Results 1 to 31 of 31
    Established Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Any DIY out there for driveshaft replacement?
    Did a launch today, driveshaft blew apart. I've been trying to look for a driveshaft replacement DIY... To no avail. Is it as simple as unbolting the old one and bolting the new one in?
    Is allignment important?
    187/57 - e85 custom tune (EPL) - custom exhaust -
    ported blower - IABED TB - Brembo BBK - APR CPS - USP intake- 034 sways and drivetrain inserts - cr-15 - 034 density control arms - Koni sport shocks - Eibach lowering springs - VMR v804 -PSS - N2O coming 😎
    Senior Member Four Rings evil35r's Avatar
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Wow thatís crazy first Iíve heard of someone doing that
    13 S4: Tune EPL, CTS 57/XLR8 196.5 Meth/E file, ROC-EURO w/ custom velocity stack, RSE test pipes and custom catback, ECS inserts, 034 subframe mounts, CR-15, H&R Sports, ECS Slotted rotors, Akebono pads, Snow Performance meth dual 375 nozzles=1000cc 70/30 mix, 034 rear sway, coolant pump mod/divorced, Merc hx, AG M590 wheels/Indy 500ís, iABED 75mm TB, Autotech, Matty Blower with hygroscopic vents on ics.
    11.27 @ 122 via Dragy W/ 180/57 ratio
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by evil35r View Post
    I think a few people have done it including loe.
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Any aftermarket shafts out there that are stronger?
    May 08 2018
    Berkeley, CA
    Not from what I've seen. It's the bearing that chews itself out of its gromet type thing and clanks around. Unfortunately the only way to replace the bearing is to replace the entire shaft.
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Dam that sucks are you 8 or 8.5?
    May 08 2018
    Berkeley, CA
    B8 but all the S4 and s5 aside from 2010 use the same part. Along with some a4/a5 etc... It's a very common part.
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Gotcha didnít know if it was a b8 issue if it was different to the b8.5. If I had to replace mine Iíd get a one piece carbon fiber that will hold up to 3000 hp and not worry again haha
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Here's an interesting read. Apparently there can be issues with aftermarket, i.e., non-OEM 2-piece drive shafts. ECS has some options here.
    2011 S4 | Prestige | Jet Blue | Black/Silver Silk Nappa | S-Tronic | Sport Diff | Drive Select | Side Assist | Titanium | Carbon Fiber Inlays | HRE R40s (summer) BBS RGRs (winter)
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by LYKUNO View Post
    No way in hell I'm spending $1600 one one. I'm picking up one at a wrecker off a 2016 a4 for $150 tomorrow. Found on car part.
    May 20 2010
    B5/C5 driveshaft center bearings are notorious for failing. Removing it can be a complete bitch too!
    Good catch on the price. I have one for a B8 A4 (ends in 101, no extra letters), but apparently doesn't fit the S4
    2016 A6 TDI Prestige - S-Line, Black Optics, Driver Assistance, HUD, LED Headlights, Cold Weather, Warm Weather
    2003 allroad 6MT - STUKLR Stage 1, Hotchkis sway bars, RS4 engine mounts, Apikol rear diff mounts
    May 08 2018
    Berkeley, CA
    I made sure it's the same part number on the Audi website
    https://parts.audiusa.com/p/Audi__/D...0521101AA.html
    Jul 18 2010
    NE Ohio
    Good find on the recycled part. And after reading the PDF on replacing a center bearing, it makes sense to replace the entire assembly. Keep us posted on your progress and the result!
    May 08 2018
    Berkeley, CA
    Drove all the way to Fresno to get it yesterday. When they pulled it out of the car, turns out it was bent. God damnit.
    I have a new one shipping that should be here on Tuesday. There's also another one in Bakersfield I might check out tomorrow.
    Jul 18 2010
    NE Ohio
    Well that had to be frustrating! And with a trip of ~350 miles RT to Fresno and ~550 miles RT to Bakersfield, having the new one shipped to you is starting to sound like a bargain! Hopefully your S4 will be back on the road soon!
    Senior Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    2011 Silver S4, Mercedes Benz R350 ('07 & '11), Suzuki SV1000
    New Hampshire
    As far as the DIY, check ECSís instructions for clutch replacement. They are very detailed with pics.
    The one curious part is that they have you mark the shaft before pulling it out and then line it back when reinstalling. Not sure why though. Especially when it needs to be replaced.
    May 12 2008
    Quote Originally Posted by Ford Prefect View Post
    Probably something to do with keeping the same balance. E36ís were the same way.
    May 08 2018
    Berkeley, CA
    So I tried a ghetto fix.
    Took off my mid pipe, heat shield, and made a new bushing by shooting window weld into the space between the bearing and carrier with a caulk gun.
    I'll let you know tomorrow if it works. $20 and 1 hour it took me.
    May 08 2018
    Berkeley, CA
    This was the play in my bearing with a completely obliterated bushing
    https://youtu.be/b-MdqFpvJGM
    Here's what I poured in
    It's not pretty, but I don't see why it won't do the job.
    Jul 18 2010
    NE Ohio
    Damn, that video certainly illustrates why it was banging around in there! It'll be interesting to see if the Windo-Weld urethane (normally used for bonding automotive windshields to car bodies) will stand up to the stresses involved in a driveshaft bearing mount.
    The 3M website states: "Besides replacement auto glass installations, this adhesive may also be suitable for some non-structural body panel applications." I suspect nobody ever considered it for a driveshaft center bearing support though. Clever fix and I hope it works for you.
    Jan 20 2017
    New Hampshire
    Thatís an insane amount of movement.
    May 08 2018
    Berkeley, CA
    So I put the underside of the car back together this morning and took her for a spin. Works PEFRECTLY.
    I'm going to see how long this lasts as a test. To be honest it seems more robust than the OEM bushing.
    All credit goes to this guy
    https://www.audizine.com/forum/showt...-3M-Windo-Weld
    Here's what it looks like now.
    https://youtu.be/ykBxP6rC0t8
    Senior Member Two Rings Akvdubn's Avatar
    Jun 28 2013
    2001 Imola B5 S4, 2005 Subaru STI, 1997 VW Jetta GLX, 2016 Triumph Daytona 675R
    Anchorage, AK
    So another fix from the Cayenne world was to tear out all the rubber completely around the bearing, then zip tie like 1/2 inch long pieces of fuel line all around inside the carrier. The cayennes were notorious for failing center bearings. Did that fix on my 957 turbo and it worked perfectly
    Sent from my SM-G965U1 using Audizine mobile app
    May 20 2010
    I was gonna suggest Windo Weld. Glad you found it via search. Common to use on the allroads as well.
    Established Member Two Rings helldiver14's Avatar
    Jun 21 2017
    Ohio
    Would a bad prop shaft cause a whine on decel?
    Sent from my Pixel 3 XL using Audizine mobile app
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by helldiver14 View Post
    Probably not. You check your wheel bearings?
    Jun 21 2017
    Ohio
    Quote Originally Posted by Morritse View Post
    Not yet. Moved to a townhouse recently and haven't been able to get it up on a lift. I'll have to take it to my friends shop, I've been told Driveshaft, wheel bearing or just my 034 trans mount and insert. Only hear it on decel at like 40 and below coasting in neutral.
    May 08 2018
    Berkeley, CA
    I'm selling a driveshaft if you want it, didn't end up needing it.
    Jun 21 2017
    Ohio
    A4 or S4?
    May 08 2018
    Berkeley, CA
    A4 or S4?
    Same part
    Jun 21 2017
    Ohio
    Same part
    PM me
