Results 1 to 18 of 18
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
    -Plug and play
    -Error free
    -Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
    -BRIGHT – this is not just a novelty bulb
    -COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
    -HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
    -SAFE – more light on the sides and down the road when dark or in bad weather conditions
    ****INTRO PRICE****$110 includes FREE UPGRADED SHIPPING (RETAIL $144.99) Simply email Support@deAutoLED.com for an invoice
    This has 3 different colors and 4 different strobe/flash modes:
    -The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
    https://www.instagram.com/p/Bpjxc_ajyaS/
    3 colors:
    -Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
    -Clean White 5500k that matches our LED & HID Headlights
    -Halogen 4300k that matches OEM
    Video cycling quickly through colors AND different strobe/flash features:
    INFO:
    ****Do not miss out these are going fast**** This Into Price ENDS IN approximately 2 weeks!
    -Also including 20% off anything else you purchase – only valid when you purchase fogs
    -They have a ship date of December 17th-19th with FREE upgraded priority mail shipping within the US only. These will most likely arrive before Christmas but currently no guarantee (sub to this thread for updates)
    -THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
    -These produce MORE LUMENS than many standalone single color white fog LEDs on the market
    -Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
    *Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
    UPDATED FAQ
    Is there a lifetime warranty?
    YES! As always this comes with a True Lifetime Warranty!
    Will your fogs keep changing colors if you use them as cornering lights?
    The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
    How does this work with the coming home feature?
    This works just like OEM. It will always be the default color of white.
    What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
    The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
    Can these turn 360 degrees?
    Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
    Are these as bright as your single color de360 fogs?
    While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
    Can you bypass the strobe feature?
    Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
    Some more fun shots - in the rain:
    White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
    And switch back to clean white:
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
    Feb 13 2015
    US
    FINAL WEEK FOR THIS GROUP BUY - DO NOT MISS OUT!
    NEW VIDEO DEMO:
    timestamps:
    How to control colors with OEM Fog switch:
    https://youtu.be/VSRIYu9xwzM?t=117
    How to bypass any color (wait 2 seconds vs quick off/on with fog switch):
    https://youtu.be/VSRIYu9xwzM?t=242
    How the white/yellow/strobe look from far away:
    https://youtu.be/VSRIYu9xwzM?t=13
    How they act as cornering lights:
    a) from inside car:
    https://youtu.be/VSRIYu9xwzM?t=220
    b) close (outside of car):
    https://youtu.be/VSRIYu9xwzM?t=294
    c) far away (outside of car):
    https://youtu.be/VSRIYu9xwzM?t=5
    Colors / cut-off on garage:
    https://youtu.be/VSRIYu9xwzM?t=140
    Small talk about the bulbs vs single color:
    https://www.youtube.com/watch?v=VSRI...=youtu.be&t=37
    deAutoLED.com
    Feb 13 2015
    US
    LAST WEEKEND!
    Thank you
    deAutoLED.com
    Feb 13 2015
    US
    Our group buy is extended!
    Simply email Support@deAutoLED.com to get in the group buy!
    deAutoLED.com
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    I got a set of these! They're awesome!
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Aug 06 2012
    Parker, CO
    Is this buy over?
    Vehicles: 2013 Ibis White allroad & 2006 Campy White Touareg
    Feb 13 2015
    US
    Quote Originally Posted by treginginco View Post
    Is this buy over?
    We are keeping it open for a few more days but price most likely increasing as intro price is over. Email with your info and the team can help.
    deAutoLED.com
    Aug 06 2012
    Parker, CO
    Message sent
    Feb 13 2015
    US
    Thanks - gb was extended so email Support@deAutoLED.com
    They will ship in less than a week!
    deAutoLED.com
    Feb 13 2015
    US
    THE SALE CONTINUES.
    Simply fill out questions below and email it to Support@deAutoLED.com:
    1) what is the bulb type of your halogen
    2) what year/make is your car
    3) is this shipping within the US
    4) do you want anything else (reverse/turns/interior etc.) at 20% off
    5) you might need an outside resistor - we sell it for an additional $15 but can try without resistors first
    6) we also have a non-strobe flash if you are interested in this model
    Both strobe & non-strobe model utilize the same bright diodes and are the same price.
    Thank you
    deAutoLED.com
    Aug 06 2012
    Parker, CO
    I ordered a set of these and got them installed this morning on my 2013 allroad
    First.... even in daylight... these things are REALLY DAMN bright!
    Second.... while it doesn’t translate well in these pictures.... the hyper yellow is REALLY DAMN bright!
    Third.... install was eeeeeeeeeasy!!
    Fourth.... in “strobe” mode, it will throw a lights error warning on the dash, but it goes out at the next start, just like DeautoLED says it will.
    And.... the weather finally showed up today here in Colorado that will put these babies to the test tonight.
    Initial thought..... I like ‘em!
    White light
    Hyper yellow
    Aug 06 2012
    Parker, CO
    And one more thing..... the flash and strobe functions are pretty damn cool!
    Aug 06 2012
    Parker, CO
    And..... the cornering light function still has the lights fade in and out like a regular bulb.
    Jan 18 2010
    Spokane Washington
    damn, i want these!!! Will they be available on the website one day??? Or will there be a second group buy??
    Feb 13 2015
    US
    Quote Originally Posted by lscheres View Post
    Hi, it is still on - you can email the team - it is going up in price after this weekend so don't miss out!
    treginginco - thanks for the amazing feedback. We appreciate it.
    deAutoLED.com
    Aug 06 2012
    Parker, CO
    These things are impressive.
    Without fogs on
    With hyper yellows activated
    Established Member Two Rings CanadaRed's Avatar
    Aug 26 2013
    London, Ont
    Can you just get these in yellow?
    1993 Honda Prelude SR 4WS
    1997 Honda Prelude Base
    1996 Volvo 850 Turbo Wagon
    2010 A4 2.0T Sline 6spd MT
    Feb 13 2015
    US
    Quote Originally Posted by CanadaRed View Post
    Not just yellow.
    But they have a White/Yellow/Halogen model too without strobe/flash mode.
    Thank you
    deAutoLED.com
