Results 1 to 7 of 7
    Sep 09 2018
    Ohio
    Schwaben code reader
    Okay so I bought a schwaben code reader, Iím following the steps Iíve read are necessary. But how the fuck do I log in. You need to do a log in before anything else. Iím trying to Re-code the ABS Module I installed. If anyone has any experience with these itíd be much appreciated. Thanks you.
    Registered Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    I normally used VCDS schwaben reader is made by foxwell.I would assume it comes with a manual.
    Sep 09 2018
    Ohio
    Quote Originally Posted by EuroxS4 View Post
    Yes of course, which doesnít help on this matter. Went through the thing like 4 times.
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by DustyA4 View Post
    You need to follow login from vcds wiki
    http://wiki.ross-tech.com/wiki/index...sch_5.7)#Login
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Log in? Are you talking about the tool itself or the website? The tool should be plug and play. You have to create a log in ID for the website for registering the product and software updates. --- Edit ----Sorry i think Euro gave you the answer you are looking for.
    Sep 09 2018
    Ohio
    I followed the login. It doesnít give instructions as to how to log in though, simply states you need to. And not only that, my particular Audi has 17in Rims, I have the paper from the day it was purchased and the person bought them as an add on for $500, HOWEVER, the sheet with my coding from the spare tire well says my package has 15in.. and not only that, the sheet DOES NOT have a could for transmission, I have the slap shifter so I think itís multitronic. However it doesnít state. Iíve tried both 15Ē coding and 17Ē coding neither worked, however I tried them with ďautomaticĒ coding.
    Jan 24 2010
    Paramus,NJ USA
    if you cant login.It wount let you change the coding.Simple as that.You need to login into the module and enter login code before any changes can be made.Is there a login selection when entering menu for abs module on the scanner??
    VCDS login procedure.I would assume schwaben is very similar if not the same.
    https://www.youtube.com/watch?v=DvJ8ILKfhS8
