Results 1 to 31 of 31
Thread: 93 octane??
    Active Member Two Rings WhiteTrashB7's Avatar
    Nov 06 2018
    2005.5 b7 audi a4 2.0t quattro
    Aurora, CO
    93 octane??
    Does anyone know a gas station in aurora that sells 93 octane!?
    Established Member Two Rings Tony81's Avatar
    Apr 12 2015
    Denver
    I wish...
    Sep 10 2018
    N.W colorado
    I thought 91 was the highest tou could get in colorado
    Dec 03 2008
    2014 Forester XT, lawn mower
    Castle Rock, Colorado
    Gotta mix some E85 to get 93 octane...
    Sent from my SM-G965U using Tapatalk
    2012 Audi S4 Prestige 6 speed, 034 Stage 2+, 034 SC pulley, JHM 179mm Crank, USP Intake, custom x-pipe exhaust, 034 Trans Mount Insert, 034 Front/Rear Diff Mount Inserts, JHM Stage 3 clutch, JHM LWFW, USP SS clutch line, 034 boost tap, Podi boost gauge
    Nov 06 2018
    Aurora, CO
    Damn... well, good to know but sucks to hear! Thankyou guys for the responses!
    Senior Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    I'm only aware of a couple of gas stations in the entire state that offer 93. One in Aurora, and one near Cherry Creek. The last time I was at the Cherry Creek one on Evans, the 93 was listed as out of order, so they may not even have it anymore (this was at least 2 years ago, I don't live in Denver).
    Like others have said, you have to mix 91 and E85 to reliably get 93 here. Generally 3.5 to 4 gallons of E85 and the rest as 91 octane will get you 93/94, assuming you're near empty. If you're concerned with running a 93 tune on 91 octane, at this altitude you can safely do it. If you're going to be driving below 3500 feet though, either plan ahead on where you can fill with 93 or just change your tune over to a 91 octane build if possible.
    2013 Audi S5
    2011 Toyota Tacoma TRD Sport
    2003 Evolution VIII (Cammed, etc)
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Veteran Member Three Rings UltraSchnell34's Avatar
    Nov 04 2011
    2013 Audi S4, 2004 USP Avant 6spd(Sold), 1998 Jeep XJ
    Morrison, CO
    Here is a good resource for you https://find93.com/
    -2013 Moonlight Blue S4- Stock for now
    -2004 A4 USP 6spd Avant- SOLD
    Nov 17 2006
    I looked for the Denver station on that website with zero luck. Please let me know if that has been different for anyone else.
    I generally add e85 or fill up with 100 on occasion.
    Senior Member Four Rings Joe Jr.'s Avatar
    Mar 09 2017
    Longmont, CO
    switch over to e85....lol...
    2001 A4 1.8TQM
    2002 VW TDI 5spd
    Apr 29 2009
    Quadzilla
    Longmont, CO
    gotta go south of the mason-dixon line to find 93 octane . . .
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Feb 06 2009
    Audi A4, Mit. Montero
    Goldsboro, NC
    How prevalent is E85 in COS? How about Unleaded 100oct?
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Dec 03 2008
    Probably better off ordering E98 delivered in 50 gallon drum...
    Dec 03 2008
    @Operator I got quoted a while back for about $170 delivered for 50 gallons of E98. Hit up Hill Petroleum if you are interested.
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    I am not sure why a 93 octane gas will make much difference on a NA engine
    Established Member Three Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 (Literally in my garage most of the time); '03 Acura 3.2TL Type-S
    CO
    Seems to be a bit less prevalent the last couple of years. Used to see it regularly, especially as I got closer to Denver (a bit less so in COS). But I don't believe I see it at as may stations now. Maybe it's just that I'm not looking for it.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optics Plus, B&O, Adaptive Damping Suspension. Carbon Fiber license plate frames & tire valve caps. Mods to follow.
    Jul 17 2015
    Colorado
    I think nearly every Kum and Go in the Springs has E85 now. The one by my house recently added it, so I no longer have to drive down an extra exit to fill up.
    2013 Audi S5
    IG: @MrHazeMyth
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    What's the ratio of E85 to 91 to get 93? There's a Kum & Go right down the street... a lot closer than trekking down to Chief Petroleum for 100.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Dec 03 2008
    Quote Originally Posted by auditd0rk View Post
    With the math I've done, E25 should get you to 93. For me that's 3-4 gallons in a 16.9 gallon tank, depending on quality, but the best I've found to mix anywhere near me is like E75.
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4, 18' Discovery HSE (V), Durango R/T (sold), ML350 (sold)
    Seattle,WA
    Quote Originally Posted by 03TLSinCO View Post
    Corner of alameda and broadway if that helps, that痴 where I got mine.
    2012 S4 DSG, Ibis, Nappa, sports diff, EPL stg 1 ECU/TCU, Eurocode intake, 034 TM, X-pipe, C-Quartz, Akebonos, BFI shift knob, RS grille.
    Jan 01 2019
    Boulder
    How many of you guys are on a 93 file in Colorado? I知 wondering if it makes any difference between the 91 and 93 file at this altitude. I知 on 91 file now but I知 thinking about switching to the 93 file and filling up with 4 gallons of e85.
    Dec 03 2008
    Quote Originally Posted by MedinaGreen View Post
    Will be trying 93 file with E85 mix come spring
    Aug 27 2014
    Seattle,WA
    I was on the 93 file since day one, no issues. Added 3 to 4 gallons of E85 every fill up.
    Jul 17 2015
    Colorado
    I'm running EPL's 93 file. Since we're at high altitude you can actually get away with running 91 octane on the 93 map without causing damage to your motor. Per EPL's tuners though, if you go lower in altitude and will not have access to either 93 or E85+91, you would want to / need to load a 91 octane map to be safe. I was told by them that it's safe to run at a maximum of 4.5 gallons of E85, but that the closer to 4 I could get the better.
    I've only ran 91 a couple times since my tune. I don't do a lot of miles, so the more frequent fill-ups needed when running with some E85 don't bother me one bit. Highway miles even with E85 mixed in are honestly not as bad as I thought they were going to be. Still bad, just not as bad as I initially thought.
    2013 Audi S5
    IG: @MrHazeMyth
    Mar 26 2007
    Colorado
    New Kum & Go off I-70 and morrison exit. Next to all the park and ride lots. First time i've ever seen E15
    CURRENT:
    APR - B8 Avant
    2018 - VW ATLAS
    Dec 03 2008
    Quote Originally Posted by vdubjetta02 View Post
    Weird! What's the point of E15?
    Jan 01 2019
    Boulder
    Quote Originally Posted by HazeMyth View Post
    Thanks. I think I知 going to install the 93 file and see if I can feel any difference.
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Think of it as a cheaper mid-grade option (~88oct).
    Here痴 a good read on E15:
    * https://ethanolrfa.org/resources/blends/e15/
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Jur Mahm
    Denver CO
    Thanks - your post just secured me an E-85 source a few miles closer to me!
    2013 S4 Estoril Blue Crystal 6MT / Prestige / Silver & Black / B&O / Sport Diff / 20% Tint / ECS SSK / E-codes / RS Grille / Ziza Yellow Fogs / ECS Slotted & Drilled Rotors / Akebono Pads / Roc Euro Intake
    Denver to Vegas in 9:26 (2/27/15)
    Veteran Member Three Rings Aok303's Avatar
    Jul 11 2012
    Bicycle bicycle i wont ride my bicycle
    Lakewood-Morrison / Colorado
    the Bradley on alameda and broadway still is the best spot to get e85, the Forum on facebook has people doing test all the time and the consistency of the oct is best there and highest average
    i run mix in summer to early winter and go to 91 for the rest. i also am by one of the spots that sell 100 oct year round as i live by bandamire. sadly brads conoco no longer sells gas as i know alot went there during race season since they never mixed additives in.
    2016 Noggy S4 - Kohlefaser Luft-Technik Intake System, Chipwerke Pro, CR-15, Awe touring and Dp, H&R OEM springs, and Ziza LED's everywhere
    Want List: carbon fiber rear diffuser, Rear sway bar, xbrace, and after audi care is over stage 2 mods
    Mar 26 2007
    Colorado
    Brotherowl Off the morrison exit, Im building the Over Yonder Brewery 50' away.... so you will also have a place to grab a beer.
    "Vice whiskey and kitchen" is also a good hangout place now right next to the brewery. Owners are really nice and they have a good happy hour.
    2-3 draft beers during happy hour will only run you around $9.
    CURRENT:
    APR - B8 Avant
    2018 - VW ATLAS
    Nov 17 2006
    Quote Originally Posted by Aok303 View Post
    What's the name of the FB group?
