Results 1 to 3 of 3
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
    -Plug and play
    -Error free
    -Easy to switch between each color simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
    -BRIGHT this is not just a novelty bulb
    -COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
    -HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
    -SAFE more light on the sides and down the road when dark or in bad weather conditions
    ****INTRO PRICE****$110 includes FREE UPGRADED SHIPPING (RETAIL $144.99) Simply email Support@deAutoLED.com for an invoice
    This has 3 different colors and 4 different strobe/flash modes:
    -The Hyper Strobe / Flash this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
    https://www.instagram.com/p/Bpjxc_ajyaS/
    3 colors:
    -Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
    -Clean White 5500k that matches our LED & HID Headlights
    -Halogen 4300k that matches OEM
    Video cycling quickly through colors AND different strobe/flash features:
    INFO:
    ****Do not miss out these are going fast**** This Into Price ENDS IN approximately 2 weeks!
    -Also including 20% off anything else you purchase only valid when you purchase fogs
    -They have a ship date of December 17th-19th with FREE upgraded priority mail shipping within the US only. These will most likely arrive before Christmas but currently no guarantee (sub to this thread for updates)
    -THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
    -These produce MORE LUMENS than many standalone single color white fog LEDs on the market
    -Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
    *Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models errors WILL clear once you go back to a solid color.
    UPDATED FAQ
    Is there a lifetime warranty?
    YES! As always this comes with a True Lifetime Warranty!
    Will your fogs keep changing colors if you use them as cornering lights?
    The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
    How does this work with the coming home feature?
    This works just like OEM. It will always be the default color of white.
    What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
    The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
    Can these turn 360 degrees?
    Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
    Are these as bright as your single color de360 fogs?
    While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
    Can you bypass the strobe feature?
    Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
    Some more fun shots - in the rain:
    White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
    And switch back to clean white:
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
    Sep 10 2012
    London
    International shipping?
    Feb 13 2015
    US
    Quote Originally Posted by Adamantium View Post
    You have to email the team but currently this is only for US residents.
    Thank you
    deAutoLED.com
