Results 1 to 8 of 8
    Sep 28 2009
    suburb
    How do I remove this mirror trim piece
    How do I remove the base piece (the most bottom black piece)? I used a trim tool to separate the middle and lower piece and broke a tab on the middle piece. I canít seem to loosen the lower piece. Any advice?
    Audi S7 stage 2
    Audi allroad stage 3
    Audi q5 stage 1
    Jan 10 2014
    2012 a4, 2015 s4
    Houston, TX
    This piece? It pops right off
    Sent from my SM-G965U using Tapatalk
    Established Member Two Rings Nully's Avatar
    Sep 11 2014
    WA, US
    That's part of the actual mirror assembly. To remove the assembly:
    1) Squeeze the two sides of the bigger flat cover further back and pull it off.
    2) Unplug the cable there.
    3) Grab that piece you are pointing at and twist it; the mirror assembly will come off the windshield.
    Sep 28 2009
    suburb
    Yes the piece with the red arrows.
    In regards to #1 above, are you referring to the big flat piece that is directly above the mirror?
    I donít want to remove the whole mirror. I want to buy a dash cam and it asks for a picture of the inside view of the black piece with arrows to it to see the clips on the inside so that the proper part can be sent. It doesnít come off by itself? Iíve searched bunch of YouTube videos and canít find one to show how itís removed.
    Audi S7 stage 2
    Audi q5 stage 1
    Feb 01 2017
    Seattle WA
    The so-so instruction on Aliexpress also mentions taking the cover above first, then the one with red arrows. Looks like there is a sequence to this.
    Aug 20 2018
    Ponchatoula, LA
    I found this out the hard way but the cover piece pops right off and the whole mirror twists right off...I went fishing one weekend and came home to my wife making a sorry face and my mirror dangling from the windshield lol
    Sep 28 2009
    suburb
    Quote Originally Posted by Jasonb0383 View Post
    Did you figure out how it pops off by itself? Without removing the mirror?
    Audi S7 stage 2
    Audi q5 stage 1
    Aug 20 2018
    Ponchatoula, LA
    It just pops off when you pull I believe maybe squeeze it a little...I saw a video on youtube too on how to take it off and put it on
