Results 1 to 3 of 3
    Nov 27 2018
    2000 a6 4.2 transmission problem!! help please!!!!!
    hello there!! ok I Have a 2000 a6 4.2 with 123xxx I own the car for about 3 years, the car shift all gears fine, but this past monday when I went out and was parking and notice, that when I put the car in reverse the car doesn't move! feels like if the E brake was on, but if I hit the gas a bit the car moves but feels heavy like if the E brake its on, but if I put it on Drive then back to reverse it move's fine and smooth.......but what I notice is that it only happen when I start driving the car, but the car will be fine for the rest of the day, I check the car with a vag- com and it has no codes and no check engine light on, I would like to know if this had ever happened to any of you guys? and I also would like to know if the tranny is on its way out? witch I know this cars have bad transmission!! and the other part that SUCKS!! is that I have a guy buying the car this Tuesday coming up, but if I can't get it fix I guess I'm gonna have to keep it. I would appreciate the help.....chrishttps://discord.software/ FetLife https://downloader.vip/itunes/
    Senior Member Three Rings Pizdets-b5's Avatar
    Dec 21 2013
    Portland/ME
    Where in canada are you? Im in maine like 4 hours from the border. Im parting out a 4.2
    if you want a trans ill sell you one for $100 usd
    POWER!!!!
    Registered Member One Ring Hezole's Avatar
    Sep 24 2018
    BMW E3
    New Jersey
    Thanks for this info!
    __________________________________________________ _________________
    Only god can judge me
    Cheers,Diceus
