Results 1 to 6 of 6
    Oct 24 2018
    New Hampshire
    no CEL but still throwing code
    so I have a code p0340 Camshaft Position Sensor A Circuit Bank 1 or Single Sensor and I replaced the camshaft sensor and it did nothing. so I then replaced the speed sensor (crankshaft sensor) and my CEL went off but it still throws the code???? why could this be? I was thinking the timing belt but shouldn't the CEL still be on if that was the case?
    (fyi my first thought was dash light burnt out but I turned the car off and started it back up and it showed up when it went thru the system check then went out when system check was completed)
    any help would be greatly appreciated.....
    Veteran Member Three Rings SteelyS6's Avatar
    Oct 29 2011
    2004 Atlas Allroad 6MT, 2001 Kermit stage 3
    Winnipeg Manitoba
    Which engine? The 4.2's can have issues with the cam chain tensioner's.
    Oct 24 2018
    New Hampshire
    it's the 2.7t
    Sep 16 2010
    Central Wash
    unplug the sensor and drive. If the code is:--- 16724/P0340 - Camshaft Position Sensor (G40): Malfunction --Then it should change to something like 'open circuit/ short to plus' or something with it unplugged. Swap the sensors from each bank and see if the error follows the sensor to the other bank.
    If it does, bad sensor. If it doesn't ...not sure. Bad wiring?
    Apr 29 2009
    Quadzilla
    Longmont, CO
    would a bad ground make funny things happen?
    if so . . .
    Rockin' the Rockies
    '01 allroad, 240k woot woot, still boosting on original turbos and tippy, slightly more modified. . .
    Oct 24 2018
    New Hampshire
    yeah but a bad ground would make funny things happen intermittently not do funny things and stay that way
