Results 1 to 5 of 5
    Jan 18 2018
    Southern California
    Long continuous beep from cluster NO KEY INSERTED
    This is my first post on AZ. I've had my B5 A4 1.8tqm (2000) for 2 years now with problems here and there that I've fixed thanks to AZ. I've looked everywhere and no one seems to share this problem, NO KEY in the ignition car is completely off, but it will give me a continuous beep from the cluster as if the lights were on and the door was open. It beeps at random times when the car is completely off with no key no lights, literally nothing on. It's beeped like this 2 times while the car was running but stops after about 45 seconds. There doesn't seem to be any cause for the beeping but it's driving me crazy and, I fear that the beeping is going to drain the battery. If anyone knows why this might be happening please let me know. Thanks in advance.
    Registered Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    I have an issue where the cluster buzzer will stay on after I get going in my 01. To stop it I have to open and reclose the door and continue driving. Then also when I turn it off sometimes have to cycle the headlight switch. That car had its cluster warrantied in 2012 so I hope it wasn’t a bad replacement unit. Then in my 01 beater it had an issue where the remote starter wouldn’t go into active mode where I had to cycle the door to fix. I assume both are caused by worn out door latch switches.
    EH F0UR 2001 A4 1.8TqM
    = K04 | SOUTHBEND | STERN | FORGE | TREADSTONE
    = ST | MEYLEHD | FCPEURO | 034 | AWE | AKMOTORSPORT | JHM
    = HERTZ | JVC | ALPINE
    2001 A4 1.8TqM
    2002 Golf TDI
    = VNT-17 | 11mm IP | DLC1019 | COLTCAM2 | SOUTHBEND
    = RL Ultimo |
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Jun 30 2008
    Erie, Pennsylvania
    Yes. I second. Check the door latch switch status in VCDS Measuring Blocks. Probably check in the Cluster and Central Locking.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Jan 18 2018
    Southern California
    I suspected my door sensors/switches , but the car gives me the long continuous beep when the car shouldn't have any power. That's kind of thrown my suspicion in a different direction. I'll check the doors later today. Thanks for the response!
    Established Member Three Rings Blazius's Avatar
    Mar 15 2018
    Romania
    Door switches or short circuit in cluster
    2000 B5 A4 Avant FWD Manual - S Line - Sport package
    N/A ARG bottom end, AEB Head | Planning t3/t4 turbo conversion soonTM - https://www.audizine.com/forum/showt...rbo-Conversion
