4 1.8t Q Avant - Maestro, 225TT Inj, TP, FMIC, Thermal R&D Exh, KW V3, BBK / Ferrodo DS2500
    1992 SC400 - LS2 6.0, LTH, Tomei 2-Way, KW V3, BattleVersion Arms
    1986 Toyota Corolla GT-S SOLD - 20 Valve, Haltech E8, Toda 272 8.5mm, Toda Cam Gears, Silkroad High Rise Headers, TRD 2-Way, TRD SS Race
    Apr 24 2017
    Florida
    Should be able to transplant the long block and use the B6 brackets and accessories.... cant use the TT's: intake or exh manifolds nor it's turbo... would need a longitudinal oil pain and oil pump pick up too.
    '05 A4 1.8TQ, 6spd, dead engine... working on AWP+AEB hybrid transplant
    Oct 24 2013
    girls MK4 1.8t
    United States
    not much is quick about dropping a longitudinal 1.8t pan
    Stupid drift A4
    R.I.P RWD-converted '99 A4 Avant 1.8T
    Mar 05 2013
    CA
    Quote Originally Posted by garytightpants View Post
    Sorry. I didn't know that. Thanks for the info. You may be right.
    This is good to know because I wanted to drop the pan to service it. Though I don't know how necessary that is.
    I've done it on a 3.0L and am used to how V6's are packaged; they seem to tend to be easier.
    I wasn't sure if I4's are the same way or not. I've heard that the 1.8T has an upper and a lower oil pan, and that the upper is harder to work on.
    IDK if a pro mechanic can do it faster due to having power tools, or maybe not, if a lot is involved. The pictures do seem to show a lot of things in the way, such as the sway bar.
    As a service, I'm not sure how necessary it is in general. Such as renewing the pickup screen, renewing the gasket sealing material, cleaning out the pan, etc.
    Oct 24 2013
    girls MK4 1.8t
    United States
    Some transverse 1.8tís have 2 piece pans, some are 1 piece, but no longitudinal 1.8ts have 2-piece pans.
    Removing a b5/b6 1.8t oil pan requires either supporting the engine and dropping the subframe, or using a hoist to lift the engine enough to both access the bolts holding the pan to the transmission as well as have enough room to get the pan past the subframe.
    Stupid drift A4
    Dec 31 2018
    New York, NY
    Update
    363B45AC-E5D0-4103-91E9-71D491164A17.jpg776DD1F0-D505-4725-8115-C2424E4B68F6.jpgB4E7E6C2-26ED-462C-B792-A3F580C80414.jpgA8DF9747-7E00-400F-B9E3-C3904E794BE8.jpgB657786E-9E5B-40B9-BF1D-48BA5294D45A.jpgUpdate: it bottomed out and cracked nothing broke through. I was right but we did find shavings in the oil pan....time for a new crank and bearings but everything else is in order
    Mar 28 2015
    Before you consider a new crank pull the caps on the cams and check for scoring, you might also need a new head and the oil pump may also have gotten trashed. Edit... I would consider a complete used engine probably more cost effective. That's going to get costly to fix.
    Mar 05 2013
    CA
    Was this caused by driving without oil supply/flow due to it leaking out of the cracked pan?
    Dec 31 2018
    New York, NY
    I've always kept it lubricate with LiquiMoly 5W-40. I found out there was a hole in the oil an when I saw the oil on the floor when I double parked. Then I parked the car, fortunately i was directly in front of a parallel and haven't turned on the card until this day. I changed the oil pan and oil etc. 5 weeks before this happened, and the first time there were no shavings.
