Results 1 to 7 of 7
    Oct 10 2018
    2003 Audi Allroad 6spd, 2011 F350, 1997 F250LD, 1973 Jeep J4800
    Portland, OR
    Still fighting oil leak
    2003 Allroad 2.7T 6spd
    So after pulling motor and tranny to replace the clutch and fix a bunch of oil leaks I have the car back together and running good. I still have one oil leak though. When it warms up oil burns off the exhaust manifold on the passenger side. The turbo is also covered in oil.
    I have replaced the valve cover gaskets, half moon plugs, round plugs, chain tensioner gasket and all cam seals.
    I dont feel any oil along the edge of the valve cover gasket. The rear half moon seal and round plug looks ok.
    The valve cover gasket on that side has the "V" that goes between the cam cap and chain tensioner. Maybe I did not get that in the groove? I did put RTV in the appropriate places.
    I hope it isnt coming from the turbo somewhere. This is a very frustrating car.
    Apr 29 2009
    Quadzilla
    Longmont, CO
    did you use oem audi gaskets?
    if not, replace with oem
    also, did you use RTV at the corners of the valve covers and the 'V'?
    i did my VCG's 3 times before using oem, hasn't leaked since
    Rockin' the Rockies
    '01 allroad, 247k woot woot, still boosting on original turbos and tippy, slightly more modified. . .
    Oct 10 2018
    Portland, OR
    I did not use oem. I got a kit off Amazon. The valve covers are easy enough to get off. I'll give OEM a try.
    Nov 30 2016
    northfield, ma usa
    Looks like it leaking out of the half moon seals. Did you replace the cam chain tensioner gasket?
    Oct 10 2018
    Portland, OR
    The half moon seals and chain tensioner gaskets were replaced and the RTV was put in the appropriate places on all gaskets.
    One thing I noticed when putting it back together is that the end cap for the exhaust cams had no gaskets or RTV. They are a metal on metal seal. Maybe I scratched the surface and its seeping out from there. The oil leak is right in that area.
    I looked up OEM valve cover gaskets. $80 a side? Wow. The Mahle ones are $40 a side. What brand have other people had luck with other than OEM?
    Apr 29 2009
    Quadzilla
    Longmont, CO
    gotta know where to look
    i got most of the parts from europa parts the last time i did the VCG's, and they sell oem
    Rockin' the Rockies
    Senior Member Two Rings mr_dave's Avatar
    Apr 20 2013
    C5 RS6
    MN
    It took me a couple tries to get all the leaks on my S6 when I did it. I'd recommend making sure all the metal surfaces are perfectly clean - I even used rubbing alcohol. Then use a thin layer of Permatex Ultra Black on all seals. My main issues were the cam caps not seating/sealing properly.
