Results 1 to 9 of 9
    GTA, Canada
    Rear brake replacement, any tricks for caliper carrier bolts
    I've got things pulled apart but am struggling with the caliper bolts. Any tricks, I have a torque gun but there is no space to get in there. How are you getting these out to change out the rotor?
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    I use a breaker bar and small 1/2 drive socket.
    Instagram: donomoko
    - 2014 S5 3.0T Prestige - : Plain ole S5 w/ a few cosmetic mods...
    Senior Member Three Rings MME1122's Avatar
    Mar 26 2016
    2011 Jeep Liberty
    The rear was very difficult for me. No room for an impact gun, and no room for my big 1/2" breaker bar. I have a 3/8 breaker bar that's about a foot and a half long so it fit in the wheel well, and I used a hammer on it to knock the bolts loose. And some penetrating oil for good measure, even though the bolts are aluminum.
    Going back in, I got the torque right but didn't get a full 90 degree turn after. I haven't had any issues.
    Sep 29 2018
    Dallas
    Quote Originally Posted by MME1122 View Post
    What does that mean? Full 90 degree turn after?
    GTA, Canada
    Thanks boys. Breaker bar and hammer, and after a long session I got movement.
    Audizine
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Quote Originally Posted by JPhi1618 View Post
    Audi uses stretch bolts, one time use on a lot of components so you replace with new ones. When you torque them down, Audi specifies a preliminary torque figure, say 60Nm plus a 90 degree (or whatever they specify) additional rotation of the torque wrench. So you torque it down to 60Nm and then turn an additional 90 degrees of rotation.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Sep 29 2018
    Dallas
    Quote Originally Posted by Ape Factory View Post
    Ok, cool. Didn’t realize that and was thinking, yea... that’s not how you torque a bolt... Thanks for the knowledge.
    Jun 24 2017
    San Antonio, TX
    They're also called torque to yield bolts. They physically stretch which is why you cannot reuse them. Theoretically you can with a bit of loctite blue and more torque but most of the bolts are fairly inexpensive. It's a pain when you do suspension as you replace every bolt. ECS actually has a whole kit just for this.
    Some links to parts but you can get them at your local Audi dealer for about the same cost or even less if you're an Audi Club member:
    https://www.ecstuning.com/b-genuine-...ch/8k0698470a/
    https://www.ecstuning.com/b-genuine-...ach/n91041702/
    https://www.ecstuning.com/b-genuine-...ach/n91126801/
    Mar 26 2016
    2011 Jeep Liberty
    Yeah I replaced the carrier bolts but none of the others. The audi shop manual says to replace the others too but they're just tightened to a torque, not stretched after. And it's a low torque, so I saw no need to replace them. I'm assuming they recommend it just because it's for brakes.
