Results 1 to 10 of 10
Thread: Upgrade 3g+ ???
    Jan 07 2018
    Nashville, TN
    Upgrade 3g+ ???
    Can the B8 3g system be upgraded to a higher version of MMI ?
    Sent from my Pixel XL using Tapatalk
    Jan 07 2018
    Nashville, TN
    Anyone ?
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by audi_sq4 View Post
    Yes you can!
    I went from 3G Low (bnav) to 3G+...
    Straight swap of the main unit, control panel and screen albeit subject to C/P removal.
    Sent from my SM-G965F using Tapatalk
    Established Member Two Rings S5_SID's Avatar
    Apr 08 2018
    2011 S5 Quartz Gray Cab
    Orange County, CA
    Keep Deep Sea Alive!
    Deep Sea Diver 🇺🇸
    2011 S5 Cabriolet • Quartz Gray Metallic • 3.0T •B&O•Sport Seats• Peelers•Carbon Inlays•Mods to come...
    Jan 07 2018
    Nashville, TN
    Thank you !!
    What did you gain with the swap ?
    Oct 10 2016
    Madrid, Spain
    Thank you !!
    Native bluetooth streaming and graphics that are slightly more acceptable, but a lot less than what I gained installing my RSNav unit... If I hadn't managed to retrofit it for under €250 I'd be pretty gutted to have gone for it instead of waiting a bit more and save money (RSNav delivery ended up happening 4 months later than initially expected)...
    Jan 07 2018
    Nashville, TN
    So RSNav is a better option....?
    Apr 08 2018
    Orange County, CA
    Just a lot more you can do with rsnav. Bigger screens along with accessing odb functions as well. The more time the rsnav has the better it will be, with working out kinks. Upgradability is far easier on rsnav, just not oem. Some features are a bit slower but getting better.
    Also rsnav is cheaper with a better system in the long run.
    Deep Sea Diver 🇺🇸
    Seattle/Seoul
    Quote Originally Posted by S5_SID View Post
    I'm debating the same two options for my Q5 with MMI 3G. Mainly just looking for bluetooth integration to stream spotify. Seems like the component costs will be similar, but am concerned about the installation process and running into the component protection issues. How has the RSNAV reliability been on the most recent firmware?
    DBC ownz joo!! <- Wow what year is that from??
    Oct 10 2016
    Madrid, Spain
    Just upgraded my RSNav to 3rd Gen. and the improvement is noticeable...
    Sound quality is awesome (I've also added the missing tweeter on each front door) and the unit is super reactive...
