Page 3 of 3 FirstFirst 123
Results 81 to 107 of 107
  1. #81
    Active Member Two Rings STK-Allroad's Avatar
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    Quote Originally Posted by kenncmiller View Post
    I remember someone attempting this awhile back and getting really close. I think cooling was always the problem with this swap. :shruggs:
    I think the guy even kept all the LS adapter parts and was trying to sell them for cheap.
    Good luck. Id love to see this done. I think a 5.3 in a b5 would be awesome. Ive always dreamed of a turbo LS in my avant
    I done some good reading and always see where they run into problems and that is the GM pully set up is huge and gets in the way. So that makes running a radiator super hard.
    The 5.3 Truck motor has a gigantic water pump. So you have to go after market with Pullys, pump and oil pan. As the truck oil pan is then size of a 1.8t..... lol.
    There are slim performance radiators. Which will help maybe even run a halfie I'll see how room looks when I get there.
    IG: awesome.elvis
    Sent from Space Station
  2. #82
    Established Member Three Rings Blazius's Avatar
    Mar 15 2018
    Romania
    you can cut up the front end a bit to get more room, but things like hood lock has to go. and use latches. I think its also requirement with VR6
    2000 B5 A4 Avant FWD Manual - S Line - Sport package
    N/A ARG bottom end, AEB Head | Planning t3/t4 turbo conversion soonTM - https://www.audizine.com/forum/showt...rbo-Conversion
  3. #83
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    Quote Originally Posted by Blazius View Post
    Yeah hood lock has to go. Gut the inside of the core support and itll "fit"
    I personally dont mind using some aftermarket latches/ hood pins.
    But with a turbo 5.3 I'm not even sure itll fit a hood lol, only time will tell.
    Use brackets and you can custom fit a radiator in there.
    Crash bar will need to be fabbed up.
    IG: awesome.elvis
  4. #84
    Mar 15 2018
    Romania
    Not to mention front electric fans.
  5. #85
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    And then a intercooler.
    Once you start adding things room starts to get scarce.
    IG: awesome.elvis
  6. #86
    Mar 15 2018
    Romania
    I might have to hammer my crash support on 1.8 to make the turbo fit too :D and cut up bumper for intercooler
  7. #87
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    My single turbo allroad doesnt even have a crash bar 🤷*♂️.... the FMIC is too big
    IG: awesome.elvis
  8. #88
    Mar 15 2018
    Romania
    Quote Originally Posted by STK-Allroad View Post
    IG: awesome.elvis
    Crashbar , you mean the reinforced part of the bumper ? Yeah I might have to cut that a bit, but I am talking about the crash supports that actually hold the front end on :)
    This is the space I have, and I barerly clear the AC and I dont even know about the motor mount :D
  9. #89
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    Yeah the bar right behind the bumper. To not send the motor into your lap if you get it in the front.
    Are you talking about cutting into the frame rail it self ?!
    Why not do a top mount turbo?
    IG: awesome.elvis
  10. #90
    Mar 15 2018
    Romania
    IG: awesome.elvis
    Because I am using the stock 1.8T manifold that i got with an engine and I made a T3 adapter for it. It should be in one of my threads, but might repost it on my build thread.
  11. #91
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    Ohhhh okay I see.
    I recommend reinforcing the Frame rail if you have to cut it.
    IG: awesome.elvis
  12. #92
    Mar 15 2018
    Romania
    Ohhhh okay I see.
    IG: awesome.elvis
    I probably wont need to cut, just hammer a bit , I already clocked the compressor to the left side, relocated WG so I clear the AC bracket, but I actually need to put on engine to see how it is. Cant work in 30 cm snow tho :D
  13. #93
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    Ahhh okay.
    I'd say go for it in the snow. But I dont do shit outside if its snowing. I have a small space heater in the garage so sometimes it bearable
    IG: awesome.elvis
  14. #94
    Mar 15 2018
    Romania
    Ahhh okay.
    IG: awesome.elvis
    Idgaf about the cold :D the issue is with space . Its a small wooden garage, but the main thing is that its full with parts, and an engine. and I cannot move it alone, I am thinking about dissassembling it somehow so I can store it somewhere else. I mean there is a good 30-40 cm on each side , so it is definitly enough to work but as I said its full with crap atm :D
  15. #95
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    I have a 17z front calipers I was gonna throw on the STK allroad but this is gonna need the stopping power so gonna throw those bad mammerjammers on the B5
    IG: awesome.elvis
  16. #96
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    Got a call Friday that the custom flywheel and adapter plate are finished being made and will be shipped that afternoon.
    That means it's the for the 1.8 to leave its home soon. Possibly next weekend I'll start pulling it and prepping the car.
    Hope someone local wants to buy the 1.8 I dont wanna send a good motor off to the scrapper lol
    IG: awesome.elvis
  17. #97
    Mar 15 2018
    Romania
    IG: awesome.elvis
    I am sure somebody will buy it in country. Shipping shouldnt be that expensive ~50 usd ish.
  18. #98
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    brah! $50usd to ship an engine?
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
  19. #99
    Mar 15 2018
    Romania
    Quote Originally Posted by GrapeBandit View Post
    its 80 euroish in Europe. so it cant be that much there. The 1.8t is like ~100kg without accessories, and 150-170kg with flywheel, exhaust manifold, oil filter housing etc.
  20. #100
    Dec 13 2010
    FL
    Hey smart guy, euros are worth more than USD.
  21. #101
    Mar 15 2018
    Romania
    Hey smart guy, it is. But you also have way more and cheaper transport companies/ package options than in EU by DHL or some other 1st class shipping.
  22. #102
    Dec 09 2018
    6.0 F250/B5A4
    Colorado
    I'm gonna try to sell it local. I hate shipping. Like I am the worst shipper ever.
    If no one wants it. I'll load it up and send it to scrap with all the other scrap metal I have.
    IG: awesome.elvis
  23. #103
    Dec 13 2010
    FL
    Cheaper says the guy that lives 4000miles away. I ship shit all the time, cost me $160usd to ship a longblock about 1000miles. lay off the crack saying $50 when you have absolutely no clue what you are talking about. I know you have a problem of having to post like every 2mins, so you can't really help yourself.
  24. #104
    Mar 15 2018
    Romania
    Funny.. I did not say kilometers did I, the base shipping price is 50-100 usd depending on the company. It obviously increases with weight and distance... When and what I reply to - that is not your concern whatsoever :)
  25. #105
    Dec 13 2010
    FL
    you cant ship an engine 5miles for $50 kid!
    jesus christ, i miss the ignore option audizine used to have. mods need to bring that back
  26. #106
    Mar 15 2018
    Romania
    STK - do you have any future plans for this build ? I dont image you want to DD a 900 whp car ?
  27. #107
    Sep 24 2010
    Costa Mesa, SoCal
    Not even close
    I spent $118 just to ship an APR Stage 3+ turbo kit 2500 miles.
    Engine on a crate will definitely cost more.
    To the OP: as a B5 owner and C5 Corvette Z06 owner, I'm curious to see how your project turns out.
    2001.5 S4 Avant: JHM shifter, 3" exhaust, Stage 1, APR bipipe, lowered, receiving lots of love ($$$)
    2001.5 A4 1.8TQM: so many upgrades. Parting out.
    2001 Corvette (C5) Z06: just getting started
