Results 1 to 7 of 7
Thread: 2.0 l oil leak
    Oct 07 2018
    Revelstoke bc canada
    2.0 l oil leak
    I was wondering if there is common oil leak on these motors. I just replaced the valve cover gasket. Looking to be coming from below that on the passage side back corner.
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 15 2011
    08 xB, 13 Ex, 16 Civic EX
    most likely the gasket on your cam chain housing....did mine at 185k miles.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Jun 27 2011
    Back on that side itís the cam chain cover gasket or the vacuum pump seals.
    If itís lower down on the drivers side itís the oil cooler or oil filter housing gasket.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant)
    2012 Q5 2.0t - Stock Mommy Missile with new timing chains
    Former USP CLUB MEMBER #136
    Oct 07 2018
    I am not sure how to post pictures on here yet. But There was oil all over the passenger side of the transmission and the axle cover. But it did look like it all came from the top side
    Senior Member Four Rings Dondbg's Avatar
    Mar 12 2016
    MB w203
    New Zealand
    Quote Originally Posted by cody_harris View Post
    Vacuum pump gasket or cam chain gasket
    Best approach is to clean the area with warm soapy water and you will be able to see the source.
    Feb 15 2016
    Cambridge Ontario
    vacuum pump I would say for sure . I found the timing cover pretty rock steady unles it has been off before . But if I were going in there I would just do both and check cam follower and tensioner at the same time.
    2014 A4 2.0TQ Technik
    2006 A4 2.0TQ 6spd
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 15 2011
    Both will give you trouble eventually....like everyone is saying deal with them at the same time and be worry free. If it were me...
    - rebuild vacuum pump with one of those seal kits charles posted pics of. Something like $20 and you're good.
    - gasket on cam chain cover.. $10
    - coolant flange - it'll be sitting right there taunting you.....its $20 and normally a pain to get at
    knock on wood....but my cam tensioner and associated bits and pieces are hanging in there. If you have any issues in that area you might want to consider taking care of them...maybe the rings on the rings on the cam adjuster?
    https://www.ecstuning.com/b-genuine-...et/06f198107a/
