Results 1 to 8 of 8
    Jul 30 2018
    Lafayette la
    Rev limiter in neutral?
    Do our cars have a factory rev limiter in neutral around 4500rpm?
    I thought it was the launch control feature that my tune is supposed to have but it wonít do it in first and I donít remember my last b5 s4 having a limiter in neutral
    Feb 23 2010
    Lehigh Valley
    Nope
    Jul 30 2018
    Lafayette la
    Hmm Iím really confused then :/
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Any codes, like for the vss?
    If you swap a 2.7 into a b6 that doesnt have a vss, and dont hook it up elsewhere, it will not rev above something like 5.5k iirc.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesnít move and it should - WD40.
    Jul 30 2018
    Lafayette la
    Quote Originally Posted by zillarob View Post
    No codes but what does the gas code mean
    Jul 30 2018
    Lafayette la
    Vss*
    Nov 16 2010
    WetSide, WA
    Vehicle speed sensor.
    You have a tune?
    A soft launch limit easy to do and could be in there.
    It doesnt build boost though because it is just limiting the throttle.
    Jul 30 2018
    Lafayette la
    Yeah itís a b5 projects stage 3 tune and it apparently had launch control according to the previous owner. And yeah it doesnít build boost just limits the throttle. Iím guessing itís not working in first cause somethings up with my clutch switch?
