Originally Posted by
JamesRS5
I believe the speed signal is pulled off the CAN bus by the spoiler control module so any adjustment may have to be made in the module itself? Maybe someone with electronics skills could figure how the control module interprets the CAN signal to trigger it deploying earlier.
I know KW suspension DDC taps into the CAN bus next to the spoiler control and it also takes a speed signal to adjust the damping as speed increases.
I’m not sure how long the spoiler motor would last if you wired it up to the brake lights, driving in traffic would shorten its life dramatically.
You’re right about practicality, putting on my aircraft engineering hat, the rear spoiler isn’t an air brake nor would it have any braking effect in its current configuration, you’d have to alter its deployment angle to have any type of drag effect and that sounds like an awful lot of work for very little result, putting your head out of the window would have the same braking effect.
Spoiler alert (pun intended), I'm actually getting an aftermarket CF wing that I'll custom fab brackets for. So it'll be able to rotate and go basically vertical which should actually have some impact on braking. However you're right the motor would burn out pretty quick, so I have 2 ideas on how to avoid this.
There's emergency braking where the lights flash under hard braking, could possibly tap into this.
Second idea is still tying into the rear lights but adding an on/off switch so the 'air brake' only activates when I have the whole system turned on.
